    Power Supply
    • bradhundefined
      bradh
      What is the recommended power supply of duet 2 wifi board?
        dc42 administrators @bradh
        https://duet3d.dozuki.com/Wiki/Choosing_the_power_supply
        • jens55undefined
          jens55
          A note about MeanWell power supplies - there are a lot of clones out there that look identical to the real thing from the outside. I would recommend buying from a well known supplier rather than from a Chinese (or other) Ebay / Ali Express etc seller. It is quite possible that the seller isn't even aware he is possibly selling clones.
          Buying from a supplier who's reputation depends on selling the real thing will dramatically increase your odds of getting a genuine supply.
          • bradhundefined
            bradh
            So what happens if I pick a power supply with to high of a wattage
            A Former User? peter247undefined 2 Replies Last reply Reply Quote 0
              A Former User @bradh
              @bradh said in Power Supply:
              not much, but if you're very over powered efficiency will suffer a little, but its perfectly safe.
              second the point about reliable sources. I've gotten genuine meanwell off "redsky" on Ali Express, but thanks to new customs rules DigiKey was cheaper than Ali for the last two supplies I bought, even after paying 25% VAT at checkout it was cheaper - and - next day delivery. Ali is dead, long live DigiKey 😍
              bradhundefined 1 Reply Last reply Reply Quote 0
              • peter247undefined
                peter247 @bradh
                @bradh
                So what happens if I pick a power supply with to high of a wattage ?
                Not a lot , the only disadvantage of get a bigger wattage power supply is the cost and may be size , but I would say there is more advantages getting one with a little head room.
                Ender 5 plus linear rail and hemera powered by duet 2 wifi , CR10s pro v1 with bltouch mostly stock , BLV mgn Cube slowly being built powered by duet 3 mini 5+
                • bradhundefined
                  bradh @A Former User
                  @bearer ok thanks
