    Need Probe Setup Help
    Firmware installation
    1.3k
    • 1d1undefined
      1d1
      At position E0 on the endstop connectors
        jay_s_uk
        change your command to
        M558 P8 C"!e0stop" H5 F300 T6000 R0.4
        • 1d1undefined
          1d1
          @jay_s_uk said in Need Probe Setup Help:
          Done.
          • 1d1undefined
            1d1
            Before you ask:
            m558
            Z Probe 0: type 8, input pin !e0stop, output pin nil, dive height 5.0mm, probe speed 300mm/min, travel speed 6000mm/min, recovery time 0.44 sec, heaters normal, max taps 1, max diff 0.03
              jay_s_uk
              Run G30 and see if it probes.
              I would make sure you've homed your machine using G28 and then tap the probe on the way down to make sure it stops
              1d1undefined 1 Reply Last reply Reply Quote 0
              • 1d1undefined
                1d1 @jay_s_uk
                @jay_s_uk
                "Probe already triggered"
                Remove exclamation point from 558?
                  jay_s_uk
                  yes please
                  • 1d1undefined
                    1d1
                    Great progress! G30 starts probe quite slowly, stops immediately when triggered and raises up a bit.
                    Do it again with probe?
                      jay_s_uk
                      now you've got the height set you can G32 (assuming your bed file is correct)
                      • 1d1undefined
                        1d1
                        Sorry - took a bit of doing, but G32 yields a 6 point probe. You are awesome. Now, M500?
                          jay_s_uk @1d1
                          @1d1 yep.
                          • 1d1undefined
                            1d1
                            Excellent. Can I buy you a beer? Your time and effort is much appreciated.
                              jay_s_uk
                              No need. I prefer to see people being able to print
                              • 1d1undefined
                                1d1
                                Well, great! Many thanks.
                                Interested in one more area I need some help with? Regarding Fan pins and activation...
                                • 1d1undefined
                                  1d1
                                  Never mind - I actually found the problem on my own. Hard to believe.... !
                                  Thanks again...
