    New hemera settings
    3.2k
    • ziggymanpopoundefined
      ziggymanpopo
      Yes indeed also put a small amount ik f heatoastvon it befoyr i slid it in,, good fit
        ziggymanpopo
        Yes the other manufacture used the same metal
        3mm carriage in a hemera. little heat paste fit good
        Thanks for the input guys i gotta finish later its 3 am 😁 again. lol
          ziggymanpopo
          what i changed.
          The whole x carrage
          It now ri s on two linear rail
          Of course the hemera
          A new pt 1000 sensor
          Changed from a capasitive z-stop to a nozzle activated z-stop controled by a limit Sw.
          Also upgraded the x axes stepper to a 2amp.
          And a 10mm belt to compensate for the added weights ...
          Z is dailed in nicely and current have been
          adjusted 1100 m.a. on the x stepper
            ziggymanpopo
            Oh and the steps on the extruder per the hamera e3d site
            • oliofundefined
              oliof
              What does your part cooling setup look like? The hull of the benchy up to that line has quite steep overhangs until the point where it recovers, so this could be an effect of bad cooling or overhang performance. Make sure to print the outer wall last in this section of the benchy so the overhangs can adher to the inner wall as well.
              (Here is a great resource interpreting Benchy prints and what the individual features test for https://github.com/3DprinterDiscord/wiki/wiki/3D-Benchy).
              • Vetiundefined
                Veti @ziggymanpopo
                @ziggymanpopo said in New hemera settings:
                you should run the steppers at around 75% of the rated current
                try 1700ma
                  ziggymanpopo
                  So i know why 70% must be a reason.. does it change
                  For a belt versa a ballscrew
                  • Vetiundefined
                    Veti @ziggymanpopo
                    @ziggymanpopo
                    duet2 only goes in steps of 100ma
                      ziggymanpopo
                      Thsnks for the benchy imfo. It will help.
                      The cooling is like the fang two curved airducts and a squirrel cage type fan it seems to be way mor than i need for pla or petg
                        ziggymanpopo
                        I seam to get rhe best results whem i turn the fan realy low 30% Or so
                          ziggymanpopo
                          I thinnk it would be prudent to get conformation of exactly where my temp sits then go after the cooling setting. I think my bigest prolem is figuaring out where my settings should be since everything has changed cant go by what i had ...right ??? The question is where to start my calibation
                          I thought after reviewing the links i was sent about pid that We depend on the value of the given device
                          (sensor or termistor) to be correct i guess whats throwing me is when i print anywhere close to 210°c
                          The effects are like its way too hot.. so i an thinking of buying test equiptment capable of telling me acctual temps. (Multi meter with a sensor.)
                          Get that dialed in. what do you thinkn good place to start ???
                            ziggymanpopo
                            The prints keep improving but cant seam to get rid of the large error on the bow
                            Anyone have any idea what caused it
                            Her i ran two benches at 200and 205c
                            Thebsteper curennt change helped a little
                            But for some reason the line on the bow justnis persistend.
                            Ive gone up to 220c to the point where it cisablt melts the deck and its still there
                            so dont think its temp related
                            Thought maybe is mechanically hung up. But its always in the same place
                              ziggymanpopo
                              I also moved the benchy to a div spot on the build platform
                              Also ran the same slicer program from laptop to rule out slicer. ????
                              Im baffled running out of things to check and ideas
                                ziggymanpopo
                                Current rating is 1.33amps is it possable this js where my prob is extruder ma??? 😳
                                  ziggymanpopo
                                  Extruder current??
                                  • Vetiundefined
                                    Veti
                                    you are running at 950 which is about 70%. that should be fine
                                      Phaedrux Moderator @ziggymanpopo
                                      https://help.prusa3d.com/en/article/the-benchy-hull-line_124745
                                      Try some different test print models.
                                        ziggymanpopo
                                        Hey phaedrux... Thank you for the benchy link ..That explains it.. see the pick.... it ptinted fairly well i couldn't explain the lines at all now i understand
                                        You will notice the missing lines on the tray
                                        To complicate the analysis,16023490399355724165675788726501.jpg the hamera i got is one of the miss mached gear ones (3%of one run had this ) guess I'm one of the lucky ones ??
                                        I was testing feed rate and heard the extruder start popping the gears at a 30mm per sec. feedrate ..
                                        With your benchy link i beleave i have an awnser
                                        Thanks Again. Ed
                                          Cute dice tower.
                                            ziggymanpopo
                                            Like yours beter 😁
