    3D GCode Viewer integrated with DWC
    Duet Web Control wishlist
    42
    284
    31.6k
    • Dougal1957undefined
      Dougal1957 @Sindarius
      @Sindarius said in 3D GCode Viewer integrated with DWC:
      @Dougal1957 Delta support is on my down the road list at the moment. I would need to see if there is a way through the rest services to read M665/M666.
      I don't own a Delta but an early compromise would be to let you select the bed shape (circle/square) and let you adjust the radius of the bed for now. I am currently storing settings client side for the viewer and not on the duet/pi itself.
      That would be a fair compromise along with being able to set the origin although you could default it to be 0,0 in the centre of the bed. That would work but allowing the Origin to be set manually would be a good idea anyway as I do know some like to have it in the centre even on rectangular beds.
      another suggestion would be to show non print moves in a different colour as well (those without any E movement).
      Doug
      Sindariusundefined 1 Reply Last reply Reply Quote 1
      • Sindariusundefined
        Sindarius @Dougal1957
        @Dougal1957 I had non-print moves in there at one point and even with toggling just found them to be noise, which also reduces the amount of polygons that can be rendered for the models. Since I am not doing a line by line scrub bar I don't know that travel moves make much sense to visualize the model's end product.
          OK I can live with that it was just a suggestion and if you have tried it and it don't really work then that's fine.
          Doug
            Sindarius
            Did some mobile tweaks in a new release that is now availabe on github.
            https://www.youtube.com/watch?v=XxkoAm-oLH0&feature=youtu.be
            I plan to address the ui scaling in a future release.
            • AS-3D Druckundefined
              AS-3D Druck
              Is it possible to change this to a Tool to live view the current Layer in the sliced view?
              What i mean with this is shows the Print in Orange with 100 Opacity for example and the rest upcomming in Orange 50% Opacity with a few Things like Printtime and Layer Number etc.
              Is this possible?
              Best regards
              AS-3D Druck / Andre
                Sindarius
                It’s possible but my priority with this tool has mainly been to view the colors that are assigned by tool / m567 mixing as a preview. A few folks have asked for a live view. My early go will probably just adjust the z slider automatically on the side.
                • danym21undefined
                  danym21
                  @Sindarius
                  is it possible to have this also in DWC 3.1.1 for the Duet 3?
                  1 Reply Last reply Reply Quote 4
                  • PCRundefined
                    PCR
                    @Sindarius any possibility to update to 3.1.1
                    Sindariusundefined 1 Reply Last reply Reply Quote 0
                      Sindarius @PCR
                      @PCR I will start looking at updating my branch of the DWC with my 3D Viewer here soon. It has been a while since I updated it.
                      • PCRundefined
                        PCR
                        Or as a Plugin with 3.2 ;)))
                          Sindarius @PCR
                          @PCR I've been waiting on that for over a year. I'll see if I want to spend the time converting it when that happens. For now...
                          https://github.com/Sindarius/DuetWebControl/releases/tag/3.1.1-Sindarius
                          • PCRundefined
                            PCR
                            In a thread someone said something about that.
                            Edit: https://forum.duet3d.com/topic/18313/live-gcode-view
                            • PCRundefined
                              PCR
                              @Sindarius Works great! Thank you for that
                                Sindarius @PCR
                                @PCR It's possible/probable they are developing their own 3d viewer for the DWC. The drive for my original development was that I needed the ability to see the model but also be able to see a color mixing approximation based on color mixing gcode on my M3D Crane Quad mixing head. I also use it when I have a print that just has several tools for my set of extruders, so it should work great for something like a tool changer. Not sure what they have worked on but I am sure it'll be good.
                                by simply changing the colors loaded into the extruder I get a nice approximation of what the gradients / colors will look like.
                                  Sindarius
                                  Did some poking around at the 3.2 development baseline and it looks like they are using this package for their upcoming viewer.
                                  https://gcode-preview.web.app/
                                  • PCRundefined
                                    PCR
                                    @Sindarius The SBC Version do not work ;( it "hangs" at downloading Gcode
                                      Sindarius @PCR
                                      @PCR I don’t have a duet 3 nor a pi setup to test. Is there any message in the console? I wonder if it is the issue where you had to upload the web client twice for it to take.
                                      • PCRundefined
                                        PCR
                                        @Sindarius i think i found the problem.
                                        The SBC Version want to download the file via the
                                        GET http://192.168.178.36/rr_download?name=0:/gcodes/lpc_adapter_case_bottom_0.2mm_PLA_MK3S_2h6m.gcode
                                        command.
                                        For the Duet SBC it should be
                                        GET http://192.168.178.36/machine/file/0:/gcodes/lpc_adapter_case_bottom_0.2mm_PLA_MK3S_2h6m.gcode
                                        In the browser it will download the file via the last command
                                        More Info here : https://github.com/Duet3D/DuetSoftwareFramework#get-machinefilefilename
                                        • smoki3undefined
                                          smoki3
                                          @Sindarius
                                          Very cool. I like the multi color implementation. Looks better than the visualizer on 3.2
                                          So would be cool if this will also be available as an Plug In for 3.2. On my 3.2 build from yesterday, christian got the plugin system to work.
                                            Sindarius @PCR
                                            @PCR Thanks for looking into this. I will start looking at what it takes to make sure that the URL is correct for the SBC version. Hopefully I will have some time today/tomorrow to make the changes to it.
