Need Probe Setup Help
M558
Error: M558: Z probe 0 not found -
I've just realised why. You've used a duet 3 pin name with a duet 2.
Where do you have it connected? -
At position E0 on the endstop connectors
change your command to
M558 P8 C"!e0stop" H5 F300 T6000 R0.4
Before you ask:
m558
Z Probe 0: type 8, input pin !e0stop, output pin nil, dive height 5.0mm, probe speed 300mm/min, travel speed 6000mm/min, recovery time 0.44 sec, heaters normal, max taps 1, max diff 0.03 -
Run G30 and see if it probes.
I would make sure you've homed your machine using G28 and then tap the probe on the way down to make sure it stops -
@jay_s_uk
"Probe already triggered"Remove exclamation point from 558?
yes please
Great progress! G30 starts probe quite slowly, stops immediately when triggered and raises up a bit.
Do it again with probe? -
now you've got the height set you can G32 (assuming your bed file is correct)
Sorry - took a bit of doing, but G32 yields a 6 point probe. You are awesome. Now, M500?
@1d1 yep.
Excellent. Can I buy you a beer? Your time and effort is much appreciated.
No need. I prefer to see people being able to print
Well, great! Many thanks.
Interested in one more area I need some help with? Regarding Fan pins and activation...
Never mind - I actually found the problem on my own. Hard to believe.... !
Thanks again...
