    Tips to mitigate vertical artifacting Duet 2 Wifi
    91
    8.2k
    • brotherchrisundefined
      brotherchris @NexxCat
      @NexxCat lol, thank you!
        Yeah definitely looking like VFA. Upping your natural steps per mm on XY would be a good next step.
          brotherchris
          The 0.9 motors might have helped a bit, but I think this is as good as it's going to get. 1.8 on the right 0.9 on the left.20201003_145945.jpg
          • botundefined
            bot
            Did you end up playing with a range of jerk (instantaneous speed change) values? I've found that certain values of jerk are much worse than others for artifacts like this. Obviously, the amount of acceleration plays a role, too.
            Try a test of ranges of jerk values with a range of acceleration values, too. I almost forgot to mention feedrate. Try a combination of different jerk, accel, and feedrates.
            dc42 has on his list to implement some alternative to "jerk" (not real jerk, but you know what we mean) similar to junction deviation. After finally learning what junction deviation actually is and how exactly it works -- I'm convinced that I would like to try it! It might alleviate problems like this: weird motion on curves.
            *not actually a robot
            brotherchrisundefined 1 Reply Last reply Reply Quote 1
              brotherchris @bot
              @bot I have made a few changes, my settings are pretty low at the moment, but I could setup a test and try different ranges.
              • botundefined
                bot @brotherchris
                @brotherchris it's not exactly putting them low that makes the best results -- it's just finding the right combination. For me, for example, 4, 5, 6, and 7 mm/s jerk produces worse results than 8 mm/s. In some tests. It's hard to figure out, but sometimes you find a combination that works magically. Heh. It's my method for now: guess and check.
                brotherchrisundefined 1 Reply Last reply Reply Quote 2
                  brotherchris @bot
                  @bot lol, guess and check is my thing! Testing now, I will see if I can find a combo. Thanks for the tips.
                    brotherchris
                    Well, I am going to take that back. The single wall prints are much improved by the 0.9 steppers. Top one is before. 20201003_161602.jpg
                    • mwolterundefined
                      mwolter
                      Chris, fan of your videos and appreciate your contributions to the community.
                      One question, can you do a single wall test with varying line widths? For instance, 0 to 9.8mm at .4 mm width, 10 to 19.8 .42mm width, etc. In the past, I’ve found vertical or diagonal lines like this caused by inconsistent extrusion and can point to an issue with your extruder. If you perform a single wall test with extrusion parameters that vary at different heights and the angle of the diagonal lines changes, there could be an issue with inconsistent extrusion.
                      The key is to see if the angle of the diagonal line artifacts changes with varying extrusion parameters.
                      brotherchrisundefined 2 Replies Last reply Reply Quote 1
                      • Vetiundefined
                        Veti
                        hi chris.
                        i presume that you have done the mechanical checks.
                        corexy are very susceptible to problems in the belt path.
                        • bad pulleys
                        • toothed belt on smooth pulley
                        • belts not parallel
                        also check for slight belt twisting when the direction of movement of the belt changes.
                        16 tooth pulley can improve the effect from switching from 1.8 to 0.9 pulleys further.
                          brotherchris @Veti
                          @Veti I have been over it many times and I am still running belts over smooth pullies. That is my next move. I need to find some toothed pullies that will fit my setup. I am currently using flanged bearings.
                          Vetiundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
                            brotherchris @mwolter
                            @mwolter Thank you! That's an interesting thought. I will setup a test and see what happens.
                            • Vetiundefined
                              Veti @brotherchris
                              @brotherchris
                              If you are running them over F623zz then finding a good tooth pulley will be hard.
                              the only thing that comes close are Gates Powergrip® 2GT Idlers, buy they are 5mm ID.
                              brotherchrisundefined 1 Reply Last reply Reply Quote 0
                                brotherchris @Veti
                                @Veti Yeah, that kind of sucks. I have been looking for alternatives all morning, but 5mm bore is about my only option. I really didn't want to go down that small. I am determined to find some sort of work around.
                                • Vetiundefined
                                  Veti
                                  what quality are your F623zz ? for a corexy they should be ABEC-3 or above.
                                  • Vetiundefined
                                    Veti
                                    i am going to test these myself once they arrive.
                                    https://www.aliexpress.com/item/4000040551804.html
                                    but i dont have high hopes
                                    Adrian52undefined 1 Reply Last reply Reply Quote 1
                                      brotherchris @Veti
                                      @Veti I am actually using F688ZZ. Not sure the grade.
                                      • Vetiundefined
                                        Veti @brotherchris
                                        @brotherchris said in Tips to mitigate vertical artifacting Duet 2 Wifi:
                                        F688ZZ
                                        closest thing i can find is
                                        https://www.aliexpress.com/item/32961265334.html
                                        but its 6mm bore
                                        • Adrian52undefined
                                          Adrian52 @Veti
                                          @Veti I am trying 16 tooth idlers like this on my kossel delta, but have bought some 6x2.5x3mm bore bearings, and pressed 3 into each idler. You clamp the idler firmly (not possible with the original 2 bearing idlers), but you need 3mm bore washers that are 4.5mm diameter to do this. Will be interesting to see if they last longer.
                                          • fcwiltundefined
                                            fcwilt @brotherchris
                                            It seems you think 5mm is too small. Why do you think that is so?
