    Smart effector first layer issues
    4.7k
    • Carloundefined
      Carlo @Lakeman
      @Lakeman
      would be good to rule it out .5mm when your talking 0.12 -0.3mm layers?
      • Lakemanundefined
        Lakeman
        I think ruling it out is the best plan, just not entirely sure if it will work if I just scale the printed parts a bit and hopefully end up exactly 0.5mm wider 😛
        Carloundefined 1 Reply Last reply Reply Quote 0
        • Lakemanundefined
          Lakeman
          I am printing a 0.2mm first layer by the way and I do not know how much effect spacing between the balls has on the height,
          • Carloundefined
            Carlo @Lakeman
            @Lakeman
            have you got the link to the ones you printed as there are afew and I found these to be best
            Used with the PCB ball mount supplied with the smart effector
            anycubic_predator_carriage_SE-PCB_withoutFE.stl
            • Carloundefined
              Carlo @Carlo
              @Carlo
              Link here for flying extruder version also
              https://www.thingiverse.com/thing:356764
              using the pcb supplied guarantees perfect spacing
              • Lakemanundefined
                Lakeman
                Haydn_Carriage_Adapter_Remix_v4.stl
                This is what I used, I will try the stl file you send me, probebly the safest option to use the pcb's. Your second link goes to a tray, not sure what to do with that 😉
                Carloundefined 2 Replies Last reply Reply Quote 0
                • Carloundefined
                  Carlo @Lakeman
                  @Lakeman
                  Make sure that the spacing between each pair of towers is the same at the top, the bottom, and half way between top and bottom from duets website
                  The spacing between the bearings at the top of a pair of rods must be exactly the same as the spacing between the bearings at the bottom
                  • Carloundefined
                    Carlo @Lakeman
                    @Lakeman
                    get the linked version with the flying extruder mounting holes easier to mount the extruder
                    • Lakemanundefined
                      Lakeman
                      Thanks, I print those and try again
                      • Carloundefined
                        Carlo @Lakeman
                        @Lakeman
                        One thing I did change on my bed was the standoffs under it the blue discs if you take 2 off and measure them mine were way way off in size each to each I replaced them with springs but that was after getting my setup sorted
                        • Carloundefined
                          Carlo @Carlo
                          @Carlo
                          New link no idea why it went to a tray
                          https://www.thingiverse.com/thing:3567642
                          • Lakemanundefined
                            Lakeman
                            Hello, I tried printing the parts yesterday (small parts usually work after some fiddling) and halfway a belt snapt, thats what you get after to much tensioning for more precision... But anyway, I changed all the belts to new ones with a metal core which I had as spare, tensioned the same and printed the small parts again, which went easy somehow. So I tried to print the big part to be sure. Perfect first layer without a mesh, just after a quick delta calibration.
                            No idea what was wrong with the other belts, could not find any problems on them and the were installed correcly and tried several amounts of tension over the last year.
                            I will install the new mounts for the arms anyway to remove the 0.5mm, but they do not couse the first layer issue.
                            Thanks a lot for al the help, It was a hardware foult afterall, altough I am still not sure what was wrong with them.
                            The support on the forum is great, really thanks a lot.
                            Should I close the thread somehow to show it is fixed?
                            • Vetiundefined
                              Veti @Lakeman
                              @Lakeman said in Smart effector first layer issues:
                              thats a big no no. steel belts do not like sharp turns like you have in a delta. they will break and cause problems.
                              here are some good belts
                              https://de.aliexpress.com/item/32853559638.html
                              • Lakemanundefined
                                Lakeman
                                Interesting, I had to replace a belt on the original predator and I thing it has more then a 1000 hours with a metal belt in 1 tower... No problems
                                • Vetiundefined
                                  Veti @Lakeman
                                  @Lakeman
                                  see https://reprap.org/wiki/Choosing_Belts_and_Pulleys
                                  • Carloundefined
                                    Carlo
                                    Glad you got it sorted
                                    Mark as the correct answer if your happy it fixed
