    smart effector g32 issues
    576
      jay_s_uk @sankafola
      @sankafola I would increase the dive height in your first probe. That's the 'H' value in M558. Use something like 30
      sankafolaundefined 1 Reply Last reply Reply Quote 1
      • sankafolaundefined
        sankafola @jay_s_uk
        @jay_s_uk thanks that worked
          Once you have corrected your M665 and M666 values following auto calibration, you can reset the dive height to a lower value such as 5mm.
          sankafolaundefined 1 Reply Last reply Reply Quote 0
            sankafola @dc42
            @dc42 can you please help , i have SKR 1.4 turbo and i installed the Rerap 3 on it with SBC raspberry pi , and smart effector and magballs , i have connected the wires to the servo GND power 5v , and the output Z , the smart effector do the 2 flashes and do the probing and all is fine except when i print i have to do baby step + 0.8 , what am doing wrong do i need to put the mod pin and if yes where ? and how do i fix this babastep + 0.80 for good ?
              jay_s_uk
              @dc42 just to verify, currently he has the mod pin not connected.
              When setting the probe so its G31 settings are G31 P100 X0 Y0 Z-0.1, as is typical for the smart effector, 0.8mm of baby stepping is required to obtain a first layer.
              If the G31 is modified to G31 P100 X0 Y0 Z-0.75, 0.8mm of baby stepping is still required to obtain a first layer.
              any thoughts?
                The Smart Effector mod pin can be left disconnected if the default sensitivity is working.
                Z-0.75 is not usual, unless the bed or the delta mechanics are very soft. I suspect that either auto calibration has not been run, or the results from it have not been saved, or they have been saved in config-override.g but there is no M501 command in config-override.g.
                What are the M558 parameters, in particular the probing speed?
                sankafolaundefined 3 Replies Last reply Reply Quote 0
                  sankafola @dc42
                  @dc42 i ran the auto calibrate , the M501 is in the config and uncommented and my M558 is
                  M558 P8 H2 F1000 T12000 R0.2 S0.02 A5 C"servo0"
                    sankafola @dc42
                    @dc42 that is my config file
                    ; Configuration file for SKR v1.4 (firmware version 3)
                    ; generated by RepRapFirmware Configuration Tool v3.1.3-LPC-1 on Sat Aug 22 2020 07:45:45 GMT-0400 (Eastern Daylight Time)
                    M564 S0 H0
                    M550 P"Duet 3" ; set printer name
                    M665 R221.139 L440.43 B184.9 H400.752 ; Set delta radius, diagonal rod length, printable radius and homed height
                    M666 X-0.054 Y0.510 Z-0.456 ; put your endstop adjustments here, or let auto calibration find them
                    M569 P0 S0 ; physical drive 0 goes backwards using default driver timings
                    M569 P1 S0 ; physical drive 1 goes backwards using default driver timings
                    M569 P2 S0 ; physical drive 2 goes backwards using default driver timings
                    M569 P3 S1 ; physical drive 3 goes forwards using default driver timings
                    M92 X80.00 Y80.00 Z80.00 E435.00 ; set steps per mm BMG 415
                    M566 X1200.00 Y1200.00 Z1200.00 E1200.00 ; set maximum instantaneous speed changes (mm/min)
                    M203 X18000.00 Y18000.00 Z18000.00 E1200.00 ; set maximum speeds (mm/min)
                    M201 X1000.00 Y1000.00 Z1000.00 E1000.00 ; set accelerations (mm/s^2)
                    M906 X1000 Y1000 Z1000 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
                    M84 S30 ; Set idle timeout
                    ;M208 Z-3 S1 ; set minimum Z
                    M574 X2 S1 P"xstop" ; configure active-high endstop for high end on X via pin xstop
                    M574 Y2 S1 P"ystop" ; configure active-high endstop for high end on Y via pin ystop
                    M574 Z2 S1 P"zstop" ; configure active-high endstop for high end on Z via pin zstop
                    ;M558 P8 C"e1stop"H5 F600 T6000 ; set Z probe type to switch and the dive height + speeds
                    ;G31 P500 X7 Y7 Z17.80 ; set Z probe trigger value, offset and trigger height
                    ;M557 R85 S20 ; define mesh grid
                    G31 P100 X0 Y0 Z0.1
                    ;M558 P8 H4 F1000 T12000 R0.2 S0.02 A5 C"servo0+!probe"
                    ;M558 P8 C"!e1stop"H5 F600 T6000 ; set Z probe type to switch and the dive height + speeds
                    ; Heaters2
                    M950 H0 C"bed" T0 ; create bed heater output (2.5) on bed and map it to sensor 0
                    M308 S1 P"e0temp" Y"pt1000" R4700 ; configure sensor 1 as PT1000 on pin e0temp
                    M143 H1 S420 ; set temperature limit for heater 1 to 420C
                    ; Heater model parameters
                    ;M307 H0 A150.1 C573.4 D0.5 S1.00 V0.0 B0
                    ;M307 H1 A521.9 C138.6 D6.8 S1.00 V0.0 B0
                    ;M950 F0 C"fan0" Q500 ; create fan 0 on pin fan0 (2.3) and set its PWM frequency
                    ;M106 P0 S0 H-1 C"Parts Cooling" ; set fan 0 (P0) value to off. Thermostatic control is turned off (H-1)
                    ;M950 F1 C"e1heat" T1 ; create extruder fan output (2.4) on e1heat and map it to sensor 1 (T1)
                    ;M106 P1 R1 H1 T45 C"Hotend Cooling" ; thermostatically 45C controlled fan from T1 sensor
                    M950 F0 C"fan0" Q500 ; Create fan 0 on pin fan0 and set its frequency
                    M106 P0 S0 H-1 ; Set fan 0 value. Thermostatic control is turned off
                    M950 F1 C"e1heat" Q500 ; Create fan 1 on pin fan1 and set its frequency
                    M106 P1 S1 H1 T45 ; Set fan 1 value. Thermostatic control is turned on
                    ; Automatic saving after power loss
                    ;M911 S21.0 R23.0 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000"
                    M575 P1 S3 B57600 ; enable support for PanelDue a.k.a TFT35 V3.0
                    ; Uncomment M501 to load EEPROM file - config-override.g
                    M501 ; load saved parameters from config-override.g
                    T0 ; select T0 as active tool
                    ;G28 ; home the printer
                    G4 ; Wait for moves to finish
                    ;G28 ; to be sure, to be sure
                    ;M591 D0 P1 ;Run out sensor
                    M591 D0 P2 C"e0stop" S1 ; filament monitor connected to E0 endstop
                    • Vetiundefined
                      Veti @sankafola
                      @sankafola said in smart effector g32 issues:
                      G31 P100 X0 Y0 Z0.1
                      see https://duet3d.dozuki.com/Wiki/Gcode#Section_G31_Set_or_Report_Current_Probe_status
                      A G31 command to set Z probe parameters must come after the M558 command that defines the Z probe.
                      4138 is the default and wrong for your thermistor
                        sankafola @Veti
                        @Veti i have PT1000 thiermster what would be the value because am getting a lot of heater fault too what is the bed value and the hotend please ?/>
                        • Vetiundefined
                          Veti @sankafola
                          @sankafola
                          you have a pt1000 on your hotend, but your bed has a thermistor. which thermistor you have i can not tell you. you will have to look that up from the sales information.
                            sankafola @Veti
                            @Veti found it M308 S0 P"bedtemp" Y"thermistor" T100000 B4300 C0 R4700
                              sankafola @dc42
                              @dc42 the bed have the whambam with PEX maybe that is why ? what do i need to do ?
                                jay_s_uk
                                My machine has whambam PEX and I use the default 0.1 perfectly
                                  sankafola @jay_s_uk
                                  @jay_s_uk all good now did the procedure again for delta calibration and now seem fine thanks all for the help
