Getting WiFi to connect
The web interface is mostly working now; I uploaded the new firmware. I do get occasional apparently random AJAX disconnections. I'm willing to do some detective work, if there's a way to track down what might be wrong.
Hey Anne
If you are able to dig into what's happening on your network when the Ajax disconnects happens that would be helpful. A program like wireshark can give you a trace of what's happening. Its interesting to see if the network connection is dropping completely or if it's just the session in the browser.
I don't know if I should create a new thread, If so, please feel free to split this off.
I'm trying to get my DuetWiFi online, and am getting the same "Reset reason: Exception" errors, though only one at a time.
This is a bare board and PanelDue being bench tested with no steppers or external power other than microUSB to the computer.
When I turn on the WiFi server, it comes online, with the same string as shown above.Flash size 4194304, free RAM 27088 bytes, WiFi Vcc 3.38V, host name: duetwifi177, reset reason: Turned on by main processor
After a few seconds to a minute, it resets, with the error string:
Flash size 4194304, free RAM 27088 bytes, WiFi Vcc 3.38V, host name: duetwifi177, reset reason: Exception
As to connecting to it to configure it, I have never gotten beyond the initial selection screen, as it reliably goes down within 10 seconds of being able to connect to the wifi server.
I have tried power cycling the Duet, removed the SD card and updated the WiFi server firmware, and updated the DuetWIFI system firmware. None have changed the behavior.
I will say that the neighborhood is very busy in the 2.4 and 5 spectrums, with over 30 different access points visible from my laptop when I have been doing this. Is this a likely cause for this behavior?
Well, It may be a moot point now, but I'll have to see what happens once it's in actual use in the printer.
I was finally able to get it to fully connect to the network by using two different tabs in the browser, one carefully prepared with the network selected and passphrase entered during the web server resets of the 4 or so prior rounds.
Once the server came up and I was able to load the page in the second window, I hit the submit button in the first and it finally gave the message that it was rebooting.I do not know what caused all the resetting, but toward the end it appeared to be induced ~5 seconds after loading the selection page.
I'm not positive that it correlates to the page load, nor near curious enough to reset it and try my luck again, barring a request for some log file only available by doing such.All that said, it looks good now, and the web interface is quick and responsive. Now to get it into operation!
I'm glad you got it working. I took a look at the code for getting the station list (I didn't write it), and there is some sloppy coding both there and in the underlying library that needs to be fixed, along with an unnecessary copying of station info that will impact on available memory when there are many stations. I'll add it to the list of things that need to be fixed in the ESP code. However, before that gets done I'll probably have added the facility to specify the SSID and pass phrase in a file on the SD card.
I'm having the same problem, but the web interface page will not load at all.
I am using the most up to date/stable versions of all firmware.This is what I get from pronterface:
SENDING:M552 S1
WiFi server starting up
DuetWiFiServer version 1.03 (ch fork)
Flash size 4194304, free RAM 32840 bytes, WiFi Vcc 3.11V, host name: duetwifi, reset reason: Turned on by main processor
WiFi server connected to access point P-WIFI, IP=10.236.85.189, signal strength=-58dBm
Flash size 4194304, free RAM 32840 bytes, WiFi Vcc 3.12V, host name: duetwifi, reset reason: Exception
DuetWiFiServer version 1.03 (ch fork)It seems like the exception happens a few seconds after requesting a connection.
Any help would be appreciated.
Matthew
I will have new beta firmware very soon, with rewritten WiFi code. I hope that will fix it. Look out for the announcement of firmware 1.19 in beta.
Thank you David for the update, I have got it to work using my iphone as a hotspot, but can not connect it to my works infrastructure (no pages load although I get server response code 200), although the I.T dept. say there are no restrictions in place, I guess they are missing something.
Occasionally I still get disconnections and board resets, here is what M122 outputs:SENDING:M122
Used output buffers: 1 of 32 (2 max)
Static ram used: 28556
Dynamic ram used: 79644
Recycled dynamic ram: 2392
Stack ram used: 3680 current, 4504 maximum
Never used ram: 15976
Last reset 00:00:12 ago, cause: power up
Last software reset code 0x0031, HFSR 0x40000000, CFSR 0x00008200, ICSR 0x0440f803, BFAR 0x447a0000, SP 0x2001fe5c
Stack: 0041a479 0041db7e 81000000 2ece0000 40279127 d758f099 bfc253a9 fffffc03 0042f7ad 004327e4 61000200 00008e4e 00000014 00000000 2000a448 00000001 0041f919 00000000
Spinning module during software reset: Network, available RAM 15652 bytes (slot 3)
Error status: 0
[ERROR] Error status: 0Free file entries: 10
SD card longest block write time: 0.0ms
MCU temperature: min 19.1, current 22.1, max 24.2
Supply voltage: min 0.4, current 0.7, max 0.9, under voltage events: 0, over voltage events: 0
Driver 0: ok
Driver 1: ok
Driver 2: ok
Driver 3: ok
Driver 4: ok
Slowest main loop (seconds): 0.002416; fastest: 0.000032
MaxReps: 0, StepErrors: 0, MaxWait: 0ms, Underruns: 0, 0
Bed compensation in use: none
Probe change coordinates:
Bed heater = 0, chamber heater = -1
Heater 1 is on, I-accum = 0.0
Segments left: 0
Movement lock held by null
http is idle in state(s) 0
telnet is idle in state(s) 0
file is idle in state(s) 0
serial is ready with "M122" in state(s) 0
aux is idle in state(s) 0
daemon is idle in state(s) 0
queue is idle in state(s) 0
Code queue is empty.
Network state is changing mode
WiFi module is trying to connect
SPI underruns 1, overruns 0
WiFi firmware version 1.19-alpha1
WiFi MAC address 5c:cf:7f:37:8b:19
WiFi Vcc 3.11, reset reason Turned on by main processor
WiFi flash size 4194304, free heap 9128
HTTP sessions: 0 of 8
FTP state 0
Telnet state 0
Wifi module is idle -
Hi Matthew,
Thanks for trying that version.
Your reset data indicates a firmware error, but I no longer have the intermediate files I need from the 1.19alpha1 build to track it down. Please can you upgrade your DuetWiFiFirmware to 1.19alpha2 and see if you still get the resets when it is connected to your iPhone. If so then post the M122 report again. See https://github.com/dc42/RepRapFirmware/blob/dev/WHATS_NEW.md for 1.19alpha2 upgrade notes.
I expect to have an update to the DuetWiFiServer code soon, and when I have released that it may be worth seeing if the Duet can connect to your works network again.
I am also having issues wit\h DuetWifi. I had an issue where the firmware got corrupted while updating firmware 1.18. The duet was locked up and couldnt even connect using USB. I used Sam BL to reinstall 1.18 but could not get the wifi running. I updated to 1.19 Alph and followed the instructions for installation. It worked. When i tried again after another print the wifi could not be connected again. This time nothing I do will allow me to connect. I can still connect over USB and the display still works
This is what i get from the diagnostics
SENDING:M122
Used output buffers: 1 of 32 (8 max)
Stack ram used: 3680 current, 4892 maximum
Never used ram: 15588
Last reset 00:01:20 ago, cause: power up
Last software reset code 0x1003, HFSR 0x00000000, CFSR 0x00000000, ICSR 0x0440f80f, BFAR 0xe000ed38, SP 0xffffffff
Spinning module during software reset: GCodes, available RAM 15876 bytes (slot 3)
Error status: 0
MCU temperature: min 36.4, current 37.9, max 39.6
Supply voltage: min 12.4, current 12.4, max 12.5, under voltage events: 0, over voltage events: 0
Driver 0: standstill
Driver 1: standstill
Driver 2: standstill
Driver 3: standstill
Driver 4: standstill
Slowest main loop (seconds): 0.004684; fastest: 0.000137
Heater 0 is on, I-accum = 0.0
Segments left: 0
Network state is running
WiFi module is idle
SPI underruns 3, overruns 0
WiFi MAC address 18:fe:34:cb:01:c9
WiFi Vcc 3.06, reset reason Turned on by main processor
FTP state 0
Telnet state 0M122
SENDING:M122
Stack ram used: 3680 current, 4988 maximum
Never used ram: 15492
Last reset 00:01:22 ago, cause: power up
Error status: 0
MCU temperature: min 36.7, current 38.4, max 39.1
Supply voltage: min 12.4, current 12.5, max 12.5, under voltage events: 0, over voltage events: 0
Slowest main loop (seconds): 0.004723; fastest: 0.000137
Segments left: 0
WiFi module is idle
SPI underruns 4, overruns 0
FTP state 0
Telnet state 0 -
Have you tried sending M552 S-1 followed by M552 S1 to reset and restart the WiFi module?
I hope to release an update to DuetWiFiServer later today.
Still getting errors and resets, using the latest release
Last software reset code 0x1001, HFSR 0x00000000, CFSR 0x00000000, ICSR 0x0440f80f, BFAR 0xe000ed38, SP 0xffffffff
Spinning module during software reset: Network, available RAM 15956 bytes (slot 0)HTTP/1.1 500 overflow
Connection: closeI seem to be getting a step closer, at least I can request and get served html404.html
Thanks. Please let me know if you get any resets with a software reset code other than 0x1001, like the one you reported before.
Last reset 00:00:22 ago, cause: reset button or watchdog
Last software reset code 0x0031, HFSR 0x40000000, CFSR 0x00008200, ICSR 0x0440f803, BFAR 0x0a9d0a9c, SP 0x2001fe5c
Stack: 0041ae99 0041e5b2 81000000 00000000 ffffffe9 2000a540 00000001 00000001 00000002 2001fee8 0041af53 0041af9a 21000000 00000000 ffffffe9 2000b868 00000001 00000000
Spinning module during software reset: Network, available RAM 15652 bytes (slot 2)Webserver: rejecting message with: not found
What is not found? Am I missing a SD card file? Everything has been extracted to /www
Also WiFi firmware version reports 1.19-alpha1 not alpha2 but has been upgraded.
Thank you for your continued effort.
Thanks for your report. That gives me a very good idea of what went wrong.
The firmware for the WiFi module (DuetWiFiServer) is still at 1.19alpha1, it's only DuetWiFiFirmware that is at 1.19alpha2.
Firmware Name: RepRapFirmware for Duet WiFi
Firmware Electronics: Duet WiFi 1.0
Firmware Version: 1.19alpha3 (2017-05-09)
WiFi Server Version: 1.19-alpha1
Web Interface Version: 1.16Using an iphone as a hotspot I can connect for a few seconds via DWC, then I get: An AJAX error has been reported….....
08:29 22/05/2017
Last software reset code 0x1001, HFSR 0x00000000, CFSR 0x00000000, ICSR 0x0043380f, BFAR 0xe000ed38, SP 0xffffffff
Spinning module during software reset: Network, available RAM 8868 bytes (slot 4)08:31 22/05/2017
Stack: 0041ae99 0041e5b2 81000000 80000000 bfd802a3 e974b355 3facf963 fffffc02 00430121 004334aa 81008a00 000002f3 09c0b000 0042fed2 01000000 2000a540 00000001 00000000
Spinning module during software reset: Network, available RAM 15652 bytes (slot 0)
Error status: 008:36 22/05/2017
Last software reset code 0x1031, HFSR 0x40000000, CFSR 0x00008200, ICSR 0x0440f803, BFAR 0x505c0f91, SP 0x2001fe44
Stack: 0041a227 004350a0 21000000 400c0000 200065c8 00000000 0041a343 0041a348 81000000 0000000b 00000000 00000000 ffffffe9 2565c18a 3e05f204 00000000 00430030 000002e2
Spinning module during software reset: Network, available RAM 15652 bytes (slot 1) -
Please switch to 1.19beta1 and try again. See https://www.duet3d.com/forum/thread.php?id=1620 for upgrade instructions.
