    BLTouch nightmare
    982
    • fcwiltundefined
      fcwilt
      I use the BuildTak FlexPlate System on my two printers.
      They both have genuine BLTouch v3.0 devices and they work just fine.
      Vulrathundefined 1 Reply Last reply Reply Quote 0
      • Vulrathundefined
        Vulrath @JoergS5
        @JoergS5 OK, this makes sense to me now. Thank you. I will try to hammer out some of this stuff over the next few days and repost. Thank you for your help with this!
        • Vulrathundefined
          Vulrath @fcwilt
          @fcwilt This is good to hear!
          • Vulrathundefined
            Vulrath @JoergS5
            @JoergS5 Here are the marlin config files, I'm pretty sure this is the firmware i loaded last.wasnt sure what the homeall file was called , maybe its this HAL.h?
            [0_1598381720358_HAL.h](Uploading 100%) [1_1598381656589_Configuration_adv.h](Uploading 100%) [0_1598381656583_Configuration.h](Uploading 100%)
            hmm doesnt seem to like these files.
            doh gonna have to make smaller vids, ill be back later
              I guess we don't get many .h files uploaded here. You could change the extension to .g and they should upload ok as gcode files. Or change them to .txt.
              • Vulrathundefined
                Vulrath @Phaedrux
                @Phaedrux Thank you! I'll try that.
                • Vulrathundefined
                  Vulrath @JoergS5
                  @JoergS5 configuration.h file Configurationh.txt
                  configuration_adv.h file Configuration_advh.txt
                  videos shortly
                  • Vulrathundefined
                    Vulrath @JoergS5
                    @JoergS5 I'm not sure how to make smaller videos. 4mb is a very small limit with todays smart phones and the HD quality of them. or maybe i just dont know how to use it properly. any way to shrink the size drastically , but the video still clear enough to see whats happening?
                    • JoergS5undefined
                      JoergS5 @Vulrath
                      @Vulrath Maybe you can find an app to make videos with low resolution for youtube. Are you using Android or iPhone, or something other?
                      I looked into the config files, but I must confess that it's difficult to read if one is used to the Duet config files. Maybe someone can help who knows marlin files.
                      Are there homing files in marlin or is the procedure you described above a manual process?
                        vimeo might be the easiest way to share video.
                        • Vulrathundefined
                          Vulrath @JoergS5
                          @JoergS5 I understand, I'm on a Duet forum asking for marlin help, so its ok that your not familiar with it. I have an android. I dont seem to find any homing files, it seems this is a manual process.
