    Pressure in advance and retraction
    • peirofundefined
      peirof
      I am having some problems with PETG and retractions, when I try to Print some objects in the same bed... In first layers I have clogs... However, if I print one or two copies of the same model, I do print it...
      I think that can be an issue of retractions... If I fine tuning pressure in advance can quit or almost reduce retractions?
        Yes pressure advance will usually allow for less retraction distance and if you don't reduce the retraction distance when using pressure advance, you can get clogs on retraction as it pulls back too far.
        • peirofundefined
          peirof
          some idea where start?
          Can someone post your config?
          In this moment have this:
          Short Bowden, aprox 20 cms.
          Pressure in advance: M572 D0 S0.1
          Settings for
          PLA
          • Retraction distance? - 4 mm
          • Retraction speed? - 40 mm/s
          ABS
          PETG
          When i try to print various objects, i have clogs in first 20 layers, aprox
          • jens55undefined
            jens55
            try retraction of 1.5 mm and speed of 30 mm/sec
            peirofundefined 1 Reply Last reply Reply Quote 0
            • peirofundefined
              peirof @jens55
              @jens55 thanks, layer try
