    Duet Laser Software
    Laser Cutters
    1.3k
    • sungod3kundefined
      sungod3k @omni
      @omni hi, check out jtech photonics. they use the fan output to regulate the laser. not sure if this fits you laser, but if you manage that, there should be no need to reconfigure your machine.
      im working with a pen plotter toolhead at the momement and i only need two extra gcode commands to run my plotter gcode succesfully.
      http://www.42dimensions.de/
      https://printnewworlds.blogspot.com/
      omniundefined 1 Reply Last reply Reply Quote 0
        dc42 administrators @omni
        The recommended approach is to use M452 to put the machine in laser mode and declare the laser control pin, and have the laser engraver software use S parameters on G1 commands to control the laser power.
        omniundefined 1 Reply Last reply Reply Quote 1
        • omniundefined
          omni @dc42
          @dc42 Thanks for the reply and for your time. I've already read that in the previous threads about the lasers and I set it up. My question was more directed towards particular software solutions that are tried out and proven to work well with the Duet, so I can start from there.
          • omniundefined
            omni @sungod3k
            @sungod3k
            Thanks for you reply. I've set up the laser to work with the Heater3 pin on the expansion header. I'll check out jtech photonics. There are many paid and free options for the laser engraving/cutting software, but I wanted to start from something that other users may have found works well, just to save some time...
            • arhiundefined
              arhi @omni
              @omni http://visicut.org/ is pretty well ranked, have not tried it with duet but should work ok
              • arhiundefined
                arhi
                visicut creates code that expect that G1 S value is sticky. @dc42 is it?
                code is e.g.
                G21
                G90
                G0 X21.539200 Y11.226800 F3600
                G1 X21.488400 Y12.242800 S255.000000 F1200
                G1 X21.336000 Y13.258800
                G1 X21.082000 Y14.173200
                G1 X20.777200 Y15.138400
                G1 X20.320000 Y16.002000
                G1 X19.862800 Y16.814800
                G1 X19.253200 Y17.576800
                G1 X18.643600 Y18.288000
                G1 X21.488400 Y10.210800
                G1 X21.539200 Y11.226800
                G0 X0 Y0
                So it will expect G0 runs with laser off but for G1 it will add S value only first time it changes the laser power. Will this work ok, or RRF expect S value for every G1 move?
                Also, will G0 run default with laser off?
                If S is sticky, is it remembering separate values for G0 and G1, e.g. visicut will do (if set to forse off on G0) something like
                G0 ... S0
                G1 ... S255
                G0 XY
                G1 XY
                and here it will expect G1 to use 255 (as previously set) and G0 to use S0 (as previously set)
                will that work with duet?
                  A Former User
                  https://duet3d.dozuki.com/Wiki/Gcode#Section_M452_Select_Laser_Printer_Mode
                  M452 S1 takes care of sticky mode in recent firmwares.
                  • arhiundefined
                    arhi @A Former User
                    @bearer ah, seen that, did not link it to this issue 😄
                    how bout G1 vs G0? each have their own sticky value or?
                      A Former User
                      it said G0 means no laser, which was part of the discussion a while back; i fell off when you started talking of stick for G0, but there is a description in the wiki
                        jay_s_uk
                        Lightburn can be coaxed into working with RRF
                        • arhiundefined
                          arhi @A Former User
                          @bearer said in Duet Laser Software:
                          I missed it on the wiki, I asked only 'cause in 3dprint mode G0 and G1 are handled same, and this app can "force G0 laser off" by adding S0 but it does it only on the first G0..
                          anyhow all that is easily tested when you have laser hooked on so it's up to @omni now 😄 ... visicut itself looks decent, the visicam addition seems very interesting, will be cool to see how it will deal with moving bed or if the camera for visicam will have to be mounted to bed and not to frame (or to enclosure like in @omni's case) ... I only tried visicut with smoothieboard and it support smoothie out of the box
                          @jay_s_uk said in Duet Laser Software:
                          https://lightburnsoftware.com/ looks rather nice but for 40$ I'd expect some of the features visicut comes with .. e.g.
                          https://www.youtube.com/watch?v=3VaI8r-8oNw
                            jay_s_uk @arhi
                            @arhi lightburn supports cameras so I believe that can be achieved. Not tried it though
                            • omniundefined
                              omni
                              Thanks for all the info guys. It's been hectic with work the past couple of days, so I could not be very active on this front. I will try out the solutions suggested here and let you know the results....
                              • oozeBotundefined
                                oozeBot
                                I am just now dipping my toes into this as well as an option for our machines. I think there are various ways to accomplish the same thing here and do remember reading how important the S parameter is for any and all commands when running a laser - so my assumption is adding the S parameter on the G1 moves will work, but I haven't yet tried it..
                                We have a copy of Vectric VCarve Pro that I recently upgraded with their laser plugin. One of the defaults is for the OozNest Duet (I know right? OozNest and oozeBot.. small world). They are using the Duet 2 as the controller for their hobby CNC machines and have instructions to add a laser on their website. Here is a sample of the code their Vectric post-processor generates:
                                T1
                                G17
                                G21
                                G90
                                G0Z20.320
                                G0X0.000Y0.000
                                G0X34.827Y38.358Z5.080
                                G1Z0.000S0F762.0
                                M3
                                M3S1000
                                G1Y62.302
                                G1X56.947Y53.139
                                G1Y29.196
                                G1X34.827Y38.358
                                G0Z5.080
                                G0X56.946Y60.322
                                G1Z0.000S0F762.0
                                M3
                                M3S1000
                                G1X33.370Y67.705
                                G1X56.946Y55.533
                                G1Y60.322
                                G0Z5.080
                                G0Y62.716
                                G1Z0.000S0F762.0
                                M3
                                M3S1000
                                G1Y67.505
                                G1X31.194Y75.779
                                G1X56.946Y62.716
                                G0Z5.080
                                G0Y74.688
                                G1Z0.000S0F762.0
                                M3
                                M3S1000
                                G1X29.013Y83.873
                                G1X56.946Y69.899
                                G1Y74.688
                                G0Z5.080
                                G0X81.279Y69.398
                                G1Z0.000S0F762.0
                                This is very similar to the gCode produced for our other laser engraver.. but again, I have not yet tested any of this.
                                And FYI, while I wait on our new Opt Laser head to arrive, I'm working on our own post-processor for Vectric we'll be releasing. I'll pick up a copy of Lightburn here soon to do the same as we understand most people won't be able justify the cost of Vectric's solution.
