    Have our slicers been wrong this whole time?
    3.2k
    • botundefined
      bot @arhi
      @arhi I caught that after I replied πŸ˜›
      *not actually a robot
      • botundefined
        bot @theruttmeister
        @theruttmeister said in Have our slicers been wrong this whole time?:
        @bot
        The one on the left.
        Given identical surface roughness (which you have), measuring on the line you drew, the one on the right would be oversize, one on the left would be the exact dimension.
        Now, if you wanted the part oversize because you planned on finishing the surface to reduce the surface roughness, then that's a different thing. But the one on the left is closer to final dimensions of the part.
        Slicing engines are trying to reproduce the CAD model, if you are going to do additional finishing, you have to plan for that.
        That's not quite how it works. You don't get to choose the precise spot you take a measurement. You have to assume that the measuring tool will as likely fall in a void as it will land on that tiny bump that defines the external nominal profile.
        theruttmeisterundefined 1 Reply Last reply Reply Quote 0
        • arhiundefined
          arhi @theruttmeister
          I'm very much familiar with jetting technology...
          I'm just a user there, outside of my aria of interest
          4 Axis FDM is able to deposit finely controlled, discrete volumes of polymer...
          With more control than most jetting tech as it is able to vary the velocity of its deposition (Jetting typically cannot). In fact, the ability to deposit truly continuous beads of polymer is a huge advantage of FDM vs Jetting.
          I disagree but hey, we can't agree on everything :D.
          Why I disagree
          1. when you start extruding there is an unknown time delay before plastic start exiting. This time delay depends on many factors and is mostly ignored by the slicers. Effects of this problem are "hidden" by "prime nozzle" parameter, pressure advance...
          2. when you stop extruding there is and unknown time delay before plastic stop extruding and to add to that plastic does not exit at same speed during this "stop" time. Effects of this problem are "hidden" by "retraction", pressure advance, coasting, wiping...
          So IMHO we cannot deposit "finely controlled, discrete volumes of polymer", we deposit something "close to it" and then hide the effects of the error.
          Or do you mean droplets?
          No, not really, I mean, some way of having discrete deposition possibility. No clue how, if I had an idea I'd come out with it :). Looking at this weird view of the printer I mentioned
          maybe some rotating drum with holes "accepting" a known discrete volume of molten plastic sending it further down the path πŸ˜„ ...
          • theruttmeisterundefined
            theruttmeister @bot
            You don't measure with a device of zero width. Any measurement is of the highest points that are contacting your tool.
            Hence surface roughness being relevant.
            The line you drew is exactly how you would measure those surfaces.
            Isolate, substitute, verify.
            • botundefined
              bot @theruttmeister
              Ah, I see you like to throw out accuracy when measuring, too. A caliper is not always the right tool for the job.
              It seems we will have to agree to disagree here, and maybe get back to the intended topic at hand.
              • arhiundefined
                arhi
                just to be clear, I have no strong position on any of these, just throwing ideas and opinions out there... English is not really in my language (not even close) and I'm already told I tend to sound like I'm fighting or holding a hard position on something while in reality I just said what I think but I'm very much willing to change my stand confronted by more logical stand I did not think about myself or faced with facts that change my stand πŸ™‚
                • arhiundefined
                  arhi @bot
                  @bot said in Have our slicers been wrong this whole time?:
                  Measuring is a science in itself πŸ™‚
                  You have to define what exactly you want to measure.
                  If we are talking about holes in 3d printing objects I tend to look at what's "sticking out farthest" and don't care much about other stuff as if "what's sticking out farthest" is wrong I need to drill the object (as I do in most cases) .... other use cases will require different measurement .. I doubt the'res "one solution for all use cases" here
                    theruttmeister @arhi
                    @arhi said in Have our slicers been wrong this whole time?:
                    Why I disagree
                    What makes you think inkjet doesn't have similar problems? You ever put a 2D print under a microscope and measured the size of each dot?
                    Besides, this is like complaining that bicycles don't protect you from the rain, but horses eat grass.
                    These two things are not in any way related.
                    I'm familiar. And its dealing with room temperature materials, which is a totally different world.
                    To replicate the control you want would require a valve in the nozzle. That would allow you to maintain constant pressure in the melt chamber and instantly stop extruding.
                    Crude versions were tested in very early reprap... They did not work well.
                    Turns out that a valve that can withstand a few thousand PSI at 200-300C is difficult and expensive, especially if you want it to be small.
                    Retracting the filament is much easier and produces satisfactory results.
                    I don't see much of a market for a $5000 printhead that produces slightly better prints.
                    arhiundefined 1 Reply Last reply Reply Quote 1
                      What he said.
                      • arhiundefined
                        I know about those "crute versions", I made one myself back in the day... didn't work well, but with new technologies and materials... who knows.. the piano wire + solenoid shown to be ^%#$^# but maybe some new piezo controled nozzle stuff ... they supposedly made a CPAP device that uses a pump made out of lot of small piezo elements, who's to say something like that can't be used for plastic πŸ™‚
                        It's a huge question how "slightly" better it would be. That precise head could hit the SLS accuracy easily if paird with good mechanics, the problem I think is that with so high price you just go SLS way, you get strong parts, higher precision, way less issues with overhang and everything faster
                          @arhi
                          Inkjet works because its not under pressure, the ink is of very low viscosity. The piezo squeezes the ink out of a long thin tube. Capillary effect and all that. All at room temp (or less than 100C for wax).
                          FDM is using high pressure (hundreds to thousands of PSI) due to the viscosity of the materials, through a much bigger nozzle. At temps from 200 to 450C. They are fundamentally different processes.
                          A pump for moving air using piezo elements is interesting, but not in any way applicable.
                          The challenge is that making a really tiny valve that is durable and can maintain a seal is going to require lots of engineering.
                          A brass nozzle and steel wire/needle valve, is going to have worn out brass really fast, for example.
                          A tungsten carbide nozzle, with a internal tungsten carbide needle/piston... that would get you a good and durable seal at one end. Now you just need to seal the other end... and figure out how you are going to get the filament into the melt chamber. Oh, and how to actuate that piston.
                          Of course you could also try and build something that is spring-loaded, but that's a whole other challenge.
                          And I don't think it is a huge question of how much better it will be. Its not going to change the fundamentals of how FDM works. Its just going to make cleaner starts and stops... the returns are really marginal.
                          And you go to Multi-jet Fusion long before SLS, its much cheaper.
                          And SLS isn't blanket better, it still has lots of design constraints, plus much more problematic overheads.
                          Part shrinkage, part warping, minimum wall thickness, material choice (and mono-material only), surface finish, object density. These are all very different from FDM.
                          And SLS is actually often slower when you actually allow for complete cycle time. Given that you need to pre-heat all your powder, then cool the build chamber very slowly.
                          • arhiundefined
                            Inkjet works ...
                            I just mentioned what does discrete deposit.. will this be or not possible for FDM, I'm pretty sure those technologies will not but just like we moved from needles to jets who knows where will we move "tomorrow" from existing solutions for FDM. maybe nowhere, maybe... with enough ppl working on solving the problem lot of things are possible πŸ™‚
                            This is where we disagree, I believe that "how much will it change" really depends on the solution.
                            depends, if you do full chamber at once, which is rather easy with SLS, speed / volume is much higher than FDM .. if you do small parts, yes, then fdm is faster
                            • botundefined
                              bot
                              The discussion seems to have wandered a bit here. I don’t know why we think we have to do anything special to get resolution or precision or discrete extrusion commands. We already have it.
                              IMO, the FDM process can be scaled up or down however much someone wants β€” there is nothing about the fdm process that fundamentally precludes high precision. We can have tiny nozzles and use a stepper to push it out and get great results. If I had a nozzle that was 0.08 mm orifice diameter, and an extruder that had about 10,000 steps/mm at 16x ms, I wager that I could print 0.08 mm extrusion widths at 20 micron layer height.
                              The problem becomes making the nozzle at this point. And also achieving the resolution on the E axis.
                              arhiundefined theruttmeisterundefined 2 Replies Last reply Reply Quote 0
                              • arhiundefined
                                arhi @bot
                                That tends to happen even with much more focused discussion πŸ˜„
                                I would take you on that as with ABS/PLA/PP available today pushing plastic trough .1mm orifice is not working. It clogs non-stop from particulate from the filament itself (filament is cleaned and even goes trough static electricity removal chamber). I doubt you can have ABS/PLA/PP that's clean enough to run consistently trough .1mm. It has bin tried by me and few others many times before. .2mm is kinda best you can do with plastic that's available, that's why noone really pushes smaller nozzles than .2mm, and even .2mm is too much hassle, .25 is the smalles I go myself these days.
                                  theruttmeister @bot
                                  There are major caveats to that... (gigantic ones).
                                  Making the nozzle isn't the problem... I can get you a ceramic nozzle with a 0.07mm orifice, probably even one from tungsten. Might be expensive. MOQ might suck too.
                                  The problem is that required extrusion force increases exponentially as the orifice size decreases. There is a point where you can't actually generate enough pressure with the filament. Or even that the thermal expansion of the filament in the melt chamber is actually faster than the deposition rate.
                                  There is also a point when you get small enough the flow boundary on either side of the nozzle meets, then you just can't push material at all... Or maybe you get small enough that your flow rate of material through the nozzle becomes supersonic, then it just stops.
                                  Also you are not talking about high precision, you are talking about really high resolution (which by necessity requires high precision, but is not the same thing)...
                                  You are going to also want to switch to ball-screws if you are not using them already. Probably harmonic gearbox for the extruder (the amount of lash and resulting delay on retraction wants to be minimised), that would get you to the right region for E resolution.
                                  Don't get me wrong, I'd love to see just how far FDM can be pushed to produce really high resolution prints... I'm just not convinced there's a market for SLA resolution but with print times measured in days.
                                  I mean, there is a market. But its for about 10 machines. And it needs to be printing in nonsense materials.
                                  • botundefined
                                    bot @theruttmeister
                                    At what point do you think this pursuit of resolution or precision or accuracy or whatever term you want to use, is impossible? I'm using, like I said before, a 0.15 mm nozzle with 0.04 mm layer heights. How much lower do you want to go exactly? I'm pretty sure I could match polyjet resolution with the right system. The actual problem/limitation is print speed. FDM is simply inherently slower than most other processes. It's not inherently less-capable of producing higly detailed, high-resolution, accurate prints with great precision. πŸ™‚
                                      theruttmeister @bot
                                      Me? I'm happy with 0.4mm nozzle, 0.2mm layers. That means I can get parts in hours, not days. I have work I need to get done.
                                      Impossible? Sounds like @arhi thinks 0.1mm nozzles are functionally impossible. But who knows.
                                      It is inherently less capable. The rheology of molten polymers just is more limiting than that of low viscosity ink through an inkjet.
                                      That doesn't mean it can't produce high resolution. Just that the trade-offs to get there make it impractical for most people.
                                      If you want to go chasing 15 micron layers, with 43 micron features... good luck, I'm sure it will be fun. πŸ™‚
                                      If I was building a high rez machine for printing nonsense polymers, I'd probably be happy with 0.1mm layers and 0.25mm features. I'm down with printing tiny expensive things that cost far too much money, but I want it to take less than a week.
                                      botundefined arhiundefined 2 Replies Last reply Reply Quote 0
                                      • botundefined
                                        bot @theruttmeister
                                        I'd appreciate it if we could return to the topic at hand, if all you want to do is badmouth other people's ideas.
                                        • arhiundefined
                                          They are functionally impossible if you ask me! They clog non stop, you have to use 40:1 gearing in order to push filament trough and you need to print very hot ... I never managed to print a benchy with .1mm nozzle (smallest nozzle I managed to finish a print is 0.16mm and it's a World easier than 0.10mm) ... and this was with .1mm nozzle with exit channel shorter than .1mm!!
                                          @bot sorry for the off-topic, I'll try to stay on the topic
                                          • botundefined
                                            bot
                                            I suppose I can accept 0.1 mm nozzle orifice as a reasonable lower bound for potential good results. Much like theruttmeister, I have no desire to go much lower than I am already. I do prefer to have the capability to do very high resolution prints, as well as low resolution prints, in order to expand the range of objects I can print. Being capable of printing at the widths and heights I am doesn't limit my ability to print 0.3 mm thick layers out of a 0.4 mm nozzle at 100 mm/s.
                                            BTW, here is why the Slic3r flow math is less accurate. It puts a bias towards parts being too small, when you consider the volume. The following pictures show exactly theoretically perfect extrusions as dictated by the Slic3r model. Variation plus or minus due to filament diameter fluctuation is inevitable. Mathematically, Slic3r produces undersized parts with more probability.
                                            0.4 mm requested extrusion width, 0.2 mm layer height.
                                            Like I've said before: don't sand your models, and make sure they don't see much abrasion in use! You must not be producing functional parts if you don't care about the surface being made up of mostly void space.
