    Duet Wifi - Ethernet, w genuine ethernet module.
    510
    • DocTruckerundefined
      DocTrucker
      Great! Will try to sort it out this evening then. The kit has the headers and plastic stand-offs with it.
      Would have normally order direct from Duet3D, but I guess that may even inconvenience them more than using resellers!
        A Former User @DocTrucker
        @DocTrucker said in Duet Wifi - Ethernet, w genuine ethernet module.:
        the low profile female header as well?
          DocTrucker @A Former User
          @bearer sure I saw one through the bubble wrap. Would be frustrating is one is missing! I think the ethernet module that Duet3D offer was intended for those looking to convert Duet WiFi to ethernet.
            Yes, it is supplied with the socket strips and standoffs. https://www.duet3d.com/DuetAddons/DuetEthernet_Module
              DocTrucker
              All sorted now thanks. I managed to goose the firmware update, but sorted with a little bossac. Talking via ethernet / DWC now. Rewire a little more involved than a simple unplug and plug.
              Getting this setup for RRF 2.05, then will look at guides for converting the config files for RRF 3. Still got the Duet3 to set up but the target machine got diverted to running on a 0.8.5, so waiting on another machine build, which is underway slowly!
                Phaedrux Moderator @DocTrucker
                Getting an example config set from the web tool to compare against is a good first step.
                  DocTrucker @Phaedrux
                  Tested all axis this morning and all fine, so just down to extendng some wires, PT100 test, fan check, tuning, then finally swap to RRF3.
                  All in about £85 with some soldering. I'm happy with that! 🙂
                  @Phaedrux yes thanks, that was my planned step one. I haven't used the config generators for some time so I was planning on a default set for RRF2 to compare to what I have now so I can transfer any extras that I have added to the defaults to the autogenerated RRF3 config. Should be fairly normal aside from the reasonably common twin z motors with gantry levelling. Don't anticipate much of an issue, just a bit of learning a new language! 😄
                    DocTrucker
                    Running RRF 3.1 now, less fuss than I expected just an issue with the bed temp sensor and figuring out how to use a NC inductive probe on the zstop input. I suspect easy fixes, just ran out of time.
                    I'll repeat the safety checks that I did on RRF1 on this system once I've established it is running well.
                      droftarts administrators @DocTrucker
                      @DocTrucker does it report as an Duet Ethernet or WiFi in M122? Always wondered where this is set, but I expect it checks peripherals before setting one or the other.
                      (I often check my peripherals before deciding one way or the other!)
                        DocTrucker @droftarts
                        @droftarts that'll be the function calls;
                        lift_skirt();
                        what_am_i_packing();
                        I'll check later!
                          @DocTrucker always declare your variables!
                          DocTruckerundefined 2 Replies Last reply Reply Quote 0
                            @droftarts Touché! Think it's best I exit this skit before I get myself in trouble.
                            Will report what it identifies as later.
                              @droftarts Here you are:
                              Spoiler; it identifies as a Duet Ethernet.
                              M122
                              RepRapFirmware for Duet 2 WiFi/Ethernet version 3.1.1 running on Duet Ethernet 1.02 or later
                              Board ID: 08DGM-917DA-G4MS8-6JKD4-3S86M-19S7A
                              Used output buffers: 3 of 24 (10 max)
                              Static ram: 27980
                              Dynamic ram: 92992 of which 20 recycled
                              Exception stack ram used: 192
                              Never used ram: 9888
                              Tasks: NETWORK(ready,384) HEAT(blocked,1304) MAIN(running,1824) IDLE(ready,80)
                              Owned mutexes:
                              Last reset 00:02:20 ago, cause: power up
                              Last software reset time unknown, reason: Watchdog timeout, spinning module PortControl, available RAM 6392 bytes (slot 0)
                              Software reset code 0x00ab HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0441f80f BFAR 0xe000ed38 SP 0x20004aac Task MAIN
                              Stack: 0043e171 0043d44c 61000000 00000000 40568000 00000000 00000000 3e178897 3e1cd04f 41880000 3e3a3329
                              Error status: 0
                              MCU temperature: min 21.3, current 27.3, max 27.5
                              Supply voltage: min 24.3, current 24.4, max 24.4, under voltage events: 0, over voltage events: 0, power good: yes
                              Date/time: 2020-08-29 17:22:37
                              Cache data hit count 275538932
                              Slowest loop: 4.14ms; fastest: 0.12ms
                              === Storage ===
                              Free file entries: 10
                              SD card longest read time 0.8ms, write time 0.0ms, max retries 0
                              Hiccups: 0(0), FreeDm: 169, MinFreeDm: 169, MaxWait: 0ms
                              === MainDDARing ===
                              === AuxDDARing ===
                              Segments left: 0
                              Movement lock held by null
                              HTTP is idle in state(s) 0
                              Telnet is idle in state(s) 0
                              File is idle in state(s) 0
                              USB is idle in state(s) 0
                              Aux is idle in state(s) 0
                              Trigger is idle in state(s) 0
                              Queue is idle in state(s) 0
                              Daemon is idle in state(s) 0
                              Code queue is empty.
                              === Network ===
                              Slowest loop: 4.86ms; fastest: 0.02ms
                              HTTP sessions: 1 of 8
                              Interface state active, link 100Mbps full duplex
                                @DocTrucker great, thanks. So it does look at the available hardware to report this. Nice.
