    smart effector g32 issues
    599
    • sankafolaundefined
      sankafola @dc42
      @dc42 can you please help , i have SKR 1.4 turbo and i installed the Rerap 3 on it with SBC raspberry pi , and smart effector and magballs , i have connected the wires to the servo GND power 5v , and the output Z , the smart effector do the 2 flashes and do the probing and all is fine except when i print i have to do baby step + 0.8 , what am doing wrong do i need to put the mod pin and if yes where ? and how do i fix this babastep + 0.80 for good ?
        jay_s_uk
        @dc42 just to verify, currently he has the mod pin not connected.
        When setting the probe so its G31 settings are G31 P100 X0 Y0 Z-0.1, as is typical for the smart effector, 0.8mm of baby stepping is required to obtain a first layer.
        If the G31 is modified to G31 P100 X0 Y0 Z-0.75, 0.8mm of baby stepping is still required to obtain a first layer.
        any thoughts?
          The Smart Effector mod pin can be left disconnected if the default sensitivity is working.
          Z-0.75 is not usual, unless the bed or the delta mechanics are very soft. I suspect that either auto calibration has not been run, or the results from it have not been saved, or they have been saved in config-override.g but there is no M501 command in config-override.g.
          What are the M558 parameters, in particular the probing speed?
          sankafolaundefined 3 Replies Last reply Reply Quote 0
            sankafola @dc42
            @dc42 i ran the auto calibrate , the M501 is in the config and uncommented and my M558 is
            M558 P8 H2 F1000 T12000 R0.2 S0.02 A5 C"servo0"
              sankafola @dc42
              @dc42 that is my config file
              ; Configuration file for SKR v1.4 (firmware version 3)
              ; generated by RepRapFirmware Configuration Tool v3.1.3-LPC-1 on Sat Aug 22 2020 07:45:45 GMT-0400 (Eastern Daylight Time)
              M564 S0 H0
              M550 P"Duet 3" ; set printer name
              M665 R221.139 L440.43 B184.9 H400.752 ; Set delta radius, diagonal rod length, printable radius and homed height
              M666 X-0.054 Y0.510 Z-0.456 ; put your endstop adjustments here, or let auto calibration find them
              M569 P0 S0 ; physical drive 0 goes backwards using default driver timings
              M569 P1 S0 ; physical drive 1 goes backwards using default driver timings
              M569 P2 S0 ; physical drive 2 goes backwards using default driver timings
              M569 P3 S1 ; physical drive 3 goes forwards using default driver timings
              M92 X80.00 Y80.00 Z80.00 E435.00 ; set steps per mm BMG 415
              M566 X1200.00 Y1200.00 Z1200.00 E1200.00 ; set maximum instantaneous speed changes (mm/min)
              M203 X18000.00 Y18000.00 Z18000.00 E1200.00 ; set maximum speeds (mm/min)
              M201 X1000.00 Y1000.00 Z1000.00 E1000.00 ; set accelerations (mm/s^2)
              M906 X1000 Y1000 Z1000 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
              M84 S30 ; Set idle timeout
              ;M208 Z-3 S1 ; set minimum Z
              M574 X2 S1 P"xstop" ; configure active-high endstop for high end on X via pin xstop
              M574 Y2 S1 P"ystop" ; configure active-high endstop for high end on Y via pin ystop
              M574 Z2 S1 P"zstop" ; configure active-high endstop for high end on Z via pin zstop
              ;M558 P8 C"e1stop"H5 F600 T6000 ; set Z probe type to switch and the dive height + speeds
              ;G31 P500 X7 Y7 Z17.80 ; set Z probe trigger value, offset and trigger height
              ;M557 R85 S20 ; define mesh grid
              G31 P100 X0 Y0 Z0.1
              ;M558 P8 H4 F1000 T12000 R0.2 S0.02 A5 C"servo0+!probe"
              ;M558 P8 C"!e1stop"H5 F600 T6000 ; set Z probe type to switch and the dive height + speeds
              ; Heaters2
              M950 H0 C"bed" T0 ; create bed heater output (2.5) on bed and map it to sensor 0
              M308 S1 P"e0temp" Y"pt1000" R4700 ; configure sensor 1 as PT1000 on pin e0temp
              M143 H1 S420 ; set temperature limit for heater 1 to 420C
              ; Heater model parameters
              ;M307 H0 A150.1 C573.4 D0.5 S1.00 V0.0 B0
              ;M307 H1 A521.9 C138.6 D6.8 S1.00 V0.0 B0
              ;M950 F0 C"fan0" Q500 ; create fan 0 on pin fan0 (2.3) and set its PWM frequency
              ;M106 P0 S0 H-1 C"Parts Cooling" ; set fan 0 (P0) value to off. Thermostatic control is turned off (H-1)
              ;M950 F1 C"e1heat" T1 ; create extruder fan output (2.4) on e1heat and map it to sensor 1 (T1)
              ;M106 P1 R1 H1 T45 C"Hotend Cooling" ; thermostatically 45C controlled fan from T1 sensor
              M950 F0 C"fan0" Q500 ; Create fan 0 on pin fan0 and set its frequency
              M106 P0 S0 H-1 ; Set fan 0 value. Thermostatic control is turned off
              M950 F1 C"e1heat" Q500 ; Create fan 1 on pin fan1 and set its frequency
              M106 P1 S1 H1 T45 ; Set fan 1 value. Thermostatic control is turned on
              ; Automatic saving after power loss
              ;M911 S21.0 R23.0 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000"
              M575 P1 S3 B57600 ; enable support for PanelDue a.k.a TFT35 V3.0
              ; Uncomment M501 to load EEPROM file - config-override.g
              M501 ; load saved parameters from config-override.g
              T0 ; select T0 as active tool
              ;G28 ; home the printer
              G4 ; Wait for moves to finish
              ;G28 ; to be sure, to be sure
              ;M591 D0 P1 ;Run out sensor
              M591 D0 P2 C"e0stop" S1 ; filament monitor connected to E0 endstop
              • Vetiundefined
                Veti @sankafola
                @sankafola said in smart effector g32 issues:
                G31 P100 X0 Y0 Z0.1
                see https://duet3d.dozuki.com/Wiki/Gcode#Section_G31_Set_or_Report_Current_Probe_status
                A G31 command to set Z probe parameters must come after the M558 command that defines the Z probe.
                4138 is the default and wrong for your thermistor
                sankafolaundefined 1 Reply Last reply Reply Quote 0
                  sankafola @Veti
                  @Veti i have PT1000 thiermster what would be the value because am getting a lot of heater fault too what is the bed value and the hotend please ?/>
                  • Vetiundefined
                    Veti @sankafola
                    @sankafola
                    you have a pt1000 on your hotend, but your bed has a thermistor. which thermistor you have i can not tell you. you will have to look that up from the sales information.
                      sankafola @Veti
                      @Veti found it M308 S0 P"bedtemp" Y"thermistor" T100000 B4300 C0 R4700
                        sankafola @dc42
                        @dc42 the bed have the whambam with PEX maybe that is why ? what do i need to do ?
                          jay_s_uk
                          My machine has whambam PEX and I use the default 0.1 perfectly
                          sankafolaundefined 1 Reply Last reply Reply Quote 1
                            sankafola @jay_s_uk
                            @jay_s_uk all good now did the procedure again for delta calibration and now seem fine thanks all for the help
