    rehome.g not found
    2.5k
    • Marco Bonaundefined
      Marco Bona
      @Phaedrux, I also created a small macro that passed to the ends of the axes moving first X then Y and finally moving the diagonals increasing the speed of 1000 at each cycle and even this did not give problems
        Can you post some additional information?
        Results of M122, config.g, homing files, start.g, bed.g any other files that may get called in the chain between startup and starting a print.
          Marco Bona
          @Phaedrux ,I'm not on the printer now. I'll get you the files tomorrow evening. Do you need M122 results after the error appears?
            Phaedrux Moderator @Marco Bona
            @Marco-Bona said in rehome.g not found:
            Ideally.
              Marco Bona
              @Phaedrux, ecco i file:
              -M122 results after error appears:
              m122
              RepRapFirmware for Duet 3 MB6HC version 3.1.1 running on Duet 3 MB6HC v0.6 or 1.0 (SBC mode)
              Board ID: 08DJM-956L2-G43S4-6JKF0-3S86T-9A5YD
              Used output buffers: 1 of 40 (15 max)
              Static ram: 154604
              Dynamic ram: 164528 of which 28 recycled
              Exception stack ram used: 520
              Never used ram: 73536
              Tasks: NETWORK(ready,1968) HEAT(blocked,1188) CanReceiv(suspended,3424) CanSender(suspended,1432) CanClock(blocked,1436) TMC(blocked,68) MAIN(running,4952) IDLE(ready,76)
              Owned mutexes:
              Last reset 00:02:21 ago, cause: power up
              Last software reset at 2020-09-11 16:40, reason: User, spinning module LinuxInterface, available RAM 73508 bytes (slot 1)
              Software reset code 0x0010 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0444a000 BFAR 0x00000000 SP 0xffffffff Task MAIN
              Error status: 0
              MCU temperature: min 23.0, current 28.1, max 28.2
              Supply voltage: min 23.9, current 24.1, max 24.1, under voltage events: 0, over voltage events: 0, power good: yes
              12V rail voltage: min 12.0, current 12.0, max 12.1, under voltage events: 0
              Driver 0: ok, reads 29500, writes 26 timeouts 0, SG min/max 0/1023
              Driver 1: ok, reads 29500, writes 26 timeouts 0, SG min/max 0/1023
              Driver 2: standstill, reads 29500, writes 26 timeouts 0, SG min/max 0/1023
              Driver 3: standstill, reads 29496, writes 31 timeouts 0, SG min/max 0/1023
              Driver 4: standstill, reads 29511, writes 17 timeouts 0, SG min/max 0/0
              Driver 5: standstill, reads 29511, writes 17 timeouts 0, SG min/max 0/0
              Date/time: 2020-09-11 16:43:03
              Slowest loop: 7.11ms; fastest: 0.13ms
              === Storage ===
              Free file entries: 10
              Hiccups: 0(0), FreeDm: 375, MinFreeDm: 372, MaxWait: 43407ms
              === MainDDARing ===
              Scheduled moves: 30, completed moves: 30, StepErrors: 0, LaErrors: 0, Underruns: 0, 0  CDDA state: -1
              === AuxDDARing ===
              Bed heaters = 0 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamberHeaters = 3 -1 -1 -1
              Segments left: 0
              Movement lock held by File
              HTTP* is ready with "M122" in state(s) 0
              Telnet is idle in state(s) 0
              File* is idle in state(s) 43 0 0, running macro
              USB is idle in state(s) 0
              Aux is idle in state(s) 0
              Queue is idle in state(s) 0
              LCD is idle in state(s) 0
              SBC is idle in state(s) 0
              Daemon* is idle in state(s) 0 0, running macro
              Aux2 is idle in state(s) 0
              Autopause* is idle in state(s) 0
              Code queue is empty.
              === Network ===
              Slowest loop: 1.28ms; fastest: 0.01ms
              HTTP sessions: 0 of 8
              - Ethernet -
              State: disabled
              Error counts: 0 0 0 0 0
              === CAN ===
              Messages sent 547, longest wait 2ms for type 6011
              === Linux interface ===
              State: 0, failed transfers: 0
              Last transfer: 18ms ago
              RX/TX seq numbers: 3923/3924
              SPI underruns 0, overruns 0
              Number of disconnects: 0
              Buffer RX/TX: 120/192-0
              === Duet Control Server ===
              Duet Control Server v3.1.1
              File:
              Buffered code: G30 P1 X140 Y0 Z-99999 S2 ; right lead screw
              Buffered code: M402 ; retract the Z probe
              Buffered code: G29 ; probe the bed and enable compensation
              ==> 112 bytes
              Executing macro bed.g, started by G32
              > Next stack level
              Executing macro start.g, started by system
              Suspended code: G1 Z10 F800
              Suspended code: G1 X0 Y0 F8000 ;go to the center of bed
              Suspended code: G30 X0 Y0 S-2 ;probe current position and ajust Z offset
              Suspended code: G1 Z40 F1000 ;go to Z40
              Suspended code: M584 P5
              Suspended code: M98 P"homev.g"
              Suspended code: M584 P3
              Suspended code: G1 X-137 Y120 F8000 ;go to X-137 Y160
              Suspended code: ;M42 P6 S50
              Suspended code: G4 S1
              > Next stack level
              Suspended code: T0
              Suspended code: M82 ;absolute extrusion mode
              Suspended code: ;Sliced at: Wed 09-09-2020 18:17:10
              Suspended code: M104 T0 S175
              Suspended code: M190 S50
              Suspended code: M109 S205
              Suspended code: T0
              Suspended code: G21
              Suspended code: G90
              Suspended code: G92 E0
              Suspended code: G1 X-50 Z2.5 E20 F1500
              Suspended code: G1 X50 Z0.15 F1000
              Suspended code: M117 P"rinting..."
              Suspended code: ;
              Suspended code: ;T0                             ;switch to extruder 1
              Suspended code: ;G92 E0                      ;reset extruder distance
              Suspended code: ;G1 F2000 E93           ;load filament
              Suspended code: ;M104 S205
              Suspended code: ;
              Suspended code: M83 ;relative extrusion mode
              Suspended code: G10
              Suspended code: ;LAYER_COUNT:96
              Suspended code: ;LAYER:0
              Suspended code: M107
              Daemon:
              Finishing macro daemon.g, started by system
              > Next stack level
              Code buffer space: 3904
              Full transfers per second: 23.89
              File /opt/dsf/sd/gcodes/White_minnow_rev1.gcode is selected, processing
              -Varius file:start.g rehome.g probe.g homeall.g customconfig.g config-override.g config.g bed.g
              I think there should be everything.
              Thank you
                Marco Bona
                @Phaedrux, after upgrading to 3.2 the problem persists.
                I found that the error (Warning: Macro file rehome.g not found) is also displayed when I launch the macro with M98 P "rehome.g".
                Have you had the opportunity to verify?
                  Marco Bona
                  @Phaedrux, i found the problem. The file name had a space after the .g file extension. Sorry but it wasn't easy to see.
                  Eliminating the space works correctly.
                  It remains to be understood why when I print, motorss continue to stall while if I start "start.g" from the console machine works correctly.
                  I look forward to some help from you if possible.
                  Thank you
                  droftartsundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
                    droftarts administrators @Marco Bona
                    @Marco-Bona This is the start of the gcode you posted earlier:
                    ;FLAVOR:RepRap
                    ;TIME:1692
                    ;Filament used: 1.00837m, 0m
                    ;Layer height: 0.15
                    ;MINX:-9.255
                    ;MINY:-35.116
                    ;MINZ:0.15
                    ;MAXX:9.259
                    ;MAXY:34.982
                    ;MAXZ:14.4
                    ;POSTPROCESSED
                    ;Generated with Cura_SteamEngine mb-master-20200822
                    T0
                    ;Sliced at: Sun 06-09-2020 12:09:56
                    M104 T0 S175
                    M190 S50
                    M109 S205
                    T0
                    G21
                    G90
                    G92 E0
                    G92 E0
                    G1 X50  Z0.15 F1000
                    M117 Printing...
                    ;M104 S205
                    G10
                    ;LAYER_COUNT:96
                    G92 E0
                    ;LAYER:0
                    M107
                    M204 T1000
                    M566 X600 Y600
                    G0 F2400 X6.196 Y0.892 Z0.15
                    M204 P500
                    ;TYPE:SKIRT
                    G11
                    G1 F2100 X6.391 Y3.65 E0.07207
                    G1 X6.657 Y6.33 E0.0702
                    G1 X7.007 Y9.063 E0.07182
                    G1 X7.427 Y11.74 E0.07064
                    G1 X7.926 Y14.423 E0.07114
                    It has these lines:
                    M204 T1000
                    M566 X600 Y600
                    M204 P500
                    M204 is setting acceleration for travel moves to 1000mm/s^2 and printing moves to 500mm/s^2, and M566 sets jerk for X and Y. Are these correct values?
                      Sorry can you explain that again?
                      When you start a print, start.g will get called automatically.
                        Marco Bona
                        @droftarts, I think they are correct, I usually use those parameters without problems, do they seem excessive to you?
                        Sorry, but start.g comes before those lines, always takes the first values it finds in gcode file?
                        @Phaedrux, exactly, start.g is automatically called up at the start of printing.
                        I explain the problem (setting M915 S3):
                        • if I start a print during the execution of start.g, X and Y motors stall continuously (then I suspend print because it does not probe bed correctly)
                          -if I start "start.g" from the DWC console with M98 "start.g", machine works perfectly.
                          I think isn't related to the sensitivity of the stall detection otherwise I think I should have same problem in both cases.
                          Again, this doesn't make sense. When you start a print, start.g will be executed. Why would you start a print while start.g is executing?
                            Marco Bona
                            @Phaedrux , They are 2 separate operations. I'm saying that if I start printing the machine behaves in one way while if I start only start.g with the print canceled the printer behaves in another way. I don't repeat start.g while the machine is paused. Clear?
                            I think it takes some value when starting the program which creates some errors.
                            droftartsundefined 2 Replies Last reply Reply Quote 0
                              @Marco-Bona This is the start.g you posted earlier in the thread.
                              G4 S1
                              M117 Preparing            ;write Preparing
                              G4 S1                     ;delay 1 seconds
                              M280 P0 S160                  ; Send PWM channel 0 the s160 (angle) command
                              M84 V;
                              ; If the printer hasn't been homed, home it
                              if !move.axes[0].homed || !move.axes[1].homed || !move.axes[2].homed
                                G28
                              M42 P6 S40
                              G21                       ;metric values
                              G90                       ;absolute positioning
                              M107                      ;start with the fan off
                              G1 X0 Y0 F10000            ;
                              G1 Z20 F1000               ;
                              M98 P"probe.g"            ;
                              T2 P0                     ;
                              G1 R2 X0 Y0 Z0 F5000      ;
                              G32                       ;
                              G1 Z10 F800               ;
                              M584 P5
                              M98 P"homev.g"
                              M584 P3
                              ;M42 P6 S50
                              G4 S1
                              As you have a start.g, it runs first when a print is run. If you run start.g yourself (with M98 P"start.g") then start a print, it will run start.g again. So possibly running start.g once causes an issue, but twice fixes it. I can't see anything obvious, though start.g seems largely related to homing the V axis, and you haven't linked homev.g. Please post that too.
                                @Marco-Bona Also, in config.g I noticed:
                                M350 X16 Y16 Z16 W16 16 V16 E32:32 I1 ; configure microstepping with interpolation
                                There needs to be a 'U' before the '16', eg:
                                M350 X16 Y16 Z16 W16 U16 V16 E32:32 I1                             ; configure microstepping with interpolation
                                Marco Bonaundefined 1 Reply Last reply Reply Quote 1
                                  What happens if you step through the start.g manually command by command?
                                  You say after a print is canceled. What do you have in pause.g cancel.g and stop.g?
                                  What else do you have in your slicer start gcode?
                                    Marco Bona @droftarts
                                    @droftarts said in rehome.g not found:
                                    fantastic, correct immediately.
                                    @Phaedrux , @droftarts, sorry but I can't be clear, I'm saying that stall warning occurs only and exclusively when a print is started, if I turn on the printer and execute M98 P "start.g", machine executes the command correctly, I can repeat command at infinity that will always work.
                                    Instead, if I start any printout, stall warning continues to appear.
                                    Again, I assume it is something that conflicts with Cura, but I don't understand what it could be.
                                    If necessary I can post a video.
                                    I am attaching the files you asked me, i am realizing that cancel.g is missing, is that a problem?
                                    homev.g pause.g stop.g
                                      Phaedrux Moderator @Phaedrux
                                      @Phaedrux said in rehome.g not found:
                                      Can you post a sample gcode?
                                        Marco Bona
                                        @Phaedrux ,
                                          M84 V;
                                          I think it has something to do with homing V and the high steps per mm.
                                          M92 U37.67 V5245.9
                                          What is the V axis?
                                          The start.g turns off the V motor and then homes all axis if an axis isn't homed, so it runs G28. Then you call the probe. and then below again it calls homev with a M98 instead of a G28 V and then rehides the axis.
                                          Then in your slicer end gcode you have M98 P"end.g". What is in end.g?
                                          You don't have a cancel.g so when you cancel a print it's calling stop.g, or it should anyway.
                                            Marco Bona
                                            @Phaedrux, V axis is a small motor that raises the second tool when not in use.
                                            It turns off the V motor because if it stays on it causes me disturbances during probing.
                                            M98 P "homev.g" and G28 V should do the same thing.
                                            end.g
