    Smart effector first layer issues
    4.6k
    • Lakemanundefined
      Lakeman
      Haydn_Carriage_Adapter_Remix_v4.stl
      This is what I used, I will try the stl file you send me, probebly the safest option to use the pcb's. Your second link goes to a tray, not sure what to do with that 😉
      Carloundefined 2 Replies Last reply Reply Quote 0
      • Carloundefined
        Carlo @Lakeman
        @Lakeman
        Make sure that the spacing between each pair of towers is the same at the top, the bottom, and half way between top and bottom from duets website
        The spacing between the bearings at the top of a pair of rods must be exactly the same as the spacing between the bearings at the bottom
        • Carloundefined
          Carlo @Lakeman
          @Lakeman
          get the linked version with the flying extruder mounting holes easier to mount the extruder
          • Lakemanundefined
            Lakeman
            Thanks, I print those and try again
            Carloundefined 1 Reply Last reply Reply Quote 0
            • Carloundefined
              Carlo @Lakeman
              @Lakeman
              One thing I did change on my bed was the standoffs under it the blue discs if you take 2 off and measure them mine were way way off in size each to each I replaced them with springs but that was after getting my setup sorted
              • Carloundefined
                Carlo @Carlo
                @Carlo
                New link no idea why it went to a tray
                https://www.thingiverse.com/thing:3567642
                • Lakemanundefined
                  Lakeman
                  Hello, I tried printing the parts yesterday (small parts usually work after some fiddling) and halfway a belt snapt, thats what you get after to much tensioning for more precision... But anyway, I changed all the belts to new ones with a metal core which I had as spare, tensioned the same and printed the small parts again, which went easy somehow. So I tried to print the big part to be sure. Perfect first layer without a mesh, just after a quick delta calibration.
                  No idea what was wrong with the other belts, could not find any problems on them and the were installed correcly and tried several amounts of tension over the last year.
                  I will install the new mounts for the arms anyway to remove the 0.5mm, but they do not couse the first layer issue.
                  Thanks a lot for al the help, It was a hardware foult afterall, altough I am still not sure what was wrong with them.
                  The support on the forum is great, really thanks a lot.
                  Should I close the thread somehow to show it is fixed?
                  • Vetiundefined
                    Veti @Lakeman
                    @Lakeman said in Smart effector first layer issues:
                    thats a big no no. steel belts do not like sharp turns like you have in a delta. they will break and cause problems.
                    here are some good belts
                    https://de.aliexpress.com/item/32853559638.html
                    • Lakemanundefined
                      Lakeman
                      Interesting, I had to replace a belt on the original predator and I thing it has more then a 1000 hours with a metal belt in 1 tower... No problems
                      • Vetiundefined
                        Veti @Lakeman
                        @Lakeman
                        see https://reprap.org/wiki/Choosing_Belts_and_Pulleys
                        • Carloundefined
                          Carlo
                          Glad you got it sorted
                          Mark as the correct answer if your happy it fixed
