    Need Probe Setup Help
    Firmware installation
    1.3k
      jay_s_uk
      I've just realised why. You've used a duet 3 pin name with a duet 2.
      Where do you have it connected?
      • 1d1undefined
        1d1
        At position E0 on the endstop connectors
          jay_s_uk
          change your command to
          M558 P8 C"!e0stop" H5 F300 T6000 R0.4
          • 1d1undefined
            1d1
            @jay_s_uk said in Need Probe Setup Help:
            Done.
            • 1d1undefined
              1d1
              Before you ask:
              m558
              Z Probe 0: type 8, input pin !e0stop, output pin nil, dive height 5.0mm, probe speed 300mm/min, travel speed 6000mm/min, recovery time 0.44 sec, heaters normal, max taps 1, max diff 0.03
                jay_s_uk
                Run G30 and see if it probes.
                I would make sure you've homed your machine using G28 and then tap the probe on the way down to make sure it stops
                1d1undefined 1 Reply Last reply Reply Quote 0
                • 1d1undefined
                  1d1 @jay_s_uk
                  @jay_s_uk
                  "Probe already triggered"
                  Remove exclamation point from 558?
                    jay_s_uk
                    yes please
                    • 1d1undefined
                      1d1
                      Great progress! G30 starts probe quite slowly, stops immediately when triggered and raises up a bit.
                      Do it again with probe?
                        jay_s_uk
                        now you've got the height set you can G32 (assuming your bed file is correct)
                        • 1d1undefined
                          1d1
                          Sorry - took a bit of doing, but G32 yields a 6 point probe. You are awesome. Now, M500?
                            jay_s_uk @1d1
                            @1d1 yep.
                            • 1d1undefined
                              1d1
                              Excellent. Can I buy you a beer? Your time and effort is much appreciated.
                                jay_s_uk
                                No need. I prefer to see people being able to print
                                • 1d1undefined
                                  1d1
                                  Well, great! Many thanks.
                                  Interested in one more area I need some help with? Regarding Fan pins and activation...
                                  • 1d1undefined
                                    1d1
                                    Never mind - I actually found the problem on my own. Hard to believe.... !
                                    Thanks again...
