unusual/unnerving noises + error codes
Error: in file macro line 9: G30: Z probe 0 not found
Error: Homing failedSo im still getting this error :s
When do you get that error?
You are using the config file set I posted?
How is your BLtouch wired?
If you send M558 in the console what does it reply with?
@PR1OR said in unusual/unnerving noises + error codes:
M98 P"config.g"
this is looking alot better though!!
M98 P"config.g"
HTTP is enabled on port 80
FTP is disabled
TELNET is disabled
Warning: Macro file config-override.g not found -
So when i click home all, it homes X and Y fine then the Z starts going down then stops and put that error up.
Yeah this was using your Config file you just sent
wired like in this diagram
And this is what i get in return of M558
m558
Z Probe 0: type 9, input pin zprobe.in, output pin nil, dive height 5.0mm, probe speed 120mm/min, travel speed 6000mm/min, recovery time 0.00 sec, heaters normal, max taps 1, max diff 0.03Let me know if i can give you anymore info, im very confused now haha
Can you go through this testing procedure for the probe and tell me how far you get?
https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe#Section_Static_test_of_the_Z_probe
We're getting closer.
So i got to step 4
'With the Z probe deployed (if applicable) but not close enough to the bed to trigger it, check that the Z probe reading in Duet Web Control is zero or close to zero.'
its not showing the right distance i dont think
That's not the Z probe reading it's talking about.
It should either show 0 or 1000. In the case of the BLtouch it should show 0 most of the time and when it triggers it would very briefly flash 1000.
Where would i see that?
The bottom right corner of that same display box under the heading Z-Probe
@Phaedrux so im not sure what just happened but it seems to be working now however when homing the x axis it shakes for a couple seconds and then is fine. the y axis homes but stays to far away so i had to manually flick the bl touch probe. But it worked. Is this just playing around with the axis limits?
Well you should still verify the basics.
I suggest you take a look through these guides.
https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Maestro+Guide+Part+3:+Commissioning/39
https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Maestro+Guide+Part+4:+Calibration/40
Thank you for this!!! i now have everything homing correctly and no weird noises or shaking which is great.
Apologies for this, i am trying to find pages that help and i really appeciate all the help you have given me to far. But...
I have been following this
Ive got to step 8 and as soon as i get to roughly 30 degree it stops and shows this message
Error: Heater 0 fault: temperature rising much more slowly than the expected 1.7°C/sec
i did some googling and found this
it says i need to do this 'Therefore, you must perform a PID auto tuning to give the firmware a model for bed heater performance. Failure to do so will result in an error message that the heater temperature is not rising fast enough'
But i dont know what a PID is or how to run it. Are you able to help with this?
Pid tuning is part of the calibration guide.
So i have no idea what happened but i have tried to connect this morning and it doent seem to be connecting to the wifi. I noticed that when i turn it on. the Blue LED (wifi LED) go straight to a solid blue rather than flickering a bit while connecting. . I have plugged it in with the USB and went into terminal and i dont seem to be able to get it into idle. I can turn it off using M552 S-1 but when checking the status of the wifi using M552 it says 'WiFi module is being started' and when putting M587 it returns 'Error: M587: Failed to retrieve network list'
Any ideas on how i can connect again?
@PR1OR ive advanced. By using M997 S1 however it keeps reverting back again. Is there a code i need to put in to stop it 'forgetting'?
And you have m552 S1 in your config.g?
If you send m122 at the end of the report it should show some wifi info. Post that here..
@Phaedrux said in unusual/unnerving noises + error codes:
m122
RepRapFirmware for Duet 2 WiFi/Ethernet version 3.1.1 running on Duet WiFi 1.02 or later
Board ID: 08DJM-9178L-L2MSD-6JKF6-3SD6R-1TDUN
Used output buffers: 3 of 24 (11 max)
Static ram: 27980
Dynamic ram: 93936 of which 24 recycled
Exception stack ram used: 264
Never used ram: 8868
Tasks: NETWORK(ready,384) HEAT(blocked,1224) MAIN(running,1816) IDLE(ready,80)
Owned mutexes: WiFi(NETWORK)
Last reset 00:03:30 ago, cause: software
Last software reset at 2020-09-18 19:00, reason: User, spinning module GCodes, available RAM 8636 bytes (slot 3)
Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f000 BFAR 0xe000ed38 SP 0xffffffff Task MAIN
Error status: 0
MCU temperature: min 37.8, current 38.3, max 38.8
Supply voltage: min 23.7, current 23.8, max 24.0, under voltage events: 0, over voltage events: 0, power good: yes
Date/time: 2020-09-18 19:04:28
Cache data hit count 369890305
Slowest loop: 5.90ms; fastest: 0.12ms
=== Storage ===
Free file entries: 10
SD card longest read time 1.0ms, write time 0.0ms, max retries 0
Hiccups: 0(0), FreeDm: 169, MinFreeDm: 169, MaxWait: 0ms
=== MainDDARing ===
Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
=== AuxDDARing ===
Heater 1 is on, I-accum = 0.0
Segments left: 0
Movement lock held by null
HTTP is idle in state(s) 0
Telnet is idle in state(s) 0
File is idle in state(s) 0
USB is idle in state(s) 0
Aux is idle in state(s) 0
Trigger is idle in state(s) 0
Queue is idle in state(s) 0
Daemon is idle in state(s) 0
Code queue is empty.
=== Network ===
Slowest loop: 119.41ms; fastest: 0.00ms
HTTP sessions: 1 of 8- WiFi -
Network state is active
WiFi firmware version 1.23
WiFi MAC address cc:50:e3:32:51:9f
WiFi Vcc 3.41, reset reason Unknown
WiFi flash size 4194304, free heap 20544
WiFi IP address 192.168.1.145
WiFi signal strength -50dBm, reconnections 0, sleep mode modem
Socket states: 0 4 0 0 0 0 0 0
- WiFi -
So it seems to be working ok now which is good. but when going for a test print i reserve this
Error: Fan number 2 not found
Error: Invalid tool number
Warning: Tool 0 was not driven because its heater temperatures were not high enough or it has a heater faultthe Fan i think can probably wait til a little later but the tool i feel is an issue
I think you should try a different slicer. Something is not right in your simplify3d setup.
Are you using the config.g from the set I provided? Can you post what you have now? Copy and paste from the config.g edit window or upload the file here.
All of your hardware works when you control it from the web interface, but when you try to print a file sliced in simplify 3d it doesn't work. I think your printer profile in S3D is setup for a different printer. I don't use S3D so I'm not much help there.
simplify 3d
yeah using the your one.
; generated by RepRapFirmware Configuration Tool v3.1.4 on Wed Sep 16 2020 13:09:04 GMT-0600 (Central Standard Time); General preferences
M550 P"Duet2Wifi" ; set printer name; Network
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M569 P0 S0 ; physical drive 0 goes backwards
M569 P1 S1 ; physical drive 1 goes backwards
M569 P3 S0 ; physical drive 3 goes forwards
M350 X16 Y16 Z16 E16 I1 ;a configure microstepping with interpolation
M92 X80.00 Y80.00 Z400.00 E93.00 ; set steps per mm
M566 X900.00 Y900.00 Z12.00 E1200.00 ; set maximum instantaneous speed changes (mm/min)
M906 X600 Y600 Z600 E600 I30 ; set motor currents (mA) and motor idle factor in per cent
M208 X-5.5 Y-10 Z0 S1 ; set axis minima
M208 X220 Y220 Z250 S0 ; set axis maxima; Endstops
M574 Z1 S2 ; configure Z-probe endstop for low end on Z; Z-Probe
M950 S0 C"exp.heater3" ; create servo pin 0 for BLTouch
M558 P9 C"^zprobe.in" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
G31 P500 X-31 Y0 Z0.6 ; set Z probe trigger value, offset and trigger height
M557 X9.5:220 Y5:195 S20 ; define mesh grid; Heaters
M308 S0 P"bedtemp" Y"thermistor" T98801 B4185 ; configure sensor 0 as thermistor on pin bedtemp
M308 S1 P"e0temp" Y"thermistor" T98801 B4185 ; configure sensor 1 as thermistor on pin e0temp
M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit; Fans
M106 P0 C"Heatsink" S0 H-1 ; set fan 0 name and value. Thermostatic control is turned off
M106 P1 C"PartCooling" S1 H1 T45 ; set fan 1 name and value. Thermostatic control is turned on
M950 F1 C"fan2" Q500 ; create fan 2 on pin fan2 and set its frequency
M106 P1 C"ExtruderCooling" S1 H1 T45 ; set fan 2 name and value. Thermostatic control is turned on; Tools
M563 P0 S"Extruder 01" D0 H1 F0 ; define tool 0
T0 ; select first toolSo i didnt use a slicer there was a gcode on the interface for the benchy so i thought id try that. Im just downloading cura now so will try again and see what happens
