Idle temperature hot-end and bed to high
@Veti Yes I did. I followed the guide to the letter
@Veti I will post my config tomorrow, I just turned the printer off
@dden said in Idle temperature hot-end and bed to high:
that would be wrong as the duet wifi has different resistance value
@Veti Ok so now I am worried. Let’s dig in tomorrow
@Veti Below is my config
; Configuration file for Duet Maestro (firmware version 2.03)
; generated by RepRapFirmware Configuration Tool v3.1.4 on Fri Aug 28 2020 14:54:26 GMT+0200 (Central European Summer Time); General preferences
M550 P"Ender 3 Pro" ; set printer name; Network
M552 S1 ; enable network and acquire dynamic address via DHCP
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M569 P0 S0 ; physical drive 0 goes backwards
M350 X16 Y16 Z16 E128 I1 ; configure microstepping with interpolation
M92 X80.00 Y80.00 Z400.00 E790.00 ; set steps per mm
M566 X1200.00 Y1200.00 Z24.00 E300.00 ; set maximum instantaneous speed changes (mm/min)
M203 X9000.00 Y9000.00 Z180.00 E6000.00 ; set maximum speeds (mm/min)
M201 X500.00 Y500.00 Z100.00 E5000.00 ; set accelerations (mm/s^2)
M906 X800 Y800 Z800 E1000 I50 ; set motor currents (mA) and motor idle factor in per cent
M208 X235 Y235 Z260 S0 ; set axis maxima; Endstops
M574 X1 Y1 Z1 S1 ; set active high endstops; Z-Probe
M558 P0 H5 F120 T6000 ; disable Z probe but set dive height, probe speed and travel speed
M557 X10:220 Y10:220 S20 ; define mesh grid; Heaters
M305 P0 T98801 B4185 R2200 ; set thermistor + ADC parameters for heater 0
M143 H0 S80 ; set temperature limit for heater 0 to 80C
M305 P1 T98801 B4185 R2200 ; set thermistor + ADC parameters for heater 1
M143 H1 S275 ; set temperature limit for heater 1 to 275C; Fans
M106 P1 S0 I0 F500 H1 T45 ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
M106 P2 S0 I0 F500 H1:0 T45 ; set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on; Tools
M563 P0 S"HotEnd" D0 H1 F0 ; define tool 0
M911 S21 R23 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss
T0 ; select first tool -
M92 X80.00 Y80.00 Z400.00 E790.00 ; set steps per mmThe Duet wifi can not do 128 with interpolation. only x16. Maestro can do x128 with interpolation
Adjust the E Steps accordingly.@dden said in Idle temperature hot-end and bed to high:
M305 P1 T98801 B4185 R2200 ; set thermistor + ADC parameters for heaterDuet Wifi has a Resistance of R4700. R2200 is duet Maestro
@Veti Thanks I will correct these settings.
@Veti I corrected the settings and now everything works like a charm. Thank you very much for your help. Much appreciated!!
@dden you can just leave the R value out. The firmware knows the proper value from the hardware.
@droftarts Thanks good to know.
