Help needed - print quality issue
@Veti said in Help needed - print quality issue:
@MartinNYHC said in Help needed - print quality issue:
extruderRetractionDistance,0.75
M572 D0 S0.1
Your pressure advance seems high for a retraction distance of 0.75
I always used 1mm retraction and did a PA test. Result can be found here. I lowered the retraction this morning to check if that changes anything.
I just recognized that the "bad corner" is always the one where the layer starts.
As already mentioned it is always the corner where the layer starts that is "bad".
I'm totally lost. Any ideas please?
And another pressurte advance test...
Another Benchy...
what extruder do you have?
Bondtech, Mosquito Magnum with approx. 20mm PTFE tube between.
can you try to adjust to bondtech tension to a lot higher and try that?
No difference. Still the corner where the layer starts
you did not yet say if the print with another slicer was better
Oh sorry....no it's the same result.
and did you print one without pressure advance?
Yes, but in the meantine I changed some settings. Will do another print without PA.
I fear the worst that it is a mechanical issue. When I compare the prints the "bad corner" has the same pattern:
Without pressure advance it looks better but I still have the scars where the layer starts. I don't have an idea at all what to do next. Any more ideas from you experienced guys are very appreciated!
What PA value did you land on?
when you grab the hotend with your fingers while the motors are powered, can you displace the hotend slightly?
@Phaedrux said in Help needed - print quality issue:
For now I'bve choosen 0.06. Not sure if that is the best choice.
Nope, it's tight.
