    DCS Not starting (Could not connect to Duet)
    1.4k
    • bcrazycramerundefined
      bcrazycramer
      pi@duet3:~$ lsusb
      Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
      Bus 001 Device 002: ID 2109:3431 VIA Labs, Inc. Hub
      Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
      pi@duet3:~$
      Can I have both the USB plugged in from the Duet to the PI and Duet VIN power at the same time?
        A Former User @bcrazycramer
        @bcrazycramer said in DCS Not starting (Could not connect to Duet):
        if the ribbon cable is connected then adding the usb cable isn't going to make any difference, but you can also do it without Vin if it feels safer.
          bcrazycramer
          I found another usb cable:
          pi@duet3:~$ lsusb
          Bus 001 Device 003: ID 1d50:60ee OpenMoko, Inc.
          pi@duet3:~$
          Trying it again.
          Erase Flash
          SAM-BA operation failed
            this was the duet, so better cable, presumably that changed to something like Bus 001 Device 008: ID 03eb:6124 Atmel Corp. at91sam SAMBA bootloader
            but either there is still an usb issue or the beforementioned bug is affecting the pi as well. I'd maybe try using the manual procedure from windows and see if its the same. if still troublesome, try yet another cable.
            @bearer said in DCS Not starting (Could not connect to Duet):
            manual instuctions if you prefer: https://duet3d.dozuki.com/Wiki/Getting_Started_With_Duet_3#Section_Updating_Duet_3_main_board_firmware
              bcrazycramer
              Same thing.
              Verify:
                A Former User
                other options include SAM-BA software or atmel studio. you could also find it works with another computer and/or usb cable.
                  bcrazycramer
                  I got it to switch to COM4 and got farther:
                    A Former User
                    thats a bit fishy; sounds like the connection was broken when it was COM3 and because the software still were using COM3 it had to be assigned to COM4 when it reconnected (or do you happen to have two separate Duet3 boards connected to to different USB ports?)
                    edit: I'd focus on trying other usb cables/usb ports based on that
                      bcrazycramer
                      I will give all this a try tomorrow. Thanks!!
                        bcrazycramer
                        I'm having the same issue this morning using a Dell Laptop. The Duet 3 shows up as Com 3 in Device Manager. Bossa Program Port (Com3). When I try to verify I get the SAM-BA operation failed.
                          bcrazycramer
                          With another USB cable when I Verify I get Verify failed with page errors and byte errors.
                            A Former User
                            given the board was flashed and tested before it shipped I'm inclined to think the issue is the usb cables still. its not the first time someone have tried 3 and 4 cables before getting a new one and then succeeding.
                            alternatively trying sam-ba or atmel studio instead of bossa.
                              bcrazycramer
                              I wasn't clicking write and then verify. My bad.
                              Current status after the write and verify:
                              Aug 18 19:43:25 duet3 systemd[1]: Stopped Duet Control Server.
                              Aug 18 19:43:25 duet3 systemd[1]: Started Duet Control Server.
                              Aug 18 19:43:26 duet3 DuetControlServer[1654]: Duet Control Server v3.1.1
                              Aug 18 19:43:26 duet3 DuetControlServer[1654]: Written by Christian Hammacher for Duet3D
                              Aug 18 19:43:26 duet3 DuetControlServer[1654]: Licensed under the terms of the GNU Public License Version 3
                              Aug 18 19:43:26 duet3 DuetControlServer[1654]: [info] Settings loaded
                              Aug 18 19:43:26 duet3 DuetControlServer[1654]: [info] Environment initialized
                              Aug 18 19:43:26 duet3 DuetControlServer[1654]: [fatal] Could not connect to Duet (Board is not available (no header))
                              Aug 18 19:43:26 duet3 systemd[1]: duetcontrolserver.service: Succeeded.
                              Aug 18 19:43:32 duet3 systemd[1]: duetcontrolserver.service: Service RestartSec=5s expired, scheduling restart.
                              Aug 18 19:43:32 duet3 systemd[1]: duetcontrolserver.service: Scheduled restart job, restart counter is at 51.
                              Aug 18 19:43:32 duet3 systemd[1]: Stopped Duet Control Server.
                              Aug 18 19:43:32 duet3 systemd[1]: Started Duet Control Server.
                                bcrazycramer
                                How can I get an original 26 pin to 40 pin ribbon cable for the Duet 3 to Raspberry Pi?
                                  A Former User
                                  achrn said in Spare ribbon cable??:
                                  https://shop.pimoroni.com/products/downgrade-gpio-ribbon-cable-for-pi-a-b-pi-2-pi-3-pi-4-40p-to-26p
                                  (but it's not going to affect the issue at hand)
                                    bcrazycramer
                                    Why do you say it won't help?
                                      A Former User
                                      The Pi seems to indicate the Duet is connected but not responding properly.
                                      Are you able to connect to the usb serial console and execute M115 to show which version of the firmware is running on the Duet now?
                                      bcrazycramerundefined 1 Reply Last reply Reply Quote 0
                                        bcrazycramer @A Former User
                                        So connect it up with Repetier host or something similar and issue M115?
                                          A Former User
                                          Yeah, although any serial terminal will suffice
                                            bcrazycramer
                                            Duet 3 MB6HC Firmware Version 3.1.1 Electronics: Duet 3 MB6HC V1.01 or later
