    Testing Resolution / accuracy , Your results wanted! Z Probe Results
    84
    14.6k
    • AndreSundefined
      AndreS
      Hi Russ, some more data for you:
      My machine:
      Basically a Think3dPrint3D mini Kossel.
      4mm aluminium heated bed + 4mm glas with Filaprint sheet.
      20T pulleys, 1,8 deg stepper.
      3 FSR sensors under the bed connected to 3 ADC on ATmega8. I created circuit and program myself (no Arduino).
      Homing switches are Hall-sensors.
      Flying extruder with counterweight.
      Bed cold, Nozzle 140C cleaned.
      17:32:09
      M98 P0:/macros/Test/Probe_Testing_Single_Point_36_probes_P_values.gcode
      Bed probe heights: 0.003 0.016 0.003 0.003 0.003 0.003 0.016 0.016 0.003 0.003 0.003 0.003 0.003 0.016 0.016 0.003 0.003 0.003 0.003 0.003 0.003 0.016 0.016 0.003 0.003 0.003 0.003 0.003 0.003 0.016 0.016 0.003 0.003 0.003 0.003 0.003, mean 0.006, deviation from mean 0.005
      17:35:34
      Bed probe heights: 0.003 0.003 0.003 0.003 0.003 0.003 0.003 0.003 0.003 0.016 0.003 0.003 0.003 0.003 0.003 0.003 0.003 0.003 0.003 0.003 0.003 0.003 0.003 0.003 0.003 0.003 0.003 0.003 0.003 0.003 0.003 0.003 0.003 0.003 0.003 0.003, mean 0.003, deviation from mean 0.002
      17:38:41
      Another run after homing. Homing switches are hall-sensors.
      Bed probe heights: -0.009 -0.009 -0.009 0.003 0.003 0.003 0.003 -0.009 0.003 0.003 0.003 0.003 0.003 0.003 0.003 0.003 0.003 0.003 0.003 0.003 0.003 0.003 0.003 0.003 0.003 0.003 0.003 0.003 0.003 0.003 0.003 -0.009 0.003 -0.009 0.003 -0.009, mean 0.001, deviation from mean 0.005
      17:44:40
      M98 P0:/macros/Test/Probe_Testing_moving_100-100_probe_0-0_25_Point_p_values_.gcode
      Bed probe heights: -0.009 0.003 0.016 0.003 0.003 0.003 0.016 0.003 0.028 0.028 0.003 0.003 0.028 0.028 0.016 0.016 0.003 0.003 0.028 0.003 0.003 0.003 0.016 0.016 0.028, mean 0.012, deviation from mean 0.011
      17:49:33
      Bed probe heights: 0.016 0.028 0.016 0.016 0.016 0.016 0.028 0.016 0.003 0.003 0.016 0.016 0.003 0.016 0.016 0.028 0.028 0.016 0.028 0.016 0.003 0.016 0.016 0.028 0.016, mean 0.017, deviation from mean 0.008
      17:56:37
      Again another run after homing.
      Bed probe heights: 0.003 0.003 0.028 0.016 0.003 0.016 0.016 0.028 0.016 0.028 0.016 0.028 0.028 0.016 0.028 0.016 0.028 0.028 0.016 0.028 0.016 0.028 0.016 0.028 0.016, mean 0.020, deviation from mean 0.008
      Andre
      • DjDemonDundefined
        DjDemonD
        Couple of fresh results.
        These are with a 20mm "Piezo20" module I am hoping to be able to sell soon, on a kossel XL.
        This is the moving head test
        Bed probe heights: -0.004 0.001 0.001 0.001 0.001 0.001 0.001 0.001 0.001 0.006 0.001 0.006 0.006 0.006 0.001 0.001 0.001 0.006 0.001 0.006 0.001 0.006 0.006 0.006 0.001, mean 0.003, deviation from mean 0.003
        This is the stationary probing test:
        Bed probe heights: 0.001 0.001 0.001 0.001 0.001 0.001 0.001 -0.004 -0.004 -0.004 0.001 0.001 -0.004 -0.009 -0.009 -0.009 -0.009 -0.004 -0.009 -0.009 -0.004 -0.004 -0.004 0.001 -0.004 0.001 -0.004 -0.004 -0.004 -0.004 -0.004 -0.004 -0.004 -0.004 -0.004 -0.004, mean -0.003, deviation from mean 0.003
        www.precisionpiezo.co.uk
          Here are the results for the prototype version #2 of the Duet3D delta effector with built-in nozzle contact probe, on my Kossel
          Stationary test:
          Bed probe heights: 0.005 -0.003 0.007 0.004 0.003 -0.003 0.003 0.004 0.004 0.002 0.004 0.002 0.002 0.003 0.004 0.002 0.003 0.005 0.003 0.005 -0.005 0.003 0.003 0.002 -0.002 0.003 0.003 0.003 0.002 0.002 0.003 0.003 0.002 0.002 -0.006 -0.003, mean 0.002, deviation from mean 0.003
          Moving test:
          Bed probe heights: 0.008 0.004 0.003 0.008 0.003 0.004 0.005 0.015 0.011 0.004 0.005 0.003 0.002 0.004 0.002 0.000 -0.002 0.002 0.003 -0.001 -0.001 0.007 0.008 0.003 0.009, mean 0.004, deviation from mean 0.004
          I used 64x microstepping for this test which on this machine gives a theoretical Z resolution of 0.00125mm, although in practice the machine doesn't move on individual 1/64 microsteps.
          • Sabagmnundefined
            Sabagmn
            Just bought one of those from your early bird special.
            Looking forward to trying it.
            Planning on using that on a Hypercube Evolution that I am in the process of building.
            Thanks for putting in the time and effort needed to develop such a product, and still making it easily available to everyone!
            Sandro
            @DjDemonD:
            • jrledererundefined
              jrlederer
              @leadinglights:
              I would like to be able to contribute some data for under-bed piezo sensors but unfortunately the cost of the Duet3D prevents me from doing so at the moment. I suspect from oscilloscope and logic analyzer traces that it is at least in the 1 micron region but Arduino/Ramps/Repetier firmware only reports to 0.01mm. Of course, if anybody knows how I can coax Repetier firmware to report G30 either to 0.001mm or in raw Z stepper steps I may be able to give you the data
              Mike
              Mike,
              I've been in the giving mood lately, and similarly to how I hooked up DJDemon's with a diet wifi, I am inclined to gift one to you as well as a personal thank you for all the contributing you do toward this hobby. Shoot me your address and I'll replace the vssa fuse on one of the other 3 boards I'd accidentally fried over the months and didn't know the fuse was replaceable. LoL. Anyway, what I'm gonna do with 4 Duet Wifi boards? ?
              "Insanity is doing the same thing over again, yet expecting different results..." --Albert Einstein
              • BlackTomundefined
                BlackTom
                @Sabagmn:
                Sandro
                @DjDemonD:
                Same here… I'll install it on my custom coreXY... I hope to get it soon 😄
                • DjDemonDundefined
                  DjDemonD
                  I'm just hoping the modules will live up to expectations, have quite a few orders now, so give me a few days guys to make them. But thank you for your support.
                  • DjDemonDundefined
                    DjDemonD
                    Hi Russ, any chance of an update of the graphs with the latest results?
                    • Russ Griesundefined
                      Russ Gries
                      will do, its been on my list of To Do's . lots of excitement lately with the release of the QSN. 🙂 (if you haven't see that let me know, i haven't posted it here because its not directly Duet related… but soon ill be!)
                      so i haven't had time to work on this project so sorry for my lack of attendance 🙂 one day at a time.
                      let me this new data now!
                      Thanks for all who have added!!
                      ~Russ
                      One Day At A Time…
                      My Main Research Page:
                      http://rwgresearch.com/open-projects/3d-printing-research/
                      • Dougal1957undefined
                        Dougal1957
                        Not heard of that Russ please do post the links?
                          Russ Gries
                          DjDemonD and dc42
                          can you run the test 2 times ( please post one more run of each. I need more data to do the equally with the rest of the data!)
                          also David, can you run the IR probe you have built, do you have it installed on something you can test? that one is a real mystery still 🙂 know one has given data on it anywhere! Thanks!
                          Jrlederer,
                          That was kind of you to gift a Bord!
                          Can I ask you to trade an old version 0.8.5 for a Duet Wifi? I have a good never used ( was for a project that i haven't finished yet) 0.8.5 that i did some testing with. then i upgraded that new Delta to a duet wifi. I would just sell it and get a Duet Wifi but no funds for that…
                          ( hey mamma always said its never a bad idea to ask) 🙂
                          and for some reason you say yes but dont want the 0.8.5 ill do a give a give away on my YT channel.. ( sponcerd by you ) 🙂
                          ok.
                          Here is the data from AndreS
                          still waiting on he second run from you other guys! 🙂 ( please)
                          your data added to the workbook.
                          Higher rezhttp://open-source-energy.org/rwg42985/russ/Projects/3D%20printer/micro%20switch%20Z%20probe%20Data/Bed%20Probes%20accuracy%20others%20added.jpg
                          looking for more! I want to make a video on this some time so if there are more users why haven't contributed please do so soon!
                          Thanks!!!
                          One Day At A Time…
                            Russ Gries
                            @Dougal1957:
                            ok i posted it here so we dont mess up this thread 🙂
                            https://www.duet3d.com/forum/thread.php?pid=15107
                            ~Russ
                            One Day At A Time…
                            • DjDemonDundefined
                              DjDemonD
                              Okay so second run for Piezo20 Hotend Z-Probe www.precisionpiezo.co.uk
                              Stationary:
                              Bed probe heights: -0.111 -0.116 -0.116 -0.121 -0.116 -0.116 -0.116 -0.116 -0.116 -0.116 -0.116 -0.116 -0.111 -0.116 -0.111 -0.116 -0.111 -0.111 -0.116 -0.116 -0.116 -0.116 -0.111 -0.116 -0.111 -0.121 -0.111 -0.116 -0.111 -0.116 -0.116 -0.116 -0.111 -0.116 -0.116 -0.116, mean -0.115, deviation from mean 0.003
                              Done printing file
                              Moving:
                              Bed probe heights: 0.004 0.017 0.013 0.019 0.010 0.013 0.013 0.014 0.017 0.014 0.013 0.014 0.013 0.017 0.019 0.022 0.019 0.019 0.013 0.018 0.010 0.010 0.017 0.017 0.019, mean 0.015, deviation from mean 0.004
                              Done printing file
                                Russ Gries
                                ok updated Charts.
                                I found a few errors on my data selection so I corrected those, That change a few results. but , all for the better.
                                its all correct now…
                                also, i added Davids data but would like to have the other data set. all ways better to have a pool of data as a one time run can make you look to good 🙂 hehe
                                One Day At A Time…
                                  Russ, if you have a Duet 0.8.5 that you don't want, you can probably find a buyer for it on the reprap.org forum.
                                  My delta is down for maintenance right now, I'll generate another set of date when it is running again
                                  • DjDemonDundefined
                                    DjDemonD
                                    New Data, Precision Piezo Titan/Aero Piezo Z-probe bracket https://www.thingiverse.com/thing:2404904
                                    15:48:16Bed probe heights: 0.005 0.005 0.000 0.000 0.000 0.005 0.000 0.005 0.005 -0.005 -0.005 0.000 0.000 0.005 0.000 0.005 0.005 0.000 -0.005 0.000 0.005 0.000 -0.005 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 -0.005 0.000 0.000 0.000 0.000, mean 0.001, deviation from mean 0.003
                                    Done printing file
                                    15:47:10M32 0:/gcodes/cartesian_Probe_Testing_Single_Point_36_probes_P_values.gcode
                                    File 0:/gcodes/cartesian_Probe_Testing_Single_Point_36_probes_P_values.gcode selected for printing
                                    15:46:55Bed probe heights: -0.015 0.000 0.005 -0.005 0.000 -0.005 0.000 0.005 0.005 0.005 0.000 0.000 -0.005 0.005 -0.005 0.000 -0.005 0.000 0.005 -0.005 -0.005 0.000 -0.005 0.000 -0.005 0.000 -0.005 0.005 -0.005 0.000 0.000 0.000 -0.005 0.005 -0.005 0.000, mean -0.001, deviation from mean 0.004
                                    Done printing file
                                    15:45:47M32 0:/gcodes/cartesian_Probe_Testing_Single_Point_36_probes_P_values.gcode
                                    • WZ9Vundefined
                                      WZ9V
                                      Tevo Little Monster with BL-Touch converted to Duet WiFi and 0.9 degree steppers on X, Y, Z.
                                      7:50:34 PM: Bed probe heights: 0.149 0.161 0.155 0.158 0.149 0.155 0.158 0.155 0.152 0.143 0.136 0.146 0.115 0.102 0.090 0.036 0.021 -0.003 -0.020 -0.026 -0.023 0.018 0.061 0.121 0.130, mean 0.098, deviation from mean 0.066
                                      7:56:14 PM: Bed probe heights: 0.149 0.183 0.186 0.155 0.152 0.083 0.049 0.021 0.005 -0.014 -0.026 0.002 0.058 0.118 0.155 0.177 0.186 0.186 0.149 0.146 0.130 0.111 0.086 0.043 0.018, mean 0.100, deviation from mean 0.070
                                      7:58:47 PM: Bed probe heights: 0.015 0.015 0.008 0.015 0.018 0.018 0.021 0.015 0.015 0.018 0.018 0.015 0.021 0.015 0.015 0.018 0.018 0.018 0.015 0.011 0.015 0.011 0.015 0.018 0.005 0.008 0.008 0.011 0.018 0.018 0.018 0.018 0.015 0.015 -0.004 -0.010, mean 0.014, deviation from mean 0.006
                                      8:01:26 PM: Bed probe heights: -0.020 -0.026 -0.029 -0.029 -0.032 -0.035 -0.032 -0.035 -0.029 -0.035 -0.039 -0.039 -0.039 -0.035 -0.042 -0.042 -0.042 -0.035 -0.035 -0.023 -0.017 -0.001 0.024 0.046 0.068 0.080 0.102 0.108 0.118 0.115 0.118 0.124 0.127 0.127 0.136 0.140, mean 0.021, deviation from mean 0.069
                                      Probably explains my troubles getting a consistent first layer.
                                      • fcwiltundefined
                                        fcwilt
                                        I still have not figured out how to get the kind of results you all are getting.
                                        I am using the dc43 IR unit and it works well but something must be wrong with my build.
                                        One thing that might be important is that repeated calibration runs get better after the 2nd or 3rd but then begin to get worse.
                                        Have no idea that that means.
                                        • DjDemonDundefined
                                          DjDemonD
                                          IMO both the BLtouch and IR sensor have their limitations, BL touch is not as accurate as it really needs to be, the notion that if a probe is within 50 microns its good enough is clearly not correct. IR works fine if you have an evenly reflective surface to IR, and on a delta, no effector tilt. In practice neither of these conditions are easy to meet. IR on a cartesian with an evenly reflective surface is a good prospect. Join the piezo revolution guys 🙂
                                            …or wait for our delta effector, which is close to availability. See https://duet3d.com/wiki/Smart_effector_and_carriage_adapters_for_delta_printer.
