    BL Touch Self Test Speratic
    2.1k
    • Edumaundefined
      Eduma
      I'll give their manual another read. I thought that set screw just adjusted sensitivity.
      It still would be nice to have positive feedback on the extend with it being so critical for homing.
      • fcwiltundefined
        fcwilt
        I mentioned the grub screw because that is the only adjustment that you can make - it may or may not help but what else can you do.
        Did you add an "Alarm Release" command to your config.g file?
          It could be a loose wire connection or failing probe. Having a spare probe to test against isn't a bad idea.
          • Edumaundefined
            Eduma
            I replaced the BL touch unit and I still this. I've also seen this on separate printers. And I've quadrupedal checked the wiring. If i power cycle 2-3 times the self test will run and everything works fine. If I then power cycle again the unit will not do anything and no commands will work. If then disconnect and reconnect the two power pins the self test will perform.
            Looking at the BLT timing diagram I see that there is a minimum 100ms delay before setting PWM so an internal power check can be run. I'm running using a 24 V power supply for the duet and a seperate 5V power supply for the duet logic. Is it possible that there is some power delay on the 24V or 5V side of the board which is cutting into that 100ms wait time.
            • Edumaundefined
              Eduma
              I disconnected the PWM cables and powered the BL touch direct from my 5V power supply. I still see the same results of the self test only occasionally being performed on power up. Looks like it is an issue on the power side.
              • I_Jediundefined
                I_Jedi
                Did this ever get sorted out? I am having issues with my BLTouch not deploying off my Duet3/Toolboard setup.
                My BLTouch clone self tested fine, updated to a Genuine BLTouch v3.1 and now no self test...
                Edumaundefined 1 Reply Last reply Reply Quote 0
                • Edumaundefined
                  Eduma @I_Jedi
                  @I_Jedi
                  I found that the 5V signal to the BL touch was not instance on, but instead "slowly" ramping up to 5V. The BL touch was not seeing 5V fast enough and going in to error. I added a time relay to create a slight delay before powering the bl touch and it remedied my situation.
                  I_Jediundefined 1 Reply Last reply Reply Quote 1
                  • I_Jediundefined
                    I_Jedi @Eduma
                    @Eduma Thanks - a time relay is not realistic on the Toolboard, so I'll just have to run with it 🙂 Appreciate you sharing your solution though!
                    • fcwiltundefined
                      fcwilt @I_Jedi
                      @I_Jedi said in BL Touch Self Test Speratic:
                      There is a servo position you can send to the BLTouch to force the self-test.
                      I_Jediundefined 1 Reply Last reply Reply Quote 0
                      • I_Jediundefined
                        I_Jedi @fcwilt
                        @fcwilt Thank you... the question at hand is should the BLTouch automatically do an unprompted self test as soon as it has power. Several of us are having an issues with the v3.1 on the Toolboard. There is a suspicision that it is not getting sufficent 5V immediately during boot up to run test. So fallback appears to force a M280 P0 S120 in the startup gCode
                        oozeBotundefined 1 Reply Last reply Reply Quote 0
                        • oozeBotundefined
                          oozeBot @I_Jedi
                          Well put. I have confirmed the same behavior with the toolboard.
                          • oozeBotundefined
                            oozeBot
                            I am also still investigating why the BL Touch goes into an alarm state (blinks red) so often when connected to the toolboard even though everything appears to work fine and it responds to all commands..
                            • I_Jediundefined
                              I_Jedi @oozeBot
                              @oozeBot I am not quite that far... still finishing first time start up... That is quite frustrating. I hope we get someone from Duet to let us know what to try/look for/patch firmware...
                              • fcwiltundefined
                                fcwilt
                                I would imagine the probe is not seeing the power conditions that it expects to see on power up and is behaving oddly.
                                I would use the "reset" and/or "self test" commands as needed.
                                oozeBotundefined Edumaundefined 2 Replies Last reply Reply Quote 0
                                • oozeBotundefined
                                  oozeBot @fcwilt
                                  @fcwilt said in BL Touch Self Test Speratic:
                                  This does not appear to be a reliable fix. In fact, M280 P0 S160 doesn't even clear the red flashing state most of the time. I'm ignoring it for the moment but really want Duet to weigh in..
                                  fcwiltundefined droftartsundefined 2 Replies Last reply Reply Quote 0
                                  • fcwiltundefined
                                    fcwilt @oozeBot
                                    @oozeBot
                                    Is this a clone or the real thing?
                                    • oozeBotundefined
                                      oozeBot @fcwilt
                                      @fcwilt the real thing - v3.1. In fact, I purchased two more this past week and both are exhibiting the same behavior when connected to the toolboard.
                                      • fcwiltundefined
                                        fcwilt @oozeBot
                                        @oozeBot said in BL Touch Self Test Speratic:
                                        Sounds like some compatibility issue between the toolboard and the BL.
                                        Now this doesn't address the problem BUT I've recently replaced my BLTouch v3 units with 12 mm inductive sensors. They take a little bit more space but the results are better than I ever got with the BL units. And they don't click.
                                          droftarts administrators @oozeBot
                                          @oozeBot @I_Jedi
                                          @dc42 runs a BLTouch on a toolboard in his setup, and as far as I know hasn't had these problems. How are your electronics set up? Is the Duet powering a RPi, with peripherals (eg screen)? Any other boards or sources of power drain/interruption on the 5V power? Can you put a scope on the 5V at the tool board, and see if the voltage is being pulled down?
                                          @dc42 also suggests: "It would be helpful if some one could test whether putting additional capacitance e.g. 100uF between +5V and GND solves it."
                                          • oozeBotundefined
                                            oozeBot
                                            Here is a picture of my electronics.. using a350w Meanwell power supply, Duet 3, RPI4, tool distribution board, and the toolboard is mounted to the tool head.
                                            Unfortunately, I don't have access to a scope, nor do I have any 100uf capacitors, but can order some if there is a strong desire to learn if this corrects the issue.
