    PanelDueFirmware 3.2-RC3 released
    PanelDue
    2.1k
    • wilrikerundefined
      wilriker
      I am pleased to announce the third release candidate for PanelDueFirmware 3.2. This release contains primarily bug fixes and a few small changes in behavior. See below for details.
      Version 3.2-RC3
      Upgrade Notes and Limitations
      See 3.2-RC2
      Changes since RC2
      • Extrusion and retraction commands are now a single line to prevent being interleaved by other commands
      • Screensaver is now a popup to better interact with existing or incoming popups
      • No longer fetch detailed M409 for Fans or Sensors (as they are currently not required)
      Bug Fixes since RC2:
      • Screensaver timeout select pop-up would not disappear when clicking anything but "Set" or a tab button
      • Extrusion factor was not always targeting the correct extruder
      • Extrusion factor controls were not hidden if amount of tools was decreased
      • Bed and chamber controls were not hidden if they were removed from config
      • If a JSON key path was too long it would result in an endless fetch-loop
      Downloads and Instructions
      Binaries can be found at https://github.com/Duet3D/PanelDueFirmware/releases/tag/3.2-RC3
      Flashing instructions can be found at https://duet3d.dozuki.com/Wiki/PanelDue_Firmware_update
      Manuel
      My Tool Collection
      • wilrikerundefined
        wilriker
        I just released 3.2-RC3+1 with one additional bugfix. I expect this to be the last release candidate before releasing 3.2 final.
        Version 3.2-RC3+1
        Bug fixes:
        • Message box was not closed on PanelDue if closed e.g. in DWC
        Binaries can be found at https://github.com/Duet3D/PanelDueFirmware/releases/tag/3.2-RC3%2B1
        Manuel
        My Tool Collection
        • oozeBotundefined
          oozeBot
          Thanks. We'll update all our panels this morning and report back with any issues.
          @wilriker - one item I'd like to ask, with the introduction of the Object Model, could Baby Steps be modified to mirror what's set in DWC instead of being fixed at .02mm?
          • wilrikerundefined
            wilriker @oozeBot
            @oozeBot said in PanelDueFirmware 3.2-RC3 released:
            Baby step amount in DWC is a DWC-local setting that RRF does know nothing about. Therefore unfortunately this cannot be mirrored to PanelDue.
            Manuel
            My Tool Collection
            • BoAundefined
              BoA
              I would like to se a setting for baby steps - step in paneldue πŸ˜„
                Current babystepping amount is present in the OM already, it's in move.axes[n].babystep.
                • wilrikerundefined
                  wilriker @dc42
                  @dc42 I think the request is rather about the amount to be applied when pressing the babystep buttons.
                  Manuel
                  My Tool Collection
                    Ah, I misunderstood.
                    • wilrikerundefined
                      wilriker @BoA
                      @BoA said in PanelDueFirmware 3.2-RC3 released:
                      This can be added quite easily. Though, I would like to fix this to 4-6 preset values because user-input is always quite tricky.
                      How about:
                      • 0.01
                      • 0.02
                      • 0.05
                      • 0.1
                      Something smaller? Something larger? Something completely different?
                      Manuel
                      My Tool Collection
                      oozeBotundefined 1 Reply Last reply Reply Quote 2
                      • oozeBotundefined
                        oozeBot @wilriker
                        @wilriker that would certainly cover it for us! However, long term, I'd still suggest syncing this with DWC through the Object Model.
                        Thanks!
                        • wilrikerundefined
                          wilriker @oozeBot
                          Once user variables have been implemented in RRF this would be very easy.
                          Manuel
                          My Tool Collection
                          • oozeBotundefined
                            oozeBot
                            I wanted to report back that I'm seeing an M291 S3 popup on the PanelDue fail to display randomly..
                            I'll be doing more testing today and through the weekend, so maybe I can put my finger on the exact scenario which is causing it.
                            To quickly describe where I've seen it happen, it's at the beginning of a job when homing - I have an M291 S3 command in my homez.g file. It's here that sometimes the popup is never displayed on the PanelDue.
                            Thanks
                            • docboboundefined
                              docbobo
                              I just set up my 5i with an BTT SKR 1.4 Turbo using 3.2-RC3 together with all the other betas (DWC, DSF, FW).
                              At least for me, M300 doesn't result in any sound coming out of the PanelDue, even though it does beep when I am pressing some of the buttons.
                              Am I missing anything there?
                              BoAundefined 1 Reply Last reply Reply Quote 0
                              • BoAundefined
                                BoA @docbobo
                                @docbobo I would say M300 is processed by the board, not the panel. If Your board has no "beeper" then no sound πŸ˜‰
                                docboboundefined 1 Reply Last reply Reply Quote 0
                                • docboboundefined
                                  docbobo @BoA
                                  @BoA Well, the documentation seems to say
                                  Play beep sound, use to notify events like the end of printing. If an LCD device is attached to RepRapFirmware, a sound is played via the add-on touch screen control panel. Else the web interface will play a beep sound.
                                  wilrikerundefined BoAundefined 2 Replies Last reply Reply Quote 1
                                  • wilrikerundefined
                                    wilriker @docbobo
                                    @docbobo Yes, M300 are supposed to be played by PanelDue. I have to investigate the problem because it worked when I tested a while back.
                                    Manuel
                                    My Tool Collection
                                    • docboboundefined
                                      docbobo
                                      @wilriker πŸ‘ Let me know if there's anything I can do.
                                      BTW, when running mesh compensation, I noticed that coordinates for X Y Z were updating the screen, even though it was in sleep mode. Doesn't seem to happen while printing.
                                      wilrikerundefined 2 Replies Last reply Reply Quote 0
                                      • BoAundefined
                                        BoA @docbobo
                                        @docbobo I am not sure, but isn't the board responsible for sending this M300 to panel to make it beeping?
                                        • wilrikerundefined
                                          wilriker @docbobo
                                          @docbobo said in PanelDueFirmware 3.2-RC3 released:
                                          Will let you know if that's necessary, thanks.
                                          I am not exactly sure if I understand what you mean. Du you mean it's waking up the panel from screensaver when running mesh compensation?
                                          If so, here's the small list of what will wait up the panel from screensaver:
                                          • Incoming message pop-up
                                          • Machine state changed e.g. Idle to Busy or Printing to Paused, etc.
                                          Manuel
                                          My Tool Collection
                                          • docboboundefined
                                            docbobo @wilriker
                                            @wilriker no, it’s not waking up the panel. It was mostly black, just the numbers for x, y, and z were appearing.
                                            oozeBotundefined wilrikerundefined 3 Replies Last reply Reply Quote 0
