    M48 Measure Z Probe repeatability and print to serial output.
    Firmware wishlist
    12
    28
    6.2k
      I've added a note to https://duet3d.dozuki.com/Wiki/G-Codes_not_implemented.
      • veng1undefined
        veng1
        The M48 without an X and Y location appears to simply move right to the end of travel.
        Could it be changed so that without X an Y, it probes at the current location?
        The intended use is:
        Probe_Corners.g
        ; Test repeatability at mesh bed compensation locations
        G1 X5 Y5
        M48
        G1 X300 Y5
        M48
        G1 X300 Y200
        M48
        G1 X5 Y200
        M48
          M48 in RepRapFirmware does nothing, unless you have a file called M48.g in the /sys folder (in which case, it executes that macro).
          joehsmashundefined 1 Reply Last reply Reply Quote 0
          • veng1undefined
            veng1
            @dc42 I understand that. The macro early in this thread that takes 10 measurements at the point X151 Y161 works fine in the /sys folder. However, if it is edited to remove the X and Y co-ordinates like:
            M291 P"Probe will be tested 10 times and return mean and standard deviation. Ok or Cancel?" R"WARNING" S3 ; User must click OK or cancel.
            G28
            G30 P0 Z-9999
            G30 P1 Z-9999
            G30 P2 Z-9999
            G30 P3 Z-9999
            G30 P4 Z-9999
            G30 P5 Z-9999
            G30 P6 Z-9999
            G30 P7 Z-9999
            G30 P8 Z-9999
            G30 P9 Z-9999 S-1
            it does not stay at the current position but moves in X. I believe it should just take 10 points at the current location without moving.
            • joehsmashundefined
              joehsmash @dc42
              @dc42 sorry to bring up such an old thread, but im having trouble trying to get this IR sensor to work.
              ive got the macro saved, but where to do i view the SD from the probed points?
                dc42 administrators @joehsmash
                @joehsmash said in M48 Measure Z Probe repeatability and print to serial output.:
                The final G30 command (with the S-1 parameter) should display the mean and standard deviation.
                • BoAundefined
                  BoA
                  Oh boy, this is some old thread. But... I actually tried G30 without X and Y parameters (G30 P0 Z-9999 - to be specific).
                  What it does it moves head according to pobe offset and basically probes in Z. However... it does not move the head back to original position. As soon as You give the X and Y this is not a problem, but probing current location few times basically requires explicitly moving head to the original position using relative move with X and Y set to Z probe offset after each G30. Is that intended behavior of G30?
                    @BoA said in M48 Measure Z Probe repeatability and print to serial output.:
                    That's normally how it's used in homeall. You position the probe manually with a G1 XY command to place the probe where you want, and then send G30 by itself to probe the bed, then you manually position the head where you want it with another G1 XYZ move.
                    BoAundefined 1 Reply Last reply Reply Quote 0
                    • BoAundefined
                      BoA @Phaedrux
                      @Phaedrux Yes. G30 without ANY parameter works fine, but as soon You use it like that: G30 P0 Z-9999 it move the head according to z probe offset.
                        Phaedrux Moderator @BoA
                        @BoA https://duet3d.dozuki.com/Wiki/Gcode#Section_G30_Single_Z_Probe
                        Using the P parameter implies providing an X Y coordinate.
                        • BoAundefined
                          BoA @Phaedrux
                          @Phaedrux So shoudn't it return an error if X and Y are not given?
                            @BoA I'll check.
                            • BoAundefined
                              BoA @Phaedrux
                              @Phaedrux Also... executing this G30 Px sequence causes printhead going outside of XY limits (which is understandable, as it allows to probe outside of bed area).
                                @BoA Yes that is mentioned too.
                                Caution: the XY coordinates are permitted to be outside the normal printable bed area! This is intentional, because some printers (e.g. delta printers) benefit from probing areas not used for printing.
                                • BoAundefined
                                  BoA @Phaedrux
                                  @Phaedrux That is true, and it is acceptable and even desired, but ONLY if you specify X and Y. And probing "current location" by G30 P0 Z-9999 should not lead to "brrr-brrr-brrr" noise from steppers 🙂
                                  But perhaps this is just my opinion.
                                  • Leavundefined
                                    Leav
                                    This is similar enough that I don't think it warrants its own thread.
                                    Is there a way to use multiple probes per point and use the average of those measurement as the Z height for that point.
                                    The script above gives me pretty good deviation (±0.005mm, and it's consistant enough that I imagine this is a actually the stepper resolution), but I still feel like double or triple probing would be a better practice.
                                    Is there a way to do this today? do you think it's worth implementing?
                                    BoAundefined fcwiltundefined 2 Replies Last reply Reply Quote 0
                                    • BoAundefined
                                      BoA @Leav
                                      @Leav When You define z probe with M558 there are params:
                                      Snnn Tolerance when probing multiple times, default 0.03mm
                                      and
                                      Annn Maximum number of times to probe each point, default 1.
                                      This probes until results are within defined tolerance.
                                      Not sure if this does averaging measurements tho
                                      Leavundefined 1 Reply Last reply Reply Quote 1
                                      • Leavundefined
                                        Leav @BoA
                                        @BoA
                                        Thanks! (link to g-code reference page)
                                        The A and S parameters control multiple probing. Probing is repeated until two consecutive probe attempts produce results that differ by no more than the S parameter; then the average of those two results is used. However, if the number of attempts specified by the A parameter is reached without getting two consecutive results within tolerance of each other, no further probe attempts are made and the average result of all the attempts is used.
                                        Looks like I could manipulate this to do exactly what I wanted! (1 femtometer repeatability goal, here I come!)
                                        • fcwiltundefined
                                          fcwilt @Leav
                                          @Leav said in M48 Measure Z Probe repeatability and print to serial output.:
                                          Using a S parameter of -1 results in averaging the number of readings specified by the A parameter.
                                          • ignacmcundefined
                                            ignacmc @dc42
                                            @dc42 If I use the macro:
                                            G28
                                            M401
                                            G30 P0 X151 Y161 Z-9999
                                            G30 P1 X151 Y161 Z-9999
                                            G30 P2 X151 Y161 Z-9999
                                            G30 P3 X151 Y161 Z-9999
                                            G30 P4 X151 Y161 Z-9999
                                            G30 P5 X151 Y161 Z-9999
                                            G30 P6 X151 Y161 Z-9999
                                            G30 P7 X151 Y161 Z-9999
                                            G30 P8 X151 Y161 Z-9999
                                            G30 P9 X151 Y161 Z-9999 S-1
                                            M402
                                            It probes on the center of the bed X=0, Y=0 (I am using a Delta). Shouldn't it probe on X=151, Y=161????
                                            Predator with Duet3 Mini 5+, Smarteffector v4 and LGX Lite Extruder
