    Robotic kinematics
    MultiAxis Printing
    22
    389
    47.7k
    • JoergS5undefined
      JoergS5 @tony73
      @tony73 hello, my first try was too flexible, I am currently building version 2. You'll see it in a few days.
      tony73undefined 1 Reply Last reply Reply Quote 0
      • tony73undefined
        tony73 @JoergS5
        @JoergS5
        OK, see you soon!
        • JoergS5undefined
          JoergS5 @tony73
          This post is deleted!
          • JoergS5undefined
            JoergS5
            @dc42 I have two short questions and hope you can easily answer them:
            The M208 XYZ, are they cartesian coordinates, and when using U it is meant as a second X? For rotational actuators, I would use the result of the kinematics world coordinates for the M208 values, not the angles? Do I understand this correctly?
            I have to inform the kinematics in advance before the G0/G1 move starts, what the complete movement will be. I added a seperate method for this in the kinematics. Where shall I add the call? (DDA/Move/...Init/Spin?) and are there additional parts where I have to add it (mesh compensation eg).
              It's entirely up to you what you use the U axis for. In the CNC world, conventionally UVW behave like a second XYZ system, and ABC are rotational axes. But RRF doesn't require that.
              • JoergS5undefined
                JoergS5 @dc42
                @dc42 I meant are M208 values cartesian coordinates or stepper positions?
                  dc42 administrators @JoergS5
                  @JoergS5 said in Robotic kinematics:
                  They are in whatever units your kinematics assumes for U parameters in G1 commands.
                  • JoergS5undefined
                    JoergS5 @dc42
                    @dc42 ok thanks, I try to use it correctly.
                    • tony73undefined
                      tony73 @JoergS5
                      @JoergS5
                      good morning ! I took the two files with the latest changes FiveAxisRobotKinematics.h and FiveAxisRobotKinematics.cpp I put them in rrf 3.1.0 as I always did, I tried to in eclipse to recompile the .bin gives me this error,
                      could you help me ? I don't know where I'm wrong!
                      • JoergS5undefined
                        JoergS5 @tony73
                        @tony73 you're right, I missed checking it in into github. I'll do this in a minute. The variables are a prepration to support P3 (hotend in the direction of the movement) and a new P4.
                        Sorry that I overlooked it.
                        • tony73undefined
                          tony73
                          @JoergS5
                          OK! eclipse firmware reloaded works! I would like to start building a robot that looks like this
                          with example link 1 /150mm, link 2/ 200mm, link 3/ 200mm, link 4/ 100mm, link 5/ 80mm
                          the (link 4 could be 100mm? considering that I don't know if link 2 can go to less than 0 degrees (type arm 2 max 75 degrees min -45 degrees? and could you say reduction ratio would serve on the basis of these arms, for the 5 engines?
                          maybe I made a wrong speech!
                          if link 1 is 150mm, I can make link 4 of 100mm that is 50mm less than link 1, can there be a problem or can it be done? can create problems at link 2 for min angle 0?
                          • JoergS5undefined
                            JoergS5 @tony73
                            @tony73 I think you confuse some of the distances, What you mark as link 1 distance has no meaning. Only how much it can rotate is important.
                            => to answer your question, different axis lengths are no problem. Longer will probebly be more stable. I will use between 100 and 200 also.
                            Link 2 min angle 0 is no problem. You must calibrate the angle at a different angle (eg 90 degree).
                            Your question according reduction ratio: which ratio do you plan?
                            At the 5 you must assemble something horizontal to hold a hotend if you want to use it for 3d printing.
                            The robot as such looks very stiff and will be precise (if the ratio is ok) imho. In axis 5 could be a harmonic drive. A planetoid gear could have backlash, but you could run it in P0 mode.
                            Axis 1 is very important to be precise (exactly horizontal rotation eg), you should consider making the rotating plate as big/good/stiff as possible.
                            tony73undefined 2 Replies Last reply Reply Quote 0
                            • tony73undefined
                              tony73 @JoergS5
                              • tony73undefined
                                tony73 @JoergS5
                                @JoergS5
                                ok! I take note of all the advice! and thank you for your help! if these were the lengths of the robot arms ((X0.0: 0.0 Y0.0: 0.0 Z100.0 L200.0: 200.0: 100.0: 80.0)) what reduction ratio would you use so that the 5 motors have excellent precision?
                                about the second robot you are building how long do you need to finish it?
                                • JoergS5undefined
                                  JoergS5 @tony73
                                  @tony73 I don't exactly know the best ratio, the commercial robots often have 1:30 for every axis. My approach will be to calculate mathematically which is the best ratio:
                                  high ratio means higher precision and more torque, but slower. So there will be an optimal ratio for the desired speed. Regarding the maximal extruder speed, the robot has a maximum speed. More speed (= low ratio) is not necessary and would result in lower precision. High ratio would be slow. The arm lengths are also important.
                                  To calculate is on my long todo list...
                                  • JoergS5undefined
                                    JoergS5 @tony73
                                    @tony73 said in Robotic kinematics:
                                    My recent firmware changes are the result of this building. The axis5offset (Xo, Yo) is to ease construction of axis 4 and 5. The main problem is axis 1. A few days left.
                                    • tony73undefined
                                      tony73 @JoergS5
                                      @JoergS5
                                      ok! could you write me what are the mandatory parameters from the last update, in M669?
                                      Is the 5 axis offset a help for robot construction problems (I think accuracy) or is it about something else?
                                      • JoergS5undefined
                                        JoergS5 @tony73
                                        @tony73 The documentation is current, just use the sample at the end. The parameters which are not mentioned in the example are all optional or have a default value. P3 /P4 implementation is not finished.
                                        The axis 4 must be exactly above axis 5. The axis5offset allows axis 5 to be outside this. This allows me to place axis 5 in front of arm 4. You'll see what I mean when I explain my construction. This is not documented yet (only the parameter, and it's already in the source and tested). Axis5offset has defaults 0.0/0.0.
                                        • tony73undefined
                                          tony73 @JoergS5
                                          @JoergS5
                                          I continue to follow your updates, thanks for the clarification and wait to see your robot!
                                          JoergS5undefined 2 Replies Last reply Reply Quote 0
                                          • JoergS5undefined
                                            JoergS5 @tony73
                                            @tony73 the robot you have shown could use a toolchanger at point 5 easily and should be a solid connection (like for CNC). But think about how to guide the wires and filament. I route it inside of the arms.
