    Ender 5 plus X ripple
    • peter247undefined
      peter247
      This is across the X axis and each ripple is about 60mm apart , so I think is caused by wheels ? Is this normal amount of error ?.
      Going to order some more wheels to see if I can fix it or even thinking of fitting linear guides.
      Because it could be a case "does a falling tree make a sound if no one is there to monitor it ?"
      Ender 5 plus linear rail and hemera powered by duet 2 wifi , CR10s pro v1 with bltouch mostly stock , BLV mgn Cube slowly being built powered by duet 3 mini 5+
        does the pattern change if you use a different grid spacing?
        peter247undefined 1 Reply Last reply Reply Quote 0
        • peter247undefined
          peter247 @Phaedrux
          @Phaedrux
          That was 30mm spacing .
          if I try 60mm spacing which is each ripple I get a flat graph .
          and 15mm spacing
