    unusual/unnerving noises + error codes
    4.2k
    • PR1ORundefined
      PR1OR @Phaedrux
      @Phaedrux
      So i got to step 4
      'With the Z probe deployed (if applicable) but not close enough to the bed to trigger it, check that the Z probe reading in Duet Web Control is zero or close to zero.'
      its not showing the right distance i dont think
        That's not the Z probe reading it's talking about.
        It should either show 0 or 1000. In the case of the BLtouch it should show 0 most of the time and when it triggers it would very briefly flash 1000.
        PR1ORundefined 1 Reply Last reply Reply Quote 0
        • PR1ORundefined
          PR1OR @Phaedrux
          @Phaedrux
          Where would i see that?
            The bottom right corner of that same display box under the heading Z-Probe
            • PR1ORundefined
              PR1OR @Phaedrux
              @Phaedrux so im not sure what just happened but it seems to be working now however when homing the x axis it shakes for a couple seconds and then is fine. the y axis homes but stays to far away so i had to manually flick the bl touch probe. But it worked. Is this just playing around with the axis limits?
                Well you should still verify the basics.
                I suggest you take a look through these guides.
                https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Maestro+Guide+Part+3:+Commissioning/39
                https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Maestro+Guide+Part+4:+Calibration/40
                • PR1ORundefined
                  PR1OR @Phaedrux
                  @Phaedrux
                  Thank you for this!!! i now have everything homing correctly and no weird noises or shaking which is great.
                  Apologies for this, i am trying to find pages that help and i really appeciate all the help you have given me to far. But...
                  I have been following this
                  Ive got to step 8 and as soon as i get to roughly 30 degree it stops and shows this message
                  Error: Heater 0 fault: temperature rising much more slowly than the expected 1.7°C/sec
                  i did some googling and found this
                  https://duet3d.dozuki.com/Wiki/Tuning_the_heater_temperature_control#Section_RRF_3_x_Error_Heater_0_fault_temperature_rising_much_more_slowly_than_the_expected_1_7_C_sec
                  it says i need to do this 'Therefore, you must perform a PID auto tuning to give the firmware a model for bed heater performance. Failure to do so will result in an error message that the heater temperature is not rising fast enough'
                  But i dont know what a PID is or how to run it. Are you able to help with this?
                    Pid tuning is part of the calibration guide.
                    • PR1ORundefined
                      PR1OR
                      So i have no idea what happened but i have tried to connect this morning and it doent seem to be connecting to the wifi. I noticed that when i turn it on. the Blue LED (wifi LED) go straight to a solid blue rather than flickering a bit while connecting. . I have plugged it in with the USB and went into terminal and i dont seem to be able to get it into idle. I can turn it off using M552 S-1 but when checking the status of the wifi using M552 it says 'WiFi module is being started' and when putting M587 it returns 'Error: M587: Failed to retrieve network list'
                      Any ideas on how i can connect again?
                      • PR1ORundefined
                        PR1OR @PR1OR
                        @PR1OR ive advanced. By using M997 S1 however it keeps reverting back again. Is there a code i need to put in to stop it 'forgetting'?
                          And you have m552 S1 in your config.g?
                          If you send m122 at the end of the report it should show some wifi info. Post that here..
                          • PR1ORundefined
                            PR1OR @Phaedrux
                            @Phaedrux said in unusual/unnerving noises + error codes:
                            m122
                            RepRapFirmware for Duet 2 WiFi/Ethernet version 3.1.1 running on Duet WiFi 1.02 or later
                            Board ID: 08DJM-9178L-L2MSD-6JKF6-3SD6R-1TDUN
                            Used output buffers: 3 of 24 (11 max)
                            Static ram: 27980
                            Dynamic ram: 93936 of which 24 recycled
                            Exception stack ram used: 264
                            Never used ram: 8868
                            Tasks: NETWORK(ready,384) HEAT(blocked,1224) MAIN(running,1816) IDLE(ready,80)
                            Owned mutexes: WiFi(NETWORK)
                            Last reset 00:03:30 ago, cause: software
                            Last software reset at 2020-09-18 19:00, reason: User, spinning module GCodes, available RAM 8636 bytes (slot 3)
                            Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f000 BFAR 0xe000ed38 SP 0xffffffff Task MAIN
                            Error status: 0
                            MCU temperature: min 37.8, current 38.3, max 38.8
                            Supply voltage: min 23.7, current 23.8, max 24.0, under voltage events: 0, over voltage events: 0, power good: yes
                            Date/time: 2020-09-18 19:04:28
                            Cache data hit count 369890305
                            Slowest loop: 5.90ms; fastest: 0.12ms
                            === Storage ===
                            Free file entries: 10
                            SD card longest read time 1.0ms, write time 0.0ms, max retries 0
                            Hiccups: 0(0), FreeDm: 169, MinFreeDm: 169, MaxWait: 0ms
                            === MainDDARing ===
                            Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
                            === AuxDDARing ===
                            Heater 1 is on, I-accum = 0.0
                            Segments left: 0
                            Movement lock held by null
                            HTTP is idle in state(s) 0
                            Telnet is idle in state(s) 0
                            File is idle in state(s) 0
                            USB is idle in state(s) 0
                            Aux is idle in state(s) 0
                            Trigger is idle in state(s) 0
                            Queue is idle in state(s) 0
                            Daemon is idle in state(s) 0
                            Code queue is empty.
                            === Network ===
                            Slowest loop: 119.41ms; fastest: 0.00ms
                            HTTP sessions: 1 of 8
                            • WiFi -
                              Network state is active
                              WiFi firmware version 1.23
                              WiFi MAC address cc:50:e3:32:51:9f
                              WiFi Vcc 3.41, reset reason Unknown
                              WiFi flash size 4194304, free heap 20544
                              WiFi IP address 192.168.1.145
                              WiFi signal strength -50dBm, reconnections 0, sleep mode modem
                              Socket states: 0 4 0 0 0 0 0 0
                            • PR1ORundefined
                              PR1OR
                              So it seems to be working ok now which is good. but when going for a test print i reserve this
                              Error: Fan number 2 not found
                              Error: Invalid tool number
                              Warning: Tool 0 was not driven because its heater temperatures were not high enough or it has a heater fault
                              the Fan i think can probably wait til a little later but the tool i feel is an issue
                                I think you should try a different slicer. Something is not right in your simplify3d setup.
                                Are you using the config.g from the set I provided? Can you post what you have now? Copy and paste from the config.g edit window or upload the file here.
                                All of your hardware works when you control it from the web interface, but when you try to print a file sliced in simplify 3d it doesn't work. I think your printer profile in S3D is setup for a different printer. I don't use S3D so I'm not much help there.
                                • PR1ORundefined
                                  PR1OR @Phaedrux
                                  simplify 3d
                                  yeah using the your one.
                                  ; generated by RepRapFirmware Configuration Tool v3.1.4 on Wed Sep 16 2020 13:09:04 GMT-0600 (Central Standard Time)
                                  M550 P"Duet2Wifi" ; set printer name
                                  M552 S1 ; enable network
                                  M586 P0 S1 ; enable HTTP
                                  M586 P1 S0 ; disable FTP
                                  M586 P2 S0 ; disable Telnet
                                  M569 P0 S0 ; physical drive 0 goes backwards
                                  M569 P1 S1 ; physical drive 1 goes backwards
                                  M569 P3 S0 ; physical drive 3 goes forwards
                                  M350 X16 Y16 Z16 E16 I1 ;a configure microstepping with interpolation
                                  M92 X80.00 Y80.00 Z400.00 E93.00 ; set steps per mm
                                  M566 X900.00 Y900.00 Z12.00 E1200.00 ; set maximum instantaneous speed changes (mm/min)
                                  M906 X600 Y600 Z600 E600 I30 ; set motor currents (mA) and motor idle factor in per cent
                                  M84 S30 ; Set idle timeout
                                  M208 X-5.5 Y-10 Z0 S1 ; set axis minima
                                  M208 X220 Y220 Z250 S0 ; set axis maxima
                                  M950 S0 C"exp.heater3" ; create servo pin 0 for BLTouch
                                  M558 P9 C"^zprobe.in" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
                                  G31 P500 X-31 Y0 Z0.6 ; set Z probe trigger value, offset and trigger height
                                  M557 X9.5:220 Y5:195 S20 ; define mesh grid
                                  M308 S0 P"bedtemp" Y"thermistor" T98801 B4185 ; configure sensor 0 as thermistor on pin bedtemp
                                  M308 S1 P"e0temp" Y"thermistor" T98801 B4185 ; configure sensor 1 as thermistor on pin e0temp
                                  M106 P0 C"Heatsink" S0 H-1 ; set fan 0 name and value. Thermostatic control is turned off
                                  M106 P1 C"PartCooling" S1 H1 T45 ; set fan 1 name and value. Thermostatic control is turned on
                                  M950 F1 C"fan2" Q500 ; create fan 2 on pin fan2 and set its frequency
                                  M106 P1 C"ExtruderCooling" S1 H1 T45 ; set fan 2 name and value. Thermostatic control is turned on
                                  M563 P0 S"Extruder 01" D0 H1 F0 ; define tool 0
                                  T0 ; select first tool
                                  So i didnt use a slicer there was a gcode on the interface for the benchy so i thought id try that. Im just downloading cura now so will try again and see what happens
                                    Phaedrux Moderator @PR1OR
                                    @PR1OR said in unusual/unnerving noises + error codes:
                                    This defined the fans and tool.
                                    The tool uses fan 0 for part cooling, extruder 0 for the motor, and heater 1 for the hotend.
                                    The hotend heatsink fan is fan1.
                                    Fan 2 is being used as maybe a duet board cooling, but maybe you don't have anything connected to fan2?
                                    You won't be able to print old gcode, you'll need to slice a new file.
                                    You'll have to setup Cura with a new printer profile. Make sure to tell it you are using reprap gcode flavor.
                                    • PR1ORundefined
                                      PR1OR @Phaedrux
                                      @Phaedrux perfect i think i have this right.
                                      I think i only have two things left wooohooo
                                      1. I have two fan bars on the DWC but they only seem to move together and not individually. How would i make them independant?
                                      2. When doing the true bed leveling i keep getting this response. But i can see where to amend either G32 or G29
                                        Warning: Skipping grid point (190.0, 60.0) because Z probe cannot reach it
                                        Warning: Skipping grid point (210.0, 60.0) because Z probe cannot reach it
                                        Warning: Skipping grid point (210.0, 80.0) because Z probe cannot reach it
                                        Warning: Skipping grid point (190.0, 80.0) because Z probe cannot reach it
                                        19/09/2020, 11:36:03 G29
                                        Warning: Skipping grid point (190.0, 20.0) because Z probe cannot reach it
                                        Warning: Skipping grid point (210.0, 20.0) because Z probe cannot reach it
                                        Warning: Skipping grid point (210.0, 40.0) because Z probe cannot reach it
                                        Warning: Skipping grid point (190.0, 40.0) because Z probe cannot reach it
                                        Those two sliders are for the same thing. The tool fan slider is for the fan of the currently selected tool, which is fan0, and the fan0 slider is for fan0. If you had two tools with different fans, the tool slider would always control the fan of the currently selected tool and you'd have 2 sliders for each fan as well. There is a little button link near the fan sliders "change visibility" that will let you hide one of you like since you only have 1 tool.
                                        To get rid of those errors we need to change the M557 grid spacing to take your probe offset into account because it can't reach some of the areas you're asking it to.
                                        Try M557 X5:185 Y5:205 P6
                                        • PR1ORundefined
                                          PR1OR @Phaedrux
                                          @Phaedrux Ahh ok fine thats ok then ill just hide one of them
                                          in regard to the M557 X5:185 Y5:205 P6 i have updated this.
                                          and am now getting this
                                          G32
                                          Warning: Skipping grid point (5.0, 5.0) because Z probe cannot reach it
                                          Warning: Skipping grid point (41.0, 5.0) because Z probe cannot reach it
                                          Warning: Skipping grid point (77.0, 5.0) because Z probe cannot reach it
                                          Warning: Skipping grid point (113.0, 5.0) because Z probe cannot reach it
                                          Warning: Skipping grid point (149.0, 5.0) because Z probe cannot reach it
                                          Warning: Skipping grid point (185.0, 5.0) because Z probe cannot reach it
                                          • PR1ORundefined
                                            PR1OR
                                            also are you able to break down that code so i can start understanding the structure and meaning? I think it will help for the future (rofl)
                                            I would on SAP and code regularly so i think if i started understanding what everything means i maybe able to start fault finding alittle better
