Im getting a basic error:563 bad driver number for my heater 1
can you post your whole config?
M550 P"Jeffrey's printer" ; set printer name
M665 R155 L397.19 B155 H520 ; Set delta radius, diagonal rod length, printable radius and homed height
M666 X0 Y0 Z0 ; put your endstop adjustments here, or let auto calibration find them; Network
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S1 ; enable FTP
M586 P2 S1 ; enable Telnet; Drives
M92 X80.00 Y80.00 Z80.00 E663.00 ; set steps per mm
M566 X1200.00 Y1200.00 Z1200.00 E1200.00 ; set maximum instantaneous speed changes (mm/min)
M203 X18000.00 Y18000.00 Z18000.00 E1200.00 ; set maximum speeds (mm/min)
M201 X1000.00 Y1000.00 Z1000.00 E1000.00 ; set accelerations (mm/s^2)
M906 X1000 Y1000 Z1000 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
M208 Z0 S1 ; set minimum Z; Endstops
M574 X2 Y2 Z2 S1 ; set active high endstops; Z-Probe
M307 H3 A-1 C-1 D-1 ; disable heater on PWM channel for BLTouch
M558 P9 H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
G31 P500 X0 Y0 Z0 ; set Z probe trigger value, offset and trigger height
M557 R85 S20 ; define mesh grid; Heaters
M106 P1 S1 I0 F500 H1 T45 ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on; Tools
M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss -
nothing wrong there i can see.
Whats in your macro?
oh wait, is that the test macro thats come on the card?
@jay_s_uk yeah
Don't run those. They are for factory testing and you won't have the same hardware connected obviously.
You can test the heater by turning it on in the web interface.
@Phaedrux
i tried but it trips an error
Error: Heating fault on heater 1, temperature rising much more slowly than the expected 1.7°C/sec
its wired to the correct heater and everything -
PID tune your hot end and your bed.
For your bedM303 H0 S60
For your hotend
M303 H1 S200
Tune your hotend with it close to your bed and your part cooling fan running at the speed you would usually use for printing
After tuning PID send M500 to save the results and add M501 to the end of your config.g to load them at startup.
yes, that helps
@jay_s_uk
im thinking the hardware might be broken
9/24/2020, 1:59:35 PM Auto tune cancelled because temperature is not increasing
9/24/2020, 1:58:58 PM Auto tune phase 1, heater on
9/24/2020, 1:58:53 PM M303 H1 S200
Auto tuning heater 1 using target temperature 200.0°C and PWM 1.00 - do not leave printer unattended -
@Jeffrey_101 where do you have the heater wired into?
maybe post a photo -
@Jeffrey_101 said in Im getting a basic error:563 bad driver number for my heater 1:
Unlikely. If you have a multimeter, disconnect the heater wires from the Duet, and test the resistance of the heater wires where they connect to the Duet. A 'normal' hot end heater should have a resistance of around 4 to 15 ohms, depending on voltage and power.
If you've run the 'factory' macros, reset your board. I seem to remember that they set the heaters to non standard settings.
@jay_s_uk
the setup is messy rn because my printer is down XD
ok. you're wired into E1 heater and yet you're using E0.
Move the heater to the other green block next to where you're wired in.
Do it without power just incase! -
wow, that embarrassing haha, i tried that before but that was when i was running the RRF3 config on the RRF2 firmware, It works now! i learned a lot thank you for all your help!
