    Received Duet2 WiFi with DOA WiFi
    719
    • prestonthayneundefined
      prestonthayne
      I'm so sorry. I didn't mean to mislead. These are screenshots of what I got before I upgraded. After upgrading I get the same results (except it does show "...FIRMWARE_VERSION: 2.05...).
      prestonthayneundefined 1 Reply Last reply Reply Quote 0
        prestonthayne @prestonthayne
        @prestonthayne
        FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 2.05 ELECTRONICS: Duet WiFi 1.02 or later FIRMWARE_DATE: 2019-12-13b1
                                         ok
                                           WiFi module is being started
        ok
                     ok
                                                   ok
        ok
                               ok
                                                             ok
           ok```
          A Former User
          User M122 to verify wifi firmware version. (and see if you can have your terminal interpet line feeds (LF) as new lines, makes it easier to read)
          If your wifi version is 1.23 then try
          ;enable wifi debug
          M111 P14 S1
          ;clear old wifi
          M552 S-1  G4 S1
          M552 S0   G4 S1
          M588 S"*" G4 S1
          ;add new wifi
          M552 S-1  G4 S1
          M552 S0   G4 S1
          M587 S"enterssid" P"enterpasskey"
          ;start wifi
          M552 S1
          (if you type the commands by hand you can skip G4 S1 and just wait a second or two between each command, and skip the lines starting with ;, if you copy and paste you can include it all.)
            prestonthayne
            @bearer said in Received Duet2 WiFi with DOA WiFi:
            thank you so much for your response and help. When I send M122 I don't see anything that indicates wifi firmware version (printout below). I also tried to send the commands that you suggested and when I send the M588 command I get "M588: Failed to reset the WiFi module to factory settings". I then tried M552 and it still gives "WiFi module is being started"
            M122 response:
            RepRapFirmware for Duet 2 WiFi/Ethernet version 2.05 running on Duet WiFi 1.02 or later
            Board ID:
            Used output buffers: 1 of 24 (1 max)
            Static ram: 25712
            Dynamic ram: 93428 of which 0 recycled
            Exception stack ram used: 256
            Never used ram: 11676
            Tasks: NETWORK(ready,1876) HEAT(blocked,1232) MAIN(running,3824) IDLE(ready,160)
            Owned mutexes:
            Last reset 00:04:13 ago, cause: power up
            Last software reset time unknown, reason: User, spinning module GCodes, available RAM 11612 bytes (slot 0)
            Error status: 0
            Free file entries: 10
            MCU temperature: min 42.9, current 48.7, max 49.0
            Supply voltage: min 1.4, current 1.7, max 1.7, under voltage events: 0, over voltage events: 0, power good: no
            Driver 0: ok, SG min/max not available
            Driver 1: ok, SG min/max not available
            Driver 2: ok, SG min/max not available
            Driver 3: ok, SG min/max not available
            Driver 4: ok, SG min/max not available
            Cache data hit count 392271515
            Slowest loop: 100.44ms; fastest: 0.05ms
            Hiccups: 0, FreeDm: 160, MinFreeDm: 160, MaxWait: 0ms
            === DDARing ===
            Segments left: 0
            Movement lock held by null
            http is idle in state(s) 0
            telnet is idle in state(s) 0
            file is idle in state(s) 0
            serial is ready with "m122" in state(s) 0
            aux is assembling a command in state(s) 0
            daemon is idle in state(s) 0
            queue is idle in state(s) 0
            Code queue is empty.
            === Network ===
            Slowest loop: 0.17ms; fastest: 0.00ms
            HTTP sessions: 0 of 8
            - WiFi -
            Network state is starting
            WiFi module is disabled
            Failed messages: pending 0, notready 1, noresp 0
            ok
              Download these two files and place them on the SD card in the /sys folder with your PC.
              https://github.com/Duet3D/RepRapFirmware/releases/download/2.05.1/Duet2CombinedFirmware.bin
              https://github.com/Duet3D/RepRapFirmware/releases/download/2.05.1/DuetWiFiServer-1.23.bin
              Rename DuetWiFiServer-1.23.bin to DuetWiFiServer.bin
              https://github.com/Duet3D/RepRapFirmware/releases/download/2.05.1/DuetWebControl-SD-2.0.7.zip
              Extract this zip file to the /www folder.
              Now put the SD card back in the duet and power up via USB and send M997 S0:1 in the console to install the main and wifi firmwares.
              Then send M122 again after it reboots and post the result.
                prestonthayne @Phaedrux
                @Phaedrux Thanks for your suggestion. I followed your directions and it looks like the sub-version did change from 2.05 to 2.05.1. I however still get the same results.
                M122
                RepRapFirmware for Duet 2 WiFi/Ethernet version 2.05.1 running on Duet WiFi 1.02 or later
                Board ID:
                Static ram: 25712
                Exception stack ram used: 304
                Never used ram: 11628
                Owned mutexes:
                Last reset 00:01:02 ago, cause: power up
                Error status: 0
                MCU temperature: min 40.1, current 47.1, max 47.1
                Cache data hit count 93718842
                Slowest loop: 0.16ms; fastest: 0.05ms
                === DDARing ===
                Segments left: 0
                serial is ready with "M122" in state(s) 0
                aux is idle in state(s) 0
                === Network ===
                Slowest loop: 0.16ms; fastest: 0.00ms
                - WiFi -
                Network state is disabled
                Failed messages: pending 2779096485, notready 2779096485, noresp 2779096485
                ok
                M552 S-1
                ok
                M552 S0
                ok
                M588 S"*"
                ok
                  A Former User
                  edit: seems to be normal output of M122 after M552 S-1. So first try M552 S0 then M122
                  if still the same, then go with:
                  could you run M552 S-1 then M111 P14 S1 followed by another attempt at M997 S1 and post what happens?
                    prestonthayne @A Former User
                    @bearer
                    M552 S-1
                    ok
                    M111 P14 S1
                    Debugging enabled for modules: WiFi(14)
                    Debugging disabled for modules: Platform(0) Network(1) Webserver(2) GCodes(3) Move(4) Heat(5) DDA(6) Roland(7) Scanner(8) PrintMonitor(9) Storage(10) PortControl(11) DuetExpansion(12) FilamentSensors(13) Display(15)
                    ok
                    M997 S1
                    Trying to connect at 230400 baud:
                     failed
                    Trying to connect at 115200 baud:
                     failed
                    Trying to connect at 74880 baud:
                     failed
                    Trying to connect at 9600 baud:
                     failed
                    Error: Installation failed due to comm write error
                    ok
                      A Former User
                      to quote Monty Python "its dead, thats whats wrong with it"
                        Not just "mostly dead?"
                          A Former User
                          I'll defer to the Duet people for the final word, but seems the wifi module has ceased to be; its not even connecting to the bootloader. (If the wifi module is okay then the uart on the main processor is toast, either way, RMA methinks)
                            @bearer Thanks for your time and expertise (and trip down Python memory lane). I will wait to hear what the Duet people have to say.
                              When and where did you purchase the Duet Wifi?
                                @Phaedrux I purchased my board from MatterHackers on March 31, 2020. It took me a while to carve out the time to put it in my 3d printer and when I started to get ready to install it, I found that I couldn't get it to connect to my network. On May 4th I reached out to support @ matterhackers and wen't back and forth with them, trying several things to get it working to no avail. They then asked me to post on this forum because the CEO and Chief Designer needed to see a post here about defective boards.
                                Thanks,
                                Preston
                                Here is the first email that I sent to support about this issue on May 4th:
                                "I purchased a Duet 2 WiFi last month (Order #101-0000102-1607002) and am trying to set it up. I can’t get the WiFi to start up. When I sent the M552 S1 command in terminal it says ok, then when I send M552 it responds with “WiFi module is being started”. It keeps showing that forever (ok, actually I waited 30 min, but in computer 30 min might as well be forever) and the blue light on the wifi module never even blinks on. Incidentally, the WiFi module is quite hot to the touch.
                                I’m not sure what to try to get the WiFi working. Please advise.
                                Regards,
                                Preston
                                  dc42 administrators @prestonthayne
                                  @prestonthayne said in Received Duet2 WiFi with DOA WiFi:
                                  @bearer
                                  M552 S-1
                                  ok
                                  M111 P14 S1
                                  ok
                                  M997 S1
                                   failed
                                   failed
                                   failed
                                   failed
                                  ok
                                  Thanks for that report, it shows that uploading firmware to the WiFi module is not working. I am happy to approve a warranty replacement.
