    Duet 3 6hc + SBC just stops printing
    1.1k
    • Stephen6309undefined
      Stephen6309 @Phaedrux
      @Phaedrux PI0W didn't work, would not bring up DWC. The Pi0W sure is slow.
      I upgraded my Duet 2 to 3.11, no problems there.
      It'll be several days before I can try again. I'll redo the raspberry OS on the Pi4. One thing, 5ghz wifi won't connect, but 2.4ghz does. If the new install doesn't work, I'll find a long enough ethernet cable and try the direct connection.
      Stephen6309undefined 1 Reply Last reply Reply Quote 0
        Stephen6309 @Stephen6309
        Setup the pi4 with the new os, install the duet stuff. Left the pi4 hanging off the side and this morning it started to print. Currently doing the first layer. Ain't computers fun. 🙂
        Will have wait a few days to see it stays working.
          Stephen6309
          Fired up the printer today, so far printed twice with no problem.
          The OS on the pi4 must have been messed up when I was powering the pi touchscreen via the dotstar connector. The pi4 was showing the low voltage lightning on the screen. Now powering from a 5vdc Meanwell.
            Stephen6309
            Today, it's once again dying on the second leg of the skirt.
            Wrapped the ribbon cable in aluminum foil and grounded it. No change. Disconnected the pi touchscreen.
            It appears my pi4 stops talking to the duet 3. Emergency stop restores the ability to send gcode.
            Going to see if the 2020-07-20-DuetPi.img lasts longer. It's current printing. Now, will it keep working over the next few days. Ribbon cable still shielded. Didn't do the updates yet.
            Next time I'll try the direct connection.
              A Former User @Stephen6309
              @Stephen6309 said in Duet 3 6hc + SBC just stops printing:
              I have been using a Pi-3B+ on my duet 3 Unit with NO issues, maybe its a Pi-4 thing, latest is not always best...
                Can you provide M122 results after the stop?
                Or enable the monitoring I linked above?
                Stephen6309undefined 2 Replies Last reply Reply Quote 0
                  @Phaedrux I will try the debug mode again, if it does it again.
                  Running a similation of a print has worked fine.
                    @Phaedrux 2020-07-20-DuetPi.img smae thing happens the next day. Tempertures still update, can set them. Simulating print time was completed successfully.
                    Emergency stop restores movement.
                    Will try to set debug. Stop the servers, and the first command in PuTTy:
                    sudo /opt/dsf/bin/DuetControlServer -l debug
                    Stops after showing: Updated key volumes
                    VNC Connect will not connect, via IP or CXY-MSv1.local.
                    Used Advanced IP Scanner to verify IP.
                    Connected the touchscreen: desktop screen garbled.
                    The M122 is below.
                    Did the update and upgrade. That took a while. The update let me set the resolution for the touchscreen. Started print via touchscreen. Stopped again.
                    Where is the terminal in 2020-07-20-DuetPi.img?
                    Ther M122 doesn't change, except for the bytes transmitted/received.
                    m122
                    RepRapFirmware for Duet 3 MB6HC version 3.1.1 running on Duet 3 MB6HC v1.01 or later (SBC mode)
                    Board ID: 08DJM-956L2-G43S8-6J9FD-3SJ6K-TB0LG
                    Used output buffers: 1 of 40 (10 max)
                    Static ram: 154604
                    Dynamic ram: 162844 of which 44 recycled
                    Exception stack ram used: 520
                    Never used ram: 75204
                    Tasks: NETWORK(ready,1972) HEAT(blocked,1188) CanReceiv(suspended,3820) CanSender(suspended,1420) CanClock(blocked,1436) TMC(blocked,68) MAIN(running,4952) IDLE(ready,76)
                    Owned mutexes:
                    Last reset 00:44:07 ago, cause: power up
                    Last software reset at 2020-08-22 15:28, reason: User, spinning module LinuxInterface, available RAM 77008 bytes (slot 3)
                    Software reset code 0x0010 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0444a000 BFAR 0x00000000 SP 0xffffffff Task MAIN
                    Error status: 0
                    MCU temperature: min 24.4, current 36.1, max 37.5
                    Supply voltage: min 23.9, current 24.2, max 24.3, under voltage events: 0, over voltage events: 0, power good: yes
                    12V rail voltage: min 12.0, current 12.1, max 12.2, under voltage events: 0
                    Driver 0: standstill, reads 55236, writes 17 timeouts 0, SG min/max 0/253
                    Driver 1: standstill, reads 55236, writes 17 timeouts 0, SG min/max 0/956
                    Driver 2: standstill, reads 55237, writes 17 timeouts 0, SG min/max 0/1023
                    Driver 3: standstill, reads 55237, writes 17 timeouts 0, SG min/max 0/144
                    Driver 4: standstill, reads 55244, writes 11 timeouts 0, SG min/max 0/0
                    Driver 5: standstill, reads 55244, writes 11 timeouts 0, SG min/max 0/0
                    Date/time: 2020-08-23 14:11:55
                    Slowest loop: 4.95ms; fastest: 0.14ms
                    === Storage ===
                    Free file entries: 10
                    Hiccups: 0(0), FreeDm: 281, MinFreeDm: 281, MaxWait: 454488ms
                    === MainDDARing ===
                    Scheduled moves: 81, completed moves: 45, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: 3
                    === AuxDDARing ===
                    Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
                    Heater 0 is on, I-accum = 0.3
                    Heater 1 is on, I-accum = 0.3
                    Segments left: 1
                    Movement lock held by null
                    HTTP* is ready with "M122" in state(s) 0
                    Telnet is idle in state(s) 0
                    File* is doing "G1 X217.895996 Y52.673000 E4.612160" in state(s) 0
                    USB is idle in state(s) 0
                    Aux is idle in state(s) 0
                    Queue is idle in state(s) 0
                    LCD is idle in state(s) 0
                    SBC is idle in state(s) 0
                    Daemon* is idle in state(s) 0
                    Aux2 is idle in state(s) 0
                    Code queue is empty.
                    === Network ===
                    Slowest loop: 0.82ms; fastest: 0.01ms
                    HTTP sessions: 0 of 8
                    • Ethernet -
                      State: disabled
                      Error counts: 0 0 0 0 0
                      === CAN ===
                      Messages sent 10514, longest wait 0ms for type 0
                      === Linux interface ===
                      State: 0, failed transfers: 0
                      Last transfer: 17ms ago
                      RX/TX seq numbers: 18425/18426
                      SPI underruns 0, overruns 0
                      Number of disconnects: 0
                      Buffer RX/TX: 3548/984-4076
                      === Duet Control Server ===
                      Duet Control Server v3.1.1
                      File:
                      Buffered code: G1 X217.896 Y52.673 E4.61216
                      Buffered code: G1 X218.739 Y51.836 E0.06141
                      Buffered code: G1 X220.019 Y50.790 E0.08550
                      Buffered code: G1 X221.406 Y49.902 E0.08514
                      Buffered code: G1 X222.512 Y49.340 E0.06417
                      Buffered code: G1 X224.040 Y48.744 E0.08481
                      Buffered code: G1 X225.634 Y48.327 E0.08515
                      Buffered code: G1 X226.859 Y48.133 E0.06416
                      Buffered code: G1 X228.509 Y48.038 E0.08547
                      Buffered code: G1 X230.116 Y48.130 E0.08319
                      Buffered code: G1 X231.213 Y48.294 E0.05735
                      Buffered code: G1 X232.297 Y48.546 E0.05755
                      Buffered code: G1 X233.827 Y49.053 E0.08332
                      Buffered code: G1 X234.844 Y49.503 E0.05755
                      Buffered code: G1 X236.252 Y50.288 E0.08331
                      Buffered code: G1 X237.164 Y50.919 E0.05735
                      Buffered code: G1 X238.389 Y51.943 E0.08255
                      Buffered code: G1 X239.180 Y52.747 E0.05833
                      Buffered code: G1 X240.199 Y53.992 E0.08319
                      Buffered code: G1 X240.819 Y54.920 E0.05768
                      Buffered code: G1 X241.581 Y56.323 E0.08255
                      Buffered code: G1 X242.018 Y57.355 E0.05800
                      Buffered code: G1 X242.506 Y58.882 E0.08287
                      Buffered code: G1 X242.741 Y59.966 E0.05735
                      Buffered code: G1 X242.931 Y61.507 E0.08028
                      Buffered code: G1 X242.966 Y237.499 E9.09980
                      Buffered code: G1 X242.873 Y239.115 E0.08374
                      Buffered code: G1 X242.703 Y240.243 E0.05898
                      Buffered code: G1 X242.306 Y241.812 E0.08365
                      Buffered code: G1 X241.890 Y242.968 E0.06355
                      Buffered code: G1 X241.238 Y244.352 E0.07911
                      Buffered code: G1 X240.607 Y245.411 E0.06371
                      ==> 1512 bytes
                      Code buffer space: 2572
                      Full transfers per second: 1.32
                      File /opt/dsf/sd/gcodes/PETG_Spacer3mm20mmX8.gcode is selected, processing
                      Stephen6309
                      Pulled the 5vdc to Pi jumper and tried powering the pi4 from a wall wart, no change.
                        Stephen6309
                        Tried a new setup on a different card. Can't connect to the Pi4, DWC or PuTTy doesn't connect. Put other card back, it connects, but won't keep printing. does show a low voltage on the screen just before to showes DWC. Tried the Pi0W again with the 2020-07-20-DuetPi.img, didn't connect.
                        Next: direct connection, it works.
                        Looks like my Pi4 is flakey, need to get another one. Will know for sure in a few days.
                          @Stephen6309 So far, the direct mode is still working.
                            Stephen6309
                            Update: Got a new Pi4 from Adafruit with an acrylic case. Installed DuetPi OS with GUI and a fanshim. So far it works and seem to be a bit more responsive. Printed a magic fish just fine.
                            In a few days, we'll see if it stays working
                            Stephen6309undefined 1 Reply Last reply Reply Quote 1
                              It's still printing.
                                Stephen6309
                                Spoke too soon. It's doing it again. Going to ask for a new ribbon cable.
                                  Stephen6309
                                  @T3P3Tony
                                  Filastruder needs authorization for a replacement cable.
                                    dc42 administrators @Stephen6309
                                    @T3P3Tony
                                    Approved.
                                      Stephen6309
                                      Received new ribbon cable, installed last Thursday. Worked fine Thursday and Saturday. Today it's once again stopping during the skirt. Emergancy stop needed to get any axes to move. The ribblon cable wasn't the problem. Can run in direct mode with no problems.
                                      Disabled the write buffer:
                                      M122
                                      Static ram: 154604
                                      Dynamic ram: 163052 of which 44 recycled
                                      Exception stack ram used: 504
                                      Never used ram: 75012
                                      Tasks: ETHERNET(blocked,832) NETWORK(ready,1968) HEAT(blocked,1188) CanReceiv(suspended,3820) CanSender(suspended,1432) CanClock(blocked,1436) TMC(blocked,68) MAIN(running,4952) IDLE(ready,76)
                                      Owned mutexes:
                                      Last reset 00:04:28 ago, cause: software
                                      Last software reset at 2020-10-04 14:15, reason: User, spinning module LinuxInterface, available RAM 75204 bytes (slot 2)
                                      Error status: 0
                                      MCU temperature: min 37.6, current 39.4, max 40.1
                                      Supply voltage: min 23.7, current 24.2, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes
                                      Driver 0: ok, reads 59415, writes 17 timeouts 0, SG min/max 0/930
                                      Driver 1: ok, reads 59416, writes 17 timeouts 0, SG min/max 0/1023
                                      Driver 2: ok, reads 59416, writes 17 timeouts 0, SG min/max 0/846
                                      Driver 3: standstill, reads 59417, writes 17 timeouts 0, SG min/max 0/133
                                      Driver 4: standstill, reads 59423, writes 11 timeouts 0, SG min/max 0/0
                                      Driver 5: standstill, reads 59424, writes 11 timeouts 0, SG min/max 0/0
                                      Date/time: 2020-10-04 14:20:07
                                      Slowest loop: 5.34ms; fastest: 0.14ms
                                      === Storage ===
                                      Hiccups: 0(0), FreeDm: 295, MinFreeDm: 295, MaxWait: 77339ms
                                      === MainDDARing ===
                                      Scheduled moves: 175, completed moves: 115, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: 3
                                      === AuxDDARing ===
                                      Heater 0 is on, I-accum = 0.1
                                      Segments left: 1
                                      File* is doing "G1 X102.293999 Y192.054993 E0.178150" in state(s) 0
                                      Daemon* is idle in state(s) 0 0, running macro
                                      === Network ===
                                      Slowest loop: 0.97ms; fastest: 0.01ms
                                      • Ethernet -
                                        State: establishingLink
                                        === CAN ===
                                        Messages sent 1050, longest wait 0ms for type 0
                                        Last transfer: 20ms ago
                                        RX/TX seq numbers: 8369/8371
                                        Buffer RX/TX: 3696/1128-4080
                                        File:
                                        Buffered code: G1 X102.294 Y192.055 E0.17815
                                        Buffered code: G1 X100.964 Y188.823 E0.16215
                                        Buffered code: G1 X99.743 Y185.547 E0.16218
                                        Buffered code: G1 X98.556 Y182.005 E0.17331
                                        Buffered code: G1 X97.531 Y178.554 E0.16700
                                        Buffered code: G1 X96.647 Y175.165 E0.16248
                                        Buffered code: G1 X95.826 Y171.521 E0.17331
                                        Buffered code: G1 X95.157 Y167.978 E0.16730
                                        Buffered code: G1 X94.623 Y164.523 E0.16218
                                        Buffered code: G1 X94.178 Y160.820 E0.17301
                                        Buffered code: G1 X93.865 Y157.103 E0.17304
                                        Buffered code: G1 X93.688 Y153.606 E0.16246
                                        Buffered code: G1 X93.627 Y150.000 E0.16730
                                        Buffered code: G1 X93.693 Y146.271 E0.17304
                                        Buffered code: G1 X93.872 Y142.780 E0.16216
                                        Buffered code: G1 X94.178 Y139.187 E0.16730
                                        Buffered code: G1 X94.623 Y135.477 E0.17334
                                        Buffered code: G1 X95.157 Y132.023 E0.16215
                                        Buffered code: G1 X95.806 Y128.581 E0.16248
                                        Buffered code: G1 X96.645 Y124.841 E0.17782
                                        Buffered code: G1 X97.529 Y121.452 E0.16248
                                        Buffered code: G1 X98.523 Y118.101 E0.16218
                                        Buffered code: G1 X99.703 Y114.563 E0.17301
                                        Buffered code: G1 X101.008 Y111.069 E0.17304
                                        Buffered code: G1 X102.339 Y107.837 E0.16216
                                        Buffered code: G1 X103.778 Y104.651 E0.16218
                                        Buffered code: G1 X105.429 Y101.300 E0.17331
                                        Buffered code: G1 X107.134 Y98.122 E0.16730
                                        Buffered code: G1 X108.890 Y95.099 E0.16218
                                        Buffered code: G1 X110.873 Y91.933 E0.17331
                                        Buffered code: G1 X112.893 Y88.946 E0.16730
                                        Buffered code: G1 X114.911 Y86.166 E0.15940
                                        ==> 1532 bytes
                                        Daemon:
                                        Finishing macro daemon.g, started by system
                                      Next stack level
                                      Code buffer space: 2568
                                      Full transfers per second: 32.12
                                      File /opt/dsf/sd/gcodes/SPOOL/PLA_custom_B_2_215C.gcode is selected, processing
                                      After the emergency stop:
                                      m122
                                      Static ram: 154604
                                      Exception stack ram used: 512
                                      Never used ram: 75004
                                      Tasks: ETHERNET(blocked,832) NETWORK(ready,1968) HEAT(blocked,1188) CanReceiv(suspended,3820) CanSender(suspended,1420) CanClock(blocked,1436) TMC(blocked,192) MAIN(running,4952) IDLE(ready,76)
                                      Owned mutexes:
                                      Last reset 00:02:33 ago, cause: software
                                      Last software reset at 2020-10-04 14:26, reason: User, spinning module LinuxInterface, available RAM 75452 bytes (slot 0)
                                      Error status: 0
                                      MCU temperature: min 39.0, current 39.6, max 40.3
                                      Supply voltage: min 23.7, current 24.0, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes
                                      12V rail voltage: min 12.0, current 12.1, max 12.1, under voltage events: 0
                                      Driver 0: standstill, reads 29308, writes 17 timeouts 0, SG min/max 0/260
                                      Driver 1: standstill, reads 29308, writes 17 timeouts 0, SG min/max 0/255
                                      Driver 2: standstill, reads 29309, writes 17 timeouts 0, SG min/max 0/459
                                      Driver 3: standstill, reads 29309, writes 17 timeouts 0, SG min/max 0/122
                                      Driver 4: standstill, reads 29316, writes 11 timeouts 0, SG min/max 0/0
                                      Driver 5: standstill, reads 29316, writes 11 timeouts 0, SG min/max 0/0
                                      Date/time: 2020-10-04 14:28:51
                                      Slowest loop: 5.20ms; fastest: 0.14ms
                                      === Storage ===
                                      Hiccups: 0(0), FreeDm: 295, MinFreeDm: 295, MaxWait: 83293ms
                                      === MainDDARing ===
                                      === AuxDDARing ===
                                      Heater 1 is on, I-accum = 0.4
                                      Segments left: 1
                                      === Network ===
                                      Slowest loop: 0.95ms; fastest: 0.01ms
                                      • Ethernet -
                                        === CAN ===
                                        Messages sent 588, longest wait 0ms for type 0
                                        Last transfer: 19ms ago
                                        RX/TX seq numbers: 4669/4671
                                        File:
                                        ==> 1532 bytes
                                        Full transfers per second: 31.71
                                        Stephen6309 @dc42
                                        @dc42 Looks like the problem is with the Duet 3. M122 in prior post.
                                          @Stephen6309, thanks for your report. Please try release 3.2beta2 which we plan to release later today.
                                            Stephen6309 @dc42
                                            @dc42 I've installed it. It's currently printing, but problem usually has taken a few days to show up. Will update later this week.
