    3D GCode Viewer integrated with DWC
    Duet Web Control wishlist
    42
    284
    31.2k
    • Sindariusundefined
      Sindarius @PCR
      @PCR I've been waiting on that for over a year. I'll see if I want to spend the time converting it when that happens. For now...
      https://github.com/Sindarius/DuetWebControl/releases/tag/3.1.1-Sindarius
      • PCRundefined
        PCR
        In a thread someone said something about that.
        Edit: https://forum.duet3d.com/topic/18313/live-gcode-view
        Sindariusundefined 1 Reply Last reply Reply Quote 0
        • PCRundefined
          PCR
          @Sindarius Works great! Thank you for that
            Sindarius @PCR
            @PCR It's possible/probable they are developing their own 3d viewer for the DWC. The drive for my original development was that I needed the ability to see the model but also be able to see a color mixing approximation based on color mixing gcode on my M3D Crane Quad mixing head. I also use it when I have a print that just has several tools for my set of extruders, so it should work great for something like a tool changer. Not sure what they have worked on but I am sure it'll be good.
            by simply changing the colors loaded into the extruder I get a nice approximation of what the gradients / colors will look like.
              Sindarius
              Did some poking around at the 3.2 development baseline and it looks like they are using this package for their upcoming viewer.
              https://gcode-preview.web.app/
              • PCRundefined
                PCR
                @Sindarius The SBC Version do not work ;( it "hangs" at downloading Gcode
                  Sindarius @PCR
                  @PCR I don’t have a duet 3 nor a pi setup to test. Is there any message in the console? I wonder if it is the issue where you had to upload the web client twice for it to take.
                  • PCRundefined
                    PCR
                    @Sindarius i think i found the problem.
                    The SBC Version want to download the file via the
                    GET http://192.168.178.36/rr_download?name=0:/gcodes/lpc_adapter_case_bottom_0.2mm_PLA_MK3S_2h6m.gcode
                    command.
                    For the Duet SBC it should be
                    GET http://192.168.178.36/machine/file/0:/gcodes/lpc_adapter_case_bottom_0.2mm_PLA_MK3S_2h6m.gcode
                    In the browser it will download the file via the last command
                    More Info here : https://github.com/Duet3D/DuetSoftwareFramework#get-machinefilefilename
                    Sindariusundefined 1 Reply Last reply Reply Quote 1
                    • smoki3undefined
                      smoki3
                      @Sindarius
                      Very cool. I like the multi color implementation. Looks better than the visualizer on 3.2
                      So would be cool if this will also be available as an Plug In for 3.2. On my 3.2 build from yesterday, christian got the plugin system to work.
                        Sindarius @PCR
                        @PCR Thanks for looking into this. I will start looking at what it takes to make sure that the URL is correct for the SBC version. Hopefully I will have some time today/tomorrow to make the changes to it.
                        • PCRundefined
                          PCR
                          Thank you! honestly like your ones more than the one from 3.2
                          • PCRundefined
                            PCR
                            made this change to the fork of you!
                            https://github.com/P-C-R/DuetWebControl/commit/32c2e5279333cae02d4a80a39c5828be06b4ef5d
                            it works now on the SBC. But i cannot say it its "enough"
                            0 P-C-R committed to P-C-R/DuetWebControl
                            Update viewer.js
                            Sindariusundefined 2 Replies Last reply Reply Quote 1
                              Sindarius @PCR
                              @PCR That'll work for the SBC but then it will break the SD. I am looking at a way to detect if the DWC is SBC or SD and use that as a parameter in the viewer so both will work.
                                Sindarius @PCR
                                @PCR
                                If you could give this a shot and let me know. I added some code that will hopefully help determine if the DWC is SBC or SD and set an appropriate parameter for the viewer.
                                https://github.com/Sindarius/DuetWebControl/releases/tag/3.1.1-SBCFix
                                • PCRundefined
                                  PCR
                                  @Sindarius
                                  not working;(
                                  • PCRundefined
                                    PCR
                                     def __init__(self,base_url):
                                            self._base_url = base_url
                                            try:
                                                URL=(f'{self._base_url}'+'/rr_status?type=1')
                                                r = self.requests.get(URL,timeout=(2,60))
                                                j = self.json.loads(r.text)
                                                _=j['coords']
                                                self.pt = 2
                                                return
                                            except:
                                                try:
                                                    URL=(f'{self._base_url}'+'/machine/status')
                                                    _=j['result']
                                                    self.pt = 3
                                                    return
                                                except:
                                                    print(self._base_url," does not appear to be a RRF2 or RRF3 printer", file=self.sys.stderr)
                                                    return
                                    This was the logic @Danal code. RIP
                                      Sindarius @PCR
                                      @PCR I was trying to avoid having to query both paths but that may be unavoidable for now.
                                        Sindarius @PCR
                                        @PCR https://github.com/Sindarius/DuetWebControl/releases/tag/3.1.1-SBCFixV2
                                        Give this one a go if you get a chance.
                                        • danym21undefined
                                          danym21
                                          @Sindarius
                                          like I said in github it is working with the FixV2 on my SBC for me.
                                          many thx for the great work.
                                            Sindarius @danym21
                                            @danym21 I saw your message, thanks for the feedback and I am glad that it going for you guys 🙂
