    PanelDueFirmware 3.2-RC3 released
    PanelDue
    1.9k
    • wilrikerundefined
      wilriker @oozeBot
      @oozeBot said in PanelDueFirmware 3.2-RC3 released:
      However, long term, I'd still suggest syncing this with DWC through the Object Model.
      Once user variables have been implemented in RRF this would be very easy.
      Manuel
      My Tool Collection
      • oozeBotundefined
        oozeBot
        I wanted to report back that I'm seeing an M291 S3 popup on the PanelDue fail to display randomly..
        I'll be doing more testing today and through the weekend, so maybe I can put my finger on the exact scenario which is causing it.
        To quickly describe where I've seen it happen, it's at the beginning of a job when homing - I have an M291 S3 command in my homez.g file. It's here that sometimes the popup is never displayed on the PanelDue.
        Thanks
        • docboboundefined
          docbobo
          I just set up my 5i with an BTT SKR 1.4 Turbo using 3.2-RC3 together with all the other betas (DWC, DSF, FW).
          At least for me, M300 doesn't result in any sound coming out of the PanelDue, even though it does beep when I am pressing some of the buttons.
          Am I missing anything there?
          BoAundefined 1 Reply Last reply Reply Quote 0
          • BoAundefined
            BoA @docbobo
            @docbobo I would say M300 is processed by the board, not the panel. If Your board has no "beeper" then no sound πŸ˜‰
            docboboundefined 1 Reply Last reply Reply Quote 0
            • docboboundefined
              docbobo @BoA
              @BoA Well, the documentation seems to say
              Play beep sound, use to notify events like the end of printing. If an LCD device is attached to RepRapFirmware, a sound is played via the add-on touch screen control panel. Else the web interface will play a beep sound.
              wilrikerundefined BoAundefined 2 Replies Last reply Reply Quote 1
              • wilrikerundefined
                wilriker @docbobo
                @docbobo Yes, M300 are supposed to be played by PanelDue. I have to investigate the problem because it worked when I tested a while back.
                Manuel
                My Tool Collection
                • docboboundefined
                  docbobo
                  @wilriker πŸ‘ Let me know if there's anything I can do.
                  BTW, when running mesh compensation, I noticed that coordinates for X Y Z were updating the screen, even though it was in sleep mode. Doesn't seem to happen while printing.
                  wilrikerundefined 2 Replies Last reply Reply Quote 0
                  • BoAundefined
                    BoA @docbobo
                    @docbobo I am not sure, but isn't the board responsible for sending this M300 to panel to make it beeping?
                    • wilrikerundefined
                      wilriker @docbobo
                      @docbobo said in PanelDueFirmware 3.2-RC3 released:
                      Will let you know if that's necessary, thanks.
                      I am not exactly sure if I understand what you mean. Du you mean it's waking up the panel from screensaver when running mesh compensation?
                      If so, here's the small list of what will wait up the panel from screensaver:
                      • Incoming message pop-up
                      • Machine state changed e.g. Idle to Busy or Printing to Paused, etc.
                      Manuel
                      My Tool Collection
                      • docboboundefined
                        docbobo @wilriker
                        @wilriker no, it’s not waking up the panel. It was mostly black, just the numbers for x, y, and z were appearing.
                        oozeBotundefined wilrikerundefined 3 Replies Last reply Reply Quote 0
                        • oozeBotundefined
                          oozeBot @docbobo
                          @docbobo - I've seen this as well..
                          @wilriker - I've had the PanelDue not display an M291 S3 command like I described earlier several times today. There is no pattern to it that I've been able to find. However, I can say with certainty that it is still occurring.
                          Like I mentioned before, it's within my homez.g file as interaction is expected when beginning a print.
                          Thanks
                          • wilrikerundefined
                            wilriker @docbobo
                            @docbobo Thanks for reporting. I'll investigate that.
                            Manuel
                            My Tool Collection
                            • wilrikerundefined
                              wilriker @oozeBot
                              Thanks
                              I need more information about your setup, please. Duet 2 or Duet 3 and standalone or with DSF?
                              Also in which state is the machine when this pop-up should occur? Idle, Busy, something else?
                              Manuel
                              My Tool Collection
                              oozeBotundefined 1 Reply Last reply Reply Quote 0
                              • oozeBotundefined
                                oozeBot @wilriker
                                @wilriker we are using Duet 3 / RPi combos running 3.2b1 and the PanelDue is on 3.2-RC3+1. I just had it happen again on a machine that had been turned off overnight. What I didn't catch was the state reported in the top right corner of the PanelDue, but I believe it was "Printing". I feel sure this will happen again today, so I'll report back.
                                I will point out that I didn't notice this nearly as often (or at all?) on the earlier betas.. it feels new to 3.2-RC3+1. Thanks
                                • wilrikerundefined
                                  wilriker @oozeBot
                                  @oozeBot The state does not have to be from PanelDue. In fact it might even be wrong there. Please check the state in DWC while the dialog is still open.
                                  3.2-RC3+1 fixed a bug where these dialogs would not disappear if closed somewhere else, e.g. DWC. This seems to have introduced a regression as it seems.
                                  Manuel
                                  My Tool Collection
                                  • docboboundefined
                                    docbobo
                                    Just noticed the following in my DSF output:
                                    [error] Failed to merge JSON: {"key":"","flags":"d99fn","result":{"boards":[{"mcuTemp":{},"vIn":{}}],"fans":[{"actualValue":0,"requestedValue":0,"rpm":-1},{"actualValue":1.00,"requestedValue":1.00,"rpm":-1}],"heat":{"heaters":[{"active":0,"current":61.0,"standby":0,"state":"off"},{"active":0,"current":84.5,"standby":0,"state":"off"}]},"inputs":[{"feedRate":50.0,"lineNumber":0,"state":"idle"},{"feedRate":50.0,"lineNumber":0,"state":"idle"},{"feedRate":50.0,"lineNumber":0,"state":"idle"},{"feedRate":50.0,"lineNumber":0,"state":"idle"},{"feedRate":50.0,"lineNumber":205,"state":"idle"},{"feedRate":50.0,"lineNumber":151,"state":"idle"},{"feedRate":50.0,"lineNumber":0,"state":"idle"},{"feedRate":50.0,"lineNumber":0,"state":"idle"},{"feedRate":50.0,"lineNumber":0,"state":"idle"},{"feedRate":50.0,"lineNumber":0,"state":"idle"},{"feedRate":50.0,"lineNumber":0,"state":"idle"},{"feedRate":50.0,"lineNumber":0,"state":"idle"}],"job":{"duration":null,"filePosition":0,"layerTime":null,"timesLeft":{"filament":null,"file":null,"layer":null}},"move":{"axes":[{"homed":false,"machinePosition":0,"userPosition":0},{"homed":false,"machinePosition":0,"userPosition":0},{"homed":false,"machinePosition":0,"userPosition":0}],"currentMove":{"acceleration":0,"deceleration":0,"laserPwm":null,"requestedSpeed":0,"topSpeed
                                       System.Text.Json.JsonReaderException: Expected end of string, but instead reached end of data. LineNumber: 0 | BytePositionInLine: 1280.
                                       at System.Text.Json.ThrowHelper.ThrowJsonReaderException(Utf8JsonReader& json, ExceptionResource resource, Byte nextByte, ReadOnlySpan`1 bytes)
                                       at System.Text.Json.Utf8JsonReader.ConsumeString()
                                       at System.Text.Json.Utf8JsonReader.ConsumePropertyName()
                                       at System.Text.Json.Utf8JsonReader.ConsumeNextToken(Byte marker)
                                       at System.Text.Json.Utf8JsonReader.ConsumeNextTokenOrRollback(Byte marker)
                                       at System.Text.Json.Utf8JsonReader.ReadSingleSegment()
                                       at System.Text.Json.Utf8JsonReader.Read()
                                       at System.Text.Json.JsonDocument.Parse(ReadOnlySpan`1 utf8JsonSpan, Utf8JsonReader reader, MetadataDb& database, StackRowStack& stack)
                                       at System.Text.Json.JsonDocument.Parse(ReadOnlyMemory`1 utf8Json, JsonReaderOptions readerOptions, Byte[] extraRentedBytes)
                                       at System.Text.Json.JsonDocument.Parse(ReadOnlyMemory`1 utf8Json, JsonDocumentOptions options)
                                       at DuetControlServer.Model.Updater.Run() in /home/christian/Duet3D/DuetSoftwareFramework/src/DuetControlServer/Model/Updater.cs:line 100
                                    I also have that on startup for some other keys, e.g. "inputs" and "move". But the one above is reoccurring. It stop when the PanelDue's screensaver is on.
                                    Some more system info:
                                    M115
                                    FIRMWARE_NAME: RepRapFirmware for LPC176x based Boards FIRMWARE_VERSION: 3.2-beta1_2 ELECTRONICS: LPC176x FIRMWARE_DATE: 2020-09-15b1
                                    Board: biquskr_1.4 (LPCSBC)
                                    DSF Version: 3.2.0-beta1+1
                                    • wilrikerundefined
                                      wilriker @docbobo
                                      @docbobo When the screensaver is active it reduces update poll rate from 1Hz to 0.25Hz. So this rather looks to me as if the LPC build has issues with available RAM or better: cleanly handling the lack of available output buffers.
                                      Manuel
                                      My Tool Collection
                                      • gloomyandyundefined
                                        gloomyandy
                                        @wilriker I look after the LPC port and have a couple of questions if you can spare some time...
                                        1. Is the panelDue causing any extra json requests to be sent to DSF, or is it just likely that having both the panelDue and DSF making requests is putting extra strain on the available buffer space?
                                        2. What are the assumptions made about available output buffers (if any)?
                                        3. It seems odd that a partial response is being sent to DSF. Is that what you would expect if the system runs out of output buffers? I would have thought that it would make more sense to assemble all of a json response before sending it?
                                        The LPC port uses the same mechanism for handling a lack of buffers as does the Duet ports, so it seems likely that if the LPC has problems then in other circumstances (under heavy load or whatever) the Duet versions will hit the same problem. We do have a smaller number of buffers defined (16), but that is the same as number used by some other Duet hardware (that using SAM3XA mcus), but perhaps those Duets will never be used with an SBC?
                                        T3P3Tonyundefined dc42undefined wilrikerundefined 3 Replies Last reply Reply Quote 1
                                          T3P3Tony administrators @gloomyandy
                                          @gloomyandy said in PanelDueFirmware 3.2-RC3 released:
                                          I cant answer the other questions, but the old SAM3X MCUs wont be supported connected to an SBC. Its close to the resource limit on Duet 2s using SAM4s
                                          gloomyandyundefined 1 Reply Last reply Reply Quote 0
                                            gloomyandy @T3P3Tony
                                            @T3P3Tony said in PanelDueFirmware 3.2-RC3 released:
                                            Thanks for the information Tony. I suspected that might well be the case!
