Received Duet2 WiFi with DOA WiFi
the m115 command says you did not update the firmware and are still on 2.03
did you by chance just update the wifi firmware and not the duet firmware as well?
see
https://duet3d.dozuki.com/Wiki/Installing_and_Updating_Firmware
you need to send M997 S0 and M997 S1 to update both -
I'm so sorry. I didn't mean to mislead. These are screenshots of what I got before I upgraded. After upgrading I get the same results (except it does show "...FIRMWARE_VERSION: 2.05...).
FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 2.05 ELECTRONICS: Duet WiFi 1.02 or later FIRMWARE_DATE: 2019-12-13b1 ok WiFi module is being started ok WiFi module is being started ok WiFi module is being started ok WiFi module is being started ok WiFi module is being started ok WiFi module is being started ok WiFi module is being started ok```
User
M122
to verify wifi firmware version. (and see if you can have your terminal interpet line feeds (LF) as new lines, makes it easier to read)If your wifi version is 1.23 then try
;enable wifi debug M111 P14 S1 ;clear old wifi M552 S-1 G4 S1 M552 S0 G4 S1 M588 S"*" G4 S1 ;add new wifi M552 S-1 G4 S1 M552 S0 G4 S1 M587 S"enterssid" P"enterpasskey" ;start wifi M552 S1
(if you type the commands by hand you can skip
G4 S1
and just wait a second or two between each command, and skip the lines starting with;
, if you copy and paste you can include it all.) -
@bearer said in Received Duet2 WiFi with DOA WiFi:
thank you so much for your response and help. When I send M122 I don't see anything that indicates wifi firmware version (printout below). I also tried to send the commands that you suggested and when I send the M588 command I get "M588: Failed to reset the WiFi module to factory settings". I then tried M552 and it still gives "WiFi module is being started"
M122 response:
=== Diagnostics === RepRapFirmware for Duet 2 WiFi/Ethernet version 2.05 running on Duet WiFi 1.02 or later Board ID: Used output buffers: 1 of 24 (1 max) === RTOS === Static ram: 25712 Dynamic ram: 93428 of which 0 recycled Exception stack ram used: 256 Never used ram: 11676 Tasks: NETWORK(ready,1876) HEAT(blocked,1232) MAIN(running,3824) IDLE(ready,160) Owned mutexes: === Platform === Last reset 00:04:13 ago, cause: power up Last software reset time unknown, reason: User, spinning module GCodes, available RAM 11612 bytes (slot 0) Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0441f000 BFAR 0xe000ed38 SP 0xffffffff Task 0x4e49414d Error status: 0 Free file entries: 10 SD card 0 detected, interface speed: 20.0MBytes/sec SD card longest block write time: 0.0ms, max retries 0 MCU temperature: min 42.9, current 48.7, max 49.0 Supply voltage: min 1.4, current 1.7, max 1.7, under voltage events: 0, over voltage events: 0, power good: no Driver 0: ok, SG min/max not available Driver 1: ok, SG min/max not available Driver 2: ok, SG min/max not available Driver 3: ok, SG min/max not available Driver 4: ok, SG min/max not available Date/time: 1970-01-01 00:00:00 Cache data hit count 392271515 Slowest loop: 100.44ms; fastest: 0.05ms I2C nak errors 0, send timeouts 0, receive timeouts 0, finishTimeouts 0, resets 0 === Move === Hiccups: 0, FreeDm: 160, MinFreeDm: 160, MaxWait: 0ms Bed compensation in use: none, comp offset 0.000 === DDARing === Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 === Heat === Bed heaters = 0 -1 -1 -1, chamberHeaters = -1 -1 === GCodes === Segments left: 0 Stack records: 2 allocated, 0 in use Movement lock held by null http is idle in state(s) 0 telnet is idle in state(s) 0 file is idle in state(s) 0 serial is ready with "m122" in state(s) 0 aux is assembling a command in state(s) 0 daemon is idle in state(s) 0 queue is idle in state(s) 0 autopause is idle in state(s) 0 Code queue is empty. === Network === Slowest loop: 0.17ms; fastest: 0.00ms Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) Telnet(0) HTTP sessions: 0 of 8 - WiFi - Network state is starting WiFi module is disabled Failed messages: pending 0, notready 1, noresp 0 Socket states: 0 0 0 0 0 0 0 0 ok
Download these two files and place them on the SD card in the /sys folder with your PC.
https://github.com/Duet3D/RepRapFirmware/releases/download/2.05.1/Duet2CombinedFirmware.bin
https://github.com/Duet3D/RepRapFirmware/releases/download/2.05.1/DuetWiFiServer-1.23.bin
Rename DuetWiFiServer-1.23.bin to DuetWiFiServer.bin
https://github.com/Duet3D/RepRapFirmware/releases/download/2.05.1/DuetWebControl-SD-2.0.7.zip
Extract this zip file to the /www folder.
Now put the SD card back in the duet and power up via USB and send M997 S0:1 in the console to install the main and wifi firmwares.
Then send M122 again after it reboots and post the result.
@Phaedrux Thanks for your suggestion. I followed your directions and it looks like the sub-version did change from 2.05 to 2.05.1. I however still get the same results.
M122 === Diagnostics === RepRapFirmware for Duet 2 WiFi/Ethernet version 2.05.1 running on Duet WiFi 1.02 or later Board ID: Used output buffers: 1 of 24 (1 max) === RTOS === Static ram: 25712 Dynamic ram: 93428 of which 0 recycled Exception stack ram used: 304 Never used ram: 11628 Tasks: NETWORK(ready,1876) HEAT(blocked,1232) MAIN(running,3824) IDLE(ready,160) Owned mutexes: === Platform === Last reset 00:01:02 ago, cause: power up Last software reset time unknown, reason: User, spinning module GCodes, available RAM 11612 bytes (slot 0) Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0441f000 BFAR 0xe000ed38 SP 0xffffffff Task 0x4e49414d Error status: 0 Free file entries: 10 SD card 0 detected, interface speed: 20.0MBytes/sec SD card longest block write time: 0.0ms, max retries 0 MCU temperature: min 40.1, current 47.1, max 47.1 Supply voltage: min 1.4, current 1.7, max 1.7, under voltage events: 0, over voltage events: 0, power good: no Driver 0: ok, SG min/max not available Driver 1: ok, SG min/max not available Driver 2: ok, SG min/max not available Driver 3: ok, SG min/max not available Driver 4: ok, SG min/max not available Date/time: 1970-01-01 00:00:00 Cache data hit count 93718842 Slowest loop: 0.16ms; fastest: 0.05ms I2C nak errors 0, send timeouts 0, receive timeouts 0, finishTimeouts 0, resets 0 === Move === Hiccups: 0, FreeDm: 160, MinFreeDm: 160, MaxWait: 0ms Bed compensation in use: none, comp offset 0.000 === DDARing === Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 === Heat === Bed heaters = 0 -1 -1 -1, chamberHeaters = -1 -1 === GCodes === Segments left: 0 Stack records: 2 allocated, 0 in use Movement lock held by null http is idle in state(s) 0 telnet is idle in state(s) 0 file is idle in state(s) 0 serial is ready with "M122" in state(s) 0 aux is idle in state(s) 0 daemon is idle in state(s) 0 queue is idle in state(s) 0 autopause is idle in state(s) 0 Code queue is empty. === Network === Slowest loop: 0.16ms; fastest: 0.00ms Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) Telnet(0) HTTP sessions: 0 of 8 - WiFi - Network state is disabled WiFi module is disabled Failed messages: pending 2779096485, notready 2779096485, noresp 2779096485 Socket states: 0 0 0 0 0 0 0 0 ok M552 S-1 ok M552 S0 ok M588 S"*" M588: Failed to reset the WiFi module to factory settings ok
edit: seems to be normal output of
M122
afterM552 S-1
. So first tryM552 S0
thenM122
if still the same, then go with:
could you run
M552 S-1
thenM111 P14 S1
followed by another attempt atM997 S1
and post what happens? -
@bearer
M552 S-1 ok M111 P14 S1 Debugging enabled for modules: WiFi(14) Debugging disabled for modules: Platform(0) Network(1) Webserver(2) GCodes(3) Move(4) Heat(5) DDA(6) Roland(7) Scanner(8) PrintMonitor(9) Storage(10) PortControl(11) DuetExpansion(12) FilamentSensors(13) Display(15) ok M997 S1 Trying to connect at 230400 baud: failed Trying to connect at 115200 baud: failed Trying to connect at 74880 baud: failed Trying to connect at 9600 baud: failed Error: Installation failed due to comm write error ok
to quote Monty Python "its dead, thats whats wrong with it"
Not just "mostly dead?"
I'll defer to the Duet people for the final word, but seems the wifi module has ceased to be; its not even connecting to the bootloader. (If the wifi module is okay then the uart on the main processor is toast, either way, RMA methinks)
@bearer Thanks for your time and expertise (and trip down Python memory lane). I will wait to hear what the Duet people have to say.
When and where did you purchase the Duet Wifi?
@Phaedrux I purchased my board from MatterHackers on March 31, 2020. It took me a while to carve out the time to put it in my 3d printer and when I started to get ready to install it, I found that I couldn't get it to connect to my network. On May 4th I reached out to support @ matterhackers and wen't back and forth with them, trying several things to get it working to no avail. They then asked me to post on this forum because the CEO and Chief Designer needed to see a post here about defective boards.
Thanks,
PrestonHere is the first email that I sent to support about this issue on May 4th:
"I purchased a Duet 2 WiFi last month (Order #101-0000102-1607002) and am trying to set it up. I can’t get the WiFi to start up. When I sent the M552 S1 command in terminal it says ok, then when I send M552 it responds with “WiFi module is being started”. It keeps showing that forever (ok, actually I waited 30 min, but in computer 30 min might as well be forever) and the blue light on the wifi module never even blinks on. Incidentally, the WiFi module is quite hot to the touch.I’m not sure what to try to get the WiFi working. Please advise.
Regards,
Preston
@prestonthayne said in Received Duet2 WiFi with DOA WiFi:
@bearer
Thanks for that report, it shows that uploading firmware to the WiFi module is not working. I am happy to approve a warranty replacement.
