    Have our slicers been wrong this whole time?
    3.2k
    • arhiundefined
      arhi @bot
      @bot said in Have our slicers been wrong this whole time?:
      On top of that, stock slic3r simplifies toolpaths excessively. Accuracy thrown out the window again.
      There was always a tradeoff there... The first slicers I used were something dr. Adrian made and skeinforge. Both worked by creating a slice of the object and generating a bitmap of that slice at some resolution, then they would vectorize this bitmap and generate g-code from those vectors. It's a super slow process but worked rather good with non manifold parts and parts with different errors. First slicer that actually generated proper vectors by intersecting a plane and the stl was netfabb and what happened is that slicing became 1000+ times faster but they had issue with non-perfect objects (luckily netfabb is also awesome to fix the STL so that was not a problem) and with "too precise" objects as by deciding on the resolution of the bitmap skeinforge could define shortest move, netfabb had to implement additional "optimizer" on top of that to now "fix all the short moves"... same issue was later on with all the other slicers doing the similar thing, IIRC s3d solved this partially with 3.0 and finally with 3.1, before 3.0 they would generate a G1 for every nanometer you had in your STL... slic3r had the optimization from start IIRC, no clue how it's implemented... but you can't go around that, you can just make it configurable so user can decide how this simplification works...
      What's bigger issue and huge difference between slicers is the optimization of generated G-code. Last time I compared S3D and Cura, S3D code was way better, more optimized, cura generated code was jumping all over the place... dunno if this changed, have not checked cura for a while.
      • arhiundefined
        arhi @bot
        S3D is by far the worst slicer I've analysed in terms of extrusion rate consistency.
        They also simplify their toolpaths now, too.
        Try to get version before 3.0 😄 and test it out, 3.0 is when they introduced simplification of toolpaths 🙂
        • arhiundefined
          arhi @bot
          I would actually love if a slicer would ASK me if I want the left or the right one 😄 ... and I know that in 90% cases I would want the left one for inside of the object (holes) and right one for the outside of the object 🙂
          • botundefined
            bot @arhi
            @arhi I remember very well. I used to take full advantage of the non-excessively simplified toolpaths!
            @arhi said in Have our slicers been wrong this whole time?:
            Now that's truly a good idea.
            *not actually a robot
            • theruttmeisterundefined
              theruttmeister @arhi
              @theruttmeister said in Have our slicers been wrong this whole time?:
              Explain what you mean by 'discrete extrusion'?
              Look at the ink-jet printer, it is expelling discrete values of ink. If you look at the "bonder" printers they expel the discrete values of the bonding material (or activator, water .. irrelevant). Lool at the beeswax printers made with Epson print heads, they build 3D object out of discrete drops of vax.
              I'm very much familiar with jetting technology...
              Jetting is able to deposit finer volumes... but no existing tech is capable of functioning at 200C+ as is required for thermoplastics, let alone deal with the far far higher viscosity of molten thermoplastics.
              4 Axis FDM is able to deposit finely controlled, discrete volumes of polymer...
              With more control than most jetting tech as it is able to vary the velocity of its deposition (Jetting typically cannot). In fact, the ability to deposit truly continuous beads of polymer is a huge advantage of FDM vs Jetting.
              Or do you mean droplets? Because droplet thermoplastic printing, well... both not currently practical and not actually desirable (due to its impacts on mechanical strength). Oh and droplet based means 100% infill 100% of the time, and support material for even 1 degree of overhang.
              I mean if you can figure out how to build a head with 42,000 nozzles that can jet out PLA, woo hoo!
              But HP went with MJF for a reason.
              Isolate, substitute, verify.
              • arhiundefined
                arhi @bot
                there might be a way to control how much they are simplified ... but I gave up on s3d so don't remember if there's a "precision" settings there.
                with IM this is more than enough for me
                • botundefined
                  bot @arhi
                  @arhi
                  Yes. X/Y compensation for the print achieves the same thing, while allowing the flow and width of the extrusions to remain as specified by the user. PrusaSlicer even has this feature! So the flow math is redundant.
                  I played around with the IM simplification for a tiny bit -- it seems they have a hard minimum that is coarser than I'd prefer.
                  • arhiundefined
                    arhi @bot
                    @arhi
                    I was more thinking about min seg leng. and merge nearby lines wrt optimization 😄 .. but added compensation and small features as those three groups together solve most of my accuracy problems
                    • botundefined
                      bot @arhi
                      @arhi I caught that after I replied 😛
                      • botundefined
                        bot @theruttmeister
                        @bot
                        The one on the left.
                        Given identical surface roughness (which you have), measuring on the line you drew, the one on the right would be oversize, one on the left would be the exact dimension.
                        Now, if you wanted the part oversize because you planned on finishing the surface to reduce the surface roughness, then that's a different thing. But the one on the left is closer to final dimensions of the part.
                        Slicing engines are trying to reproduce the CAD model, if you are going to do additional finishing, you have to plan for that.
                        That's not quite how it works. You don't get to choose the precise spot you take a measurement. You have to assume that the measuring tool will as likely fall in a void as it will land on that tiny bump that defines the external nominal profile.
                        theruttmeisterundefined 1 Reply Last reply Reply Quote 0
                        • arhiundefined
                          arhi @theruttmeister
                          I'm just a user there, outside of my aria of interest
                          I disagree but hey, we can't agree on everything :D.
                          Why I disagree
                          1. when you start extruding there is an unknown time delay before plastic start exiting. This time delay depends on many factors and is mostly ignored by the slicers. Effects of this problem are "hidden" by "prime nozzle" parameter, pressure advance...
                          2. when you stop extruding there is and unknown time delay before plastic stop extruding and to add to that plastic does not exit at same speed during this "stop" time. Effects of this problem are "hidden" by "retraction", pressure advance, coasting, wiping...
                          So IMHO we cannot deposit "finely controlled, discrete volumes of polymer", we deposit something "close to it" and then hide the effects of the error.
                          No, not really, I mean, some way of having discrete deposition possibility. No clue how, if I had an idea I'd come out with it :). Looking at this weird view of the printer I mentioned
                          maybe some rotating drum with holes "accepting" a known discrete volume of molten plastic sending it further down the path 😄 ...
                            theruttmeister @bot
                            You don't measure with a device of zero width. Any measurement is of the highest points that are contacting your tool.
                            Hence surface roughness being relevant.
                            The line you drew is exactly how you would measure those surfaces.
                            • botundefined
                              bot @theruttmeister
                              Ah, I see you like to throw out accuracy when measuring, too. A caliper is not always the right tool for the job.
                              It seems we will have to agree to disagree here, and maybe get back to the intended topic at hand.
                              • arhiundefined
                                arhi
                                just to be clear, I have no strong position on any of these, just throwing ideas and opinions out there... English is not really in my language (not even close) and I'm already told I tend to sound like I'm fighting or holding a hard position on something while in reality I just said what I think but I'm very much willing to change my stand confronted by more logical stand I did not think about myself or faced with facts that change my stand 🙂
                                • arhiundefined
                                  arhi @bot
                                  Measuring is a science in itself 🙂
                                  You have to define what exactly you want to measure.
                                  If we are talking about holes in 3d printing objects I tend to look at what's "sticking out farthest" and don't care much about other stuff as if "what's sticking out farthest" is wrong I need to drill the object (as I do in most cases) .... other use cases will require different measurement .. I doubt the'res "one solution for all use cases" here
                                    Why I disagree
                                    What makes you think inkjet doesn't have similar problems? You ever put a 2D print under a microscope and measured the size of each dot?
                                    Besides, this is like complaining that bicycles don't protect you from the rain, but horses eat grass.
                                    These two things are not in any way related.
                                    I'm familiar. And its dealing with room temperature materials, which is a totally different world.
                                    To replicate the control you want would require a valve in the nozzle. That would allow you to maintain constant pressure in the melt chamber and instantly stop extruding.
                                    Crude versions were tested in very early reprap... They did not work well.
                                    Turns out that a valve that can withstand a few thousand PSI at 200-300C is difficult and expensive, especially if you want it to be small.
                                    Retracting the filament is much easier and produces satisfactory results.
                                    I don't see much of a market for a $5000 printhead that produces slightly better prints.
                                    arhiundefined 1 Reply Last reply Reply Quote 1
                                      What he said.
                                      • arhiundefined
                                        I know about those "crute versions", I made one myself back in the day... didn't work well, but with new technologies and materials... who knows.. the piano wire + solenoid shown to be ^%#$^# but maybe some new piezo controled nozzle stuff ... they supposedly made a CPAP device that uses a pump made out of lot of small piezo elements, who's to say something like that can't be used for plastic 🙂
                                        It's a huge question how "slightly" better it would be. That precise head could hit the SLS accuracy easily if paird with good mechanics, the problem I think is that with so high price you just go SLS way, you get strong parts, higher precision, way less issues with overhang and everything faster
                                          @arhi
                                          Inkjet works because its not under pressure, the ink is of very low viscosity. The piezo squeezes the ink out of a long thin tube. Capillary effect and all that. All at room temp (or less than 100C for wax).
                                          FDM is using high pressure (hundreds to thousands of PSI) due to the viscosity of the materials, through a much bigger nozzle. At temps from 200 to 450C. They are fundamentally different processes.
                                          A pump for moving air using piezo elements is interesting, but not in any way applicable.
                                          The challenge is that making a really tiny valve that is durable and can maintain a seal is going to require lots of engineering.
                                          A brass nozzle and steel wire/needle valve, is going to have worn out brass really fast, for example.
                                          A tungsten carbide nozzle, with a internal tungsten carbide needle/piston... that would get you a good and durable seal at one end. Now you just need to seal the other end... and figure out how you are going to get the filament into the melt chamber. Oh, and how to actuate that piston.
                                          Of course you could also try and build something that is spring-loaded, but that's a whole other challenge.
                                          And I don't think it is a huge question of how much better it will be. Its not going to change the fundamentals of how FDM works. Its just going to make cleaner starts and stops... the returns are really marginal.
                                          And you go to Multi-jet Fusion long before SLS, its much cheaper.
                                          And SLS isn't blanket better, it still has lots of design constraints, plus much more problematic overheads.
                                          Part shrinkage, part warping, minimum wall thickness, material choice (and mono-material only), surface finish, object density. These are all very different from FDM.
                                          And SLS is actually often slower when you actually allow for complete cycle time. Given that you need to pre-heat all your powder, then cool the build chamber very slowly.
                                          • arhiundefined
                                            Inkjet works ...
                                            I just mentioned what does discrete deposit.. will this be or not possible for FDM, I'm pretty sure those technologies will not but just like we moved from needles to jets who knows where will we move "tomorrow" from existing solutions for FDM. maybe nowhere, maybe... with enough ppl working on solving the problem lot of things are possible 🙂
                                            This is where we disagree, I believe that "how much will it change" really depends on the solution.
                                            depends, if you do full chamber at once, which is rather easy with SLS, speed / volume is much higher than FDM .. if you do small parts, yes, then fdm is faster
