    Smart effector first layer issues
    4.7k
    • Lakemanundefined
      Lakeman
      This was the new height map
      Nozzle is clean, and filament I pulled back 5cm
      Changed back to S6 in the bed.g
      Some arms are 440.48 and some .47 So I have to chose, but that difference is minimum. Not sure why it was .50 in the override.
      Mesh is enabled
      Carloundefined 1 Reply Last reply Reply Quote 0
      • Vetiundefined
        Veti
        @Lakeman said in Smart effector first layer issues:
        ;M501 ;should save my data after calibration without homing.
        you disabled the overwrite loading
        also see
        https://duet3d.dozuki.com/Wiki/Calibrating_a_delta_printer
        what the different factor calibration do. 7 adjusts arm length
        • Lakemanundefined
          Lakeman
          Yes, as in the post above
          • Vetiundefined
            Veti
            have you tried a print with mesh bed leveling disabled?
            G29 S2
            • Carloundefined
              Carlo @Lakeman
              @Lakeman
              Height map looks fine
              G29 S1 good
              Its 440.5 above..
              So Height!
              heat bed to 60c nozzle hot or not G28, M208 Z-5 slowly lower nozzle to sheet of paper or 0.1mm feeler gauge if you have one don't delta calibrate the Z height should be at Z0.1 if not adjust M665 H so it is Z0.1 remember to add the 0.1 of the gauge/paper to the height for Z0
              Also just post you M122 please and M115 for firmware version
              Lakemanundefined 1 Reply Last reply Reply Quote 0
              • Lakemanundefined
                Lakeman
                This is with mesh disabled, slightly different, but high and low on almost the same spots
                • Lakemanundefined
                  Lakeman
                  M122
                  RepRapFirmware for Duet 2 WiFi/Ethernet version 3.1.1 running on Duet WiFi 1.02 or later
                  Board ID: 08DGM-917NK-F23T0-6JKFD-3S86S-9ZB0D
                  Used output buffers: 3 of 24 (11 max)
                  Static ram: 27980
                  Dynamic ram: 92980 of which 60 recycled
                  Exception stack ram used: 472
                  Never used ram: 9580
                  Tasks: NETWORK(ready,384) HEAT(blocked,1224) MAIN(running,1824) IDLE(ready,80)
                  Owned mutexes:
                  Last reset 00:00:36 ago, cause: software
                  Last software reset at 2020-08-25 17:01, reason: User, spinning module GCodes, available RAM 9372 bytes (slot 2)
                  Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0441f000 BFAR 0xe000ed38 SP 0xffffffff Task MAIN
                  Error status: 0
                  MCU temperature: min 34.5, current 35.1, max 35.5
                  Supply voltage: min 23.8, current 23.9, max 24.1, under voltage events: 0, over voltage events: 0, power good: yes
                  Driver 0: standstill, SG min/max 14/124
                  Driver 1: standstill, SG min/max 34/152
                  Driver 2: standstill, SG min/max 0/140
                  Date/time: 2020-08-25 17:01:57
                  Cache data hit count 57819496
                  Slowest loop: 6.62ms; fastest: 0.14ms
                  === Storage ===
                  Free file entries: 10
                  SD card longest read time 3.4ms, write time 0.0ms, max retries 0
                  Hiccups: 0(0), FreeDm: 169, MinFreeDm: 166, MaxWait: 17282ms
                  === MainDDARing ===
                  Scheduled moves: 5, completed moves: 5, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
                  === AuxDDARing ===
                  Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
                  Segments left: 0
                  Movement lock held by null
                  HTTP is idle in state(s) 0
                  Telnet is idle in state(s) 0
                  File is idle in state(s) 0
                  USB is idle in state(s) 0
                  Aux is idle in state(s) 0
                  Trigger is idle in state(s) 0
                  Queue is idle in state(s) 0
                  Daemon is idle in state(s) 0
                  Code queue is empty.
                  === Network ===
                  Slowest loop: 15.71ms; fastest: 0.00ms
                  Responder states: HTTP(2) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions
                  HTTP sessions: 1 of 8
                  • WiFi -
                    Network state is active
                    WiFi firmware version 1.23
                    WiFi MAC address ec:fa:bc:02:17:f8
                    WiFi Vcc 3.46, reset reason Unknown
                    WiFi flash size 4194304, free heap 24608
                    WiFi IP address 192.168.2.101
                    WiFi signal strength -71dBm, reconnections 0, sleep mode modem
                  • Lakemanundefined
                    Lakeman
                    M115
                    FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 3.1.1 ELECTRONICS: Duet WiFi 1.02 or later FIRMWARE_DATE: 2020-05-19b2
                    • Carloundefined
                      Carlo @Lakeman
                      @Lakeman
                      Nice one
                      • Lakemanundefined
                        Lakeman @Carlo
                        @Carlo M665 R227.9 L440.48 B185 H418.879 X0.217 Y0.125 Z0 ; Set delta radius, diagonal rod length, printable radius and homed height
                        • Carloundefined
                          Carlo @Lakeman
                          @Lakeman
                          Remember it should only just touch the gauge/paper not grip it.
                          • Lakemanundefined
                            Lakeman
                            Ok, adjusted the Z height, now it just grips the paper @ Z0.1
                            • Carloundefined
                              Carlo @Lakeman
                              @Lakeman
                              Cool so when you G28 ,G1 Z0.1 at 60c bed temp it goes to Z0.1 ? just touches the paper not grip it
                              • Lakemanundefined
                                Lakeman
                                @Carlo said in Smart effector first layer issues:
                                G1 Z0.1
                                Yes
                                • Carloundefined
                                  Carlo @Lakeman
                                  @Lakeman
                                  Good stuff was it off ? if so by how much ? just good to know..
                                  Copy below to new macro, so macros, new macro ...good to keep
                                  call it probe offset and run it its safe given to me by another user on this forum
                                  ; Heat bed to 60C & nozzle to 130C
                                  M104 S130 T0
                                  M190 S60 T0
                                  M109 S130 T0
                                  M106 P2 S0
                                  G31 P100 X0 Y0 Z0 ; Reset Z trigger height to 0mm
                                  M290 R0 S0 ; Reset babystepping
                                  G29 S2 ; Clear bed mesh
                                  G28 ; Home the effector
                                  G1 X0 Y0 Z20 F6000 ; Move close to the bed
                                  G30 ; Probe to find a rough Z 0mm
                                  G1 X0 Y0 Z1 F3000 ; Move the nozzle to Z 1mm slowly
                                  G92 Z3.0 ; Set the Z height to 3mm, allowing moves below 0
                                  M291 P"Lower the nozzle to until it touches a 0.10mm shim. Click to continue." S2 Z1
                                  G92 Z0 ; Define this point as 0mm
                                  G1 X0 Y0 Z20 ; Move the probe to Z 20mm
                                  G30 S-3 ; Probe and set the trigger height
                                  G1 Z20 ; Raise Z to 20mm
                                  • Lakemanundefined
                                    Lakeman
                                    About 1.5mm out
                                    • Carloundefined
                                      Carlo @Lakeman
                                      @Lakeman
                                      That's a lot mate
                                      • Lakemanundefined
                                        Lakeman
                                        Oke, I ran the macro. This time it touched the paper @Z2.1... But before was a cold nozzle
                                        • Carloundefined
                                          Carlo @Lakeman
                                          @Lakeman
                                          Nozzle won't make that much difference ...what was the offset ?
                                          • Lakemanundefined
                                            Lakeman
                                            touching the paper at Z2.15
