    Making it fit
    My Duet controlled machine
    delta duet3d wifi
    879
    • TinkerBillundefined
      TinkerBill
      So, whilst upgrading to metal corners I have ended up with the duet not being able to fit between my stepper motors (see pic - edit: Veti, was trying from mobile, pic now attached).
      I see my options as:
      1. get longer horizontal extrusions, providing more space, but needing a new heated bed/print surface
      2. go back to the worn plastic corners and make do
      3. be slightly mad and remove motor housing with a file to make this fit...
      As you can probably guess, I'd rather do 1 and continue upgrading. However I'm struggling to figure out what size bed (and where I'd get it, I'm uk based) for what size horizontals.
      All help appreciated
      DIY-O-Sphereundefined 1 Reply Last reply Reply Quote 0
      • Vetiundefined
        Veti
        picture requires access.
        when you upload a picture you have to wait after it reaches 100%
          TinkerBill
          Edited from desktop, should have pic visible now
          • fcwiltundefined
            fcwilt
            I would just cut longer pieces of extrusion.
            But I don't understand why that would require a new heated bed/print surface.
            TinkerBillundefined 1 Reply Last reply Reply Quote 0
              TinkerBill @fcwilt
              @fcwilt As it's a delta, with the print bed attached to the top of the base extrusions, extending the base extrusions will change the distance between the center of each extrusion where it currently mounts. Picture an equilateral triangle, with a circle touching the middle of each edge. Then make each edge longer, the circle will need to be larger.
              A Former User? fcwiltundefined 2 Replies Last reply Reply Quote 0
              • DIY-O-Sphereundefined
                DIY-O-Sphere @TinkerBill
                @TinkerBill
                One option might be to place it below the frame, adding feet.
                (UTC+1)
                  TinkerBill @DIY-O-Sphere
                  @DIY-O-Sphere I started debating to/on one side, rather than internal. Feet is a good call though, might do that. Thanks 🙂
                    A Former User @TinkerBill
                    @TinkerBill said in Making it fit:
                    or you could design mounts that allows you mount the existing bed inside a larger triangle; however in my world cutting new extrusions is way $$$ so I'd consider moving the duet to the top instead maybe?
                      TinkerBill @A Former User
                      @bearer the current extrusions are 230mm so I can get longer ones relatively easily online (circa £30-40 for the set from oozenest) rewiring to the top would mean making a new loom for a lot of the components which I'd rather avoid (currently don't have most my tools....)
                        A Former User
                        if you throw together a sketch of your current bed, incl mounting holes and the potential new extrusion lengths we might be able to suggest some mounting options
                          @bearer Current bed is 200mm diameter, 6 3mm holes seemingly evenly spaced around it, 7mm inset from edge to center of the hole. Pic is a brief sketch I threw together on F360.
                          New extrusions can be pretty much whatever length, though I'd probably max out at 300mm to keep the footprint small.
                          • fcwiltundefined
                            fcwilt @TinkerBill
                            But the print bed doesn't need to attach directly to the extrusions.
                            Make some mounting plates that attach to the extrusions and extend as needed to support the print bed.
                              TinkerBill @fcwilt
                              @fcwilt I don't have the tools to make something with sufficient precision unfortunately
                                When I found that my horizontal extrusions were a little too short, I printed short spacers to put at the ends. The spacers are short enough so that the vertices still screw into the extrusions.
                                • fcwiltundefined
                                  fcwilt @TinkerBill
                                  You have a 3D printer - that's what I used to make the pieces I needed - back when I had my delta printers.
                                  • Vetiundefined
                                    Veti
                                    here is another idea.
                                    print these https://www.thingiverse.com/thing:2519593
                                    they will also provide good noise dampening.
                                    now you have space underneath the delta where you can mount the duet without interfering with the motors.
