    Z probe wrong direction unless I zero Z
    1.1k
    • nick9one1undefined
      nick9one1
      ; generated by RepRapFirmware Configuration Tool v3.1.4 on Sat Sep 05 2020 23:57:30 GMT+0100 (British Summer Time)
      M80					       ; Turns on the ATX power supply
      G90                                            ; send absolute coordinates...
      M83                                            ; ...but relative extruder moves
      M550 P"BLV MGN Cube"                           ; set printer name
      M669 K1                                        ; select CoreXY mode
      M552 S1                                        ; enable network
      M586 P0 S1                                     ; enable HTTP
      M586 P1 S0                                     ; disable FTP
      M586 P2 S0                                     ; disable Telnet
      M569 P0 S0                                     ; physical drive 0 goes backwards
      M569 P1 S1                                     ; physical drive 1 goes forwards
      M569 P2 S1                                     ; physical drive 2 goes forwards
      M569 P3 S0                                     ; physical drive 3 goes backwards
      M584 X0 Y1 Z2 E3                               ; set drive mapping
      M350 X16 Y16 Z16 E16 I1                        ; configure microstepping with interpolation
      M92 X200.00 Y200.00 Z800.00 E415.5             ; set steps per mm
      M566 X600.00 Y600.00 Z24.00 E300.00            ; set maximum instantaneous speed changes (mm/min)
      M203 X20000.00 Y20000.00 Z600.00 E2000.00      ; set maximum speeds (mm/min)
      M201 X3000.00 Y3000.00 Z100.00 E5000.00        ; set accelerations (mm/s^2)
      M906 X1600 Y1600 Z1600 E1300 I30               ; set motor currents (mA) and motor idle factor in per cent
      M84 S30                                        ; Set idle timeout
      ; Pressure advance
      ; M572 D0 S0.05
      M208 X-23 Y0 Z0 S1                             ; set axis minima
      M208 X305 Y332 Z350 S0                         ; set axis maxima
      M564 H0					       ; allow jog without homing
      M574 X1 S1 P"xstop"                            ;
      M574 Y2 S1 P"ystop"                            ;
      M574 Z1 S2                                     ; configure Z-probe endstop for low end on Z
      M558 P1 H5 C"^zprobe.in" H5 F200 T9000 I0 R0.5 ; set Z probe type to switch and the dive height + speeds
      G31 P500 X-2 Y-16.4 Z1.33                      ; set Z probe trigger value, offset and trigger height
      M557 X10:292 Y5:300 P8                       ; define mesh grid
      M308 S0 P"bedtemp" Y"thermistor"T100000 B3950 C0 R4700 A"Bed Temp"  	; configure sensor 0 as thermistor on pin bedtemp
      M950 H0 C"bedheat" T0                          				; create bed heater output on bedheat and map it to sensor 0
      M140 H0                                        				; map heated bed to heater 0
      M143 H0 S100                                   				; set temperature limit for heater 0 to 120C
      M307 H0 A466.3 C1262.5 D12.8 S1.00 V24.0 B0    				; Set PID for heated bed values
      M308 S1 P"e0temp" Y"thermistor" T100000 B3950 C0 R4700 A"Hotend Temp"   ; configure sensor 1 as thermistor on pin e0temp
      M950 H1 C"e0heat" T1                           				; create nozzle heater output on e0heat and map it to sensor 1
      M143 H1 S260                              				; set temperature limit for heater 1
      M307 H1 A340.0 C140.0 D5.5 S1.00 V24.0 B0     				; Set PID for hotend values
      M950 F0 C"fan0" Q500                           ; create fan 0 on pin fan0 and set its frequency
      M106 P0 S0 H-1                                 ; set fan 0 value. Thermostatic control is turned off
      M950 F1 C"fan1" Q500                           ; create fan 1 on pin fan1 and set its frequency
      M106 P1 S1 H1 T45                              ; set fan 1 value. Thermostatic control is turned on
      M563 P0 D0 H1 F0                               ; define tool 0
      G10 P0 X0 Y0 Z0                                ; set tool 0 axis offsets
      G10 P0 R0 S0                                   ; set initial tool 0 active and standby temperatures to 0C
      ; homeall.g
      ; called to home all axes
      G91              	; relative positioning
      G1 H2 Z5 F500   	; lift Z relative to current position
      G1 H1 X-355 F6000 	; move quickly to X axis endstop and stop there (first pass)
      G1 H0 X5 F6000 		; go back a few mm
      G1 H1 X-355 F360  	; move slowly to X axis endstop once more (second pass)
      G90              	; absolute positioning
      G1 H1 Y355 F6000 	; move quickly to Y axis endstop and stop there (first pass)
      G1 H0 Y-5 F6000 	; go back a few mm
      G1 H1 Y326 F360  	; move slowly to Y axis endstop once more (second pass)
      G1 X152.5 Y152.5 F6000 	; go to first bed probe point and home Z
      G30                    	; home Z by probing the bed
        @nick9one1 said in Z probe wrong direction unless I zero Z:
        It's best not to use this on a regular basis and could be hiding other issues. It's meant to save you from a crash.
        Remove the H0 from your homing files. It's the default, so you don't need to specify it.
        When you jog your Z axis normally after homing (after you remove the M564) does Z+ move the bed away from the nozzle and Z- towards the nozzle?
        • fcwiltundefined
          fcwilt
          From the documentation when using your Z probe for homing:
          The S2 option of M574 is intended for use only when axes other than Z are using the Z probe for homing. The only printers known that do this using Duet electronics are the RepRapPro Ormerod, Huxley Duo, and Mendel Tricolour machines. When using the Z probe to home Z, M574 Z0 should be used.
          nick9one1undefined 2 Replies Last reply Reply Quote 0
            nick9one1 @fcwilt
            Done
            I will do after this issue is resolved - at the moment I need to raise the bed at least 300mm to home successfully.
              nick9one1
              Yes, the jog buttons work as expected, and I get good prints.
              G1 Z5 F6000 lowers the bed
              G1 Z-5 F6000 raises the bed
              When the bed is fully lowered at power on, I have to send this before a home;
              G1 Z-500 F6000
              G92 Z0
              If I dont send G92 Z0 the printer seems to attempt a probe in the wrong direction (Z+ instead of Z-). I think this is because it thinks the bed is at Z-500 (my G1 Z-500 command).
              If I attempt to home when the bed is fully lowered at power on, the bed raises about 1/2 way (Z-), then starts going to other way (Z+).
              It seems to me like there is a timeout or travel limit safety.
                nick9one1 @fcwilt
                @fcwilt
                M574 now looks like this;
                M574 Z1 S1 P"zstop"                          ;
                not
                Unfortunately the behaviour is still the same
                  jay_s_uk
                  What fcwilt meant was remove the M574 line for the endstop, unless you still have one on Z maximum.
                  Your M558 included an I0, which is not supported as part of RRF3.
                  Your Z maximum is set as 350mm. How large is it as you seem to be issuing a -600mm move which would indicate your Z axis is larger than 350mm
                    droftarts administrators @nick9one1
                    @nick9one1 this came up recently in another thread, where the M208 Z limit was much smaller then the actual Z movement. If the probe move has to move more than 1.1 times the M208 Z limit, probing is cancelled and it will try to move the bed back to Z0. So set you M208 Z limit to much closer to the actual size, eg Z600. You can always set up a fast Z home move, then slow Z home, if it’s painful to watch it home 600mm at slow speed!
                      nick9one1
                      @jay_s_uk said in Z probe wrong direction unless I zero Z:
                      Thanks!
                      I will remove I0 frm M558
                      I guess Z max here is probably the cause of the bed getting to half way then reversing. I will change to Z650 (Z is 650)
                      nick9one1undefined 1 Reply Last reply Reply Quote 0
                        nick9one1 @nick9one1
                        @droftarts said in Z probe wrong direction unless I zero Z:
                        I like the idea of a faster Z home, so will try that.
                        I'm also using a mini IR Z probe which seems to have similar behaviour when Z gets close.
                          jay_s_uk
                          I use
                          M558 F250 				 										; Set the probing speed
                          G30					 											; Probe a single point
                          M558 F30 				 										; Set a slower probing speed
                          In my Z homing file. That sets the first homing speed to just over 4mm/s and then 0.5mm/s. A similar change to your homing file would work for you.
                            Phaedrux Moderator @droftarts
                            @droftarts I thought it sounded familiar 😉
                              nick9one1
                              All working as expected now thankyou.
                              I think the key change was setting the correct Z height
                              now;
                              M208 X305 Y332 Z950 S0 ;
                              Full Gcode;
                              950 ; Configuration file for Duet WiFi (firmware version 3)
                              M906 X1500 Y1500 Z1500 E1100 I30               	; set motor currents (mA) and motor idle factor in per cent
                              ; Pressure advance
                              ; M572 D0 S0.05
                              M208 X305 Y332 Z950 S0                        	; set axis maxima
                              M574 Z1 S1 P"zstop"                            	; configure Z-probe endstop for low end on Z
                              M558 P1 H5 C"^zprobe.in" H5 F250 T9000 R0.5	; set Z probe type to switch and the dive height + speeds
                              G31 P500 X-2 Y-16.4 Z1.40                      	; set Z probe trigger value, offset and trigger height
                              M557 X10:292 Y5:300 P5                       	; define mesh grid
                              M143 H0 S100                                   				; set temperature limit for heater 0 to 100C
