DuetWifi; no tool selected
Maybe run the code with M98 and see if there are errors before the T1 which prevents execution?
@bearer
Thank you for the suggestion. I tried running a macro file, and had a copy in both the Macros folder as well as the Jobs folder, and I got an error "File not Found". -
I was able to get the macro to run by entering the full file path. I still get the error "Attempting to extrude with no tool selected."
I also tried issuing a tool command in the Console, as well as through the terminal, and even included another one in the "macro call" file. Still, no extruder moving.
@tenaja maybe you have T0 defined rather than T1? Post your config so we can see if everything is defined correctly.
@droftarts said in DuetWifi; no tool selected:
I did not change this after the FW update, so unless tool numbering changed, it has to be something else. But, despite this, I had already considered and tried T0, and it gave the same error.
Here is my config. I deleted the network setup, but it does work, both before and after the 3.1.1 update. Note, I am not using any heaters.
; Communication and general M111 S0 ; Debug off ;*** Networking M552 S1 ; Turn network on M555 P2 ; Set output to look like Marlin G20 ; (Edit) Work in INCHES (Edit) G90 ; (Edit) Send absolute coordinates... for xyz axes (Edit) M83 ; (Edit) ...but relative SPINDLE moves (Edit) ; Disable Fan 1 thermostatic mode M106 P1 H-1 ; Axis and motor configuration ; M584 Z0 A4 ; (Edit) M584: Set drive mapping M569 P0 S1 ; Drive 0 goes forwards M569 P1 S1 ; Drive 1 goes forwards M569 P2 S1 ; Drive 2 goes forwards M569 P3 S1 ; Drive 3 goes forwards M569 P4 S1 ; Drive 4 goes forwards M574 X2 Y2 Z2 S1 ; set endstop configuration (all endstops at high end, active high) ;*** The homed height is deliberately set too high in the following - you will adjust it during calibration ;M665 R105.6 L215.0 B85 H250 ; (Edit commented out) set delta radius, diagonal rod length, printable radius and homed height (Edit) M666 X0 Y0 Z0 ; put your endstop adjustments here, or let auto calibration find them M350 Z64 A64 E64 I1 ; (Edit) MICROSTEPS: Set 32x & 16x microstepping with interpolation (Edit) M92 Z10078.74 ; (Edit) Set axis steps/mm(Edit) M906 X1000 Y1000 Z1000 E1000 I50 ; (Edit) Set motor currents (mA) and increase idle current to 60%--1.68A/phase max for OpenBuilds (Edit) M201 X1 Y1 Z10 A40 E40 ; Accelerations (mm/s^2) M203 X40 Y40 Z35 A3200 E3200 ; (Edit) Maximum speeds (INCH/min) (Edit) M566 X10 Y10 Z10 A100 E100 ; Maximum instant speed changes mm/minute ; Tool definitions M563 P1 D1 ; Define Tool with with E1 as the driver no fan or heaters M92 E503.937 ; Edit: Set "extruder" spindle steps per mm, which gets multiplied by 2.54 for steps/inch; use for steps/rev. ; Z probe and compensation definition ;*** If you have a switch instead of an IR probe, change P1 to P4 in the following M558 command. M558 P4 F100 T6000 X0 Y0 Z0 H3 ; (Edit) Z probe is a Smart Effector and is not used for homing any axes R0.4 not used. Reduced F300 to 100 G31 P100 X0 Y0 Z-0.25 ; Set the zprobe height and threshold for Smart Effector ; M208 S1 Z-0.2 ; set minimum Z T1 ; select first hot end (required) M302 ; allow cold extrude. ; M117 Use https://configurator.reprapfirmware.org/ to set up your printer config
@tenaja your config.g is not sufficiently updated for RRF 3. You need to define the motors with M584, and update your endstop settings. See https://duet3d.dozuki.com/Wiki/RepRapFirmware_3_overview#Section_Summary_of_what_you_need_to_do_to_convert_your_configuration_and_other_files
Edit: in other words, define the extruder motor with M584, because it isn’t defined at the moment, so there’s no tool as you have defined it only with a non-existent extruder drive. You’ll have more success if you use the configuration tool. Run
M98 P”config.g”
to show errors in config.g, though this won’t show missing commands.Ian
Might want to generate a config set using the web tool to get a good example of the syntax for RRF3 to compare against.
M584
Ian,
Thank you for the suggestions. I ran through the config, and filled in the blanks as possible, but received the same error.I believe my biggest problem is this is not a printer, and the config tools (and help files) are not really setup to handle devices that are not printers. There are numerous configurations required in setup that simply do not exist--such as "tools", heaters, endstops, and all the other goodies that a 2-axis "cnc machine" simply does not have or need.
The way I arrived at my original config was to use the config tool, and deleted the unnecessary "clutter".
Re-running the config with the new version did not produce a functioning config file. I could not get the E axis to move regardless... so I just remapped it to A, and now it works. I prefer not to do things like that, but sometimes you just have to quit wasting time.
I really do appreciate the time you took to help me. This forum has always had people willing to assist.
@tenaja If you could describe your machine requirements (you say 2 axis CNC, but with one rotation axis?), and post your config.g as it stands now, I'll have a look and see if it can be improved. Do you need to use the extruder axis? It looks like you're trying to use it as a spindle? Or is it to turn the spindle to follow a line (so not really a spindle, more to turn the cutter in the correct direction)?
Also, you said earlier when you posted your config.g:
If you mean you have M587 in your config.g, you need to remove this from your config anyway. As well as being a security hazard, writing the access point parameters to WiFi chip every time you start the Duet may eventually wear out the flash memory. See https://duet3d.dozuki.com/Wiki/Gcode?revisionid=HEAD#Section_M587_Add_WiFi_host_network_to_remembered_list_or_list_remembered_networks
@tenaja said in DuetWifi; no tool selected:
@bearer
Thank you for the suggestion. I tried running a macro file, and had a copy in both the Macros folder as well as the Jobs folder, and I got an error "File not Found".try running config.g after boot up and see what errors you get:
M98 P"0:/sys/config.g"
