    Jumper? Where are you?
    Firmware installation
    395
    • duttiundefined
      dutti
      Hey,
      which Jumper do I have to replace for having 24v instead of the board-made 12v?
      For using 24v fans.
      I´m pretty new in building 3d Printers.
      So it would be lovely to get a short explanation.
      Thanks
      duttiundefined 1 Reply Last reply Reply Quote 0
      • aidarundefined
        aidar
        First of all, what board are you talking about?
        • duttiundefined
          dutti @aidar
          @aidar OH sry
          Duet3 6hc and duet3 3hc expansion board
          • duttiundefined
            dutti @dutti
            Are these the jumpers?
            • aidarundefined
              aidar
              Those two you marked on picture are not jumpers, they are fuses. To have 24v fans working, your PSU must be 24v, then you select jumpers witch ones are above outputs 4-6 and/or 7-9 to connect V-fused and VOUTLC1. Assuming your fans are connected to out 4-9 somewhere
              • duttiundefined
                dutti
                My PSU is 24v.
                And the other things I´ve ready to work. I just don´t know where are the jumpers ahaha
                maybe a bit stupid.
                Can you just tell me where are the jumpers and what I have to do with it to have 24v?
                Everything else is working! 🙂
                thanks
                • whosrdaddyundefined
                  whosrdaddy
                  It's right there, I marked the jumper location for you, you must set the jumper to the left position
                  • duttiundefined
                    dutti @whosrdaddy
                    @whosrdaddy
                    ah ok nice. I understood!
                    So just sober the 2 pins together or is there a pin which I can buy?
                    Thanks
                    problem solved
                      The jumpers should already be fitted on those pins, but perhaps in the wrong place. If not, you should have received some jumpers that fit over the pins, possibly in the connector pack.
                      • duttiundefined
                        dutti @dc42
                        yes.... so easy.
                        Thanks for the support. next machine with duet! sure
                        Problem solved
