    Duet 2 Ethernet no connection
    2.0k
    • camposm7undefined
      camposm7
      I think I was able to flash the firmware successfully. Windows device manager didn't recognize the board until I reset it a few times.
      Still no response in YAT when I throw M115 at it. Maybe I am missing a step in configuring YAT!
        A Former User @camposm7
        @camposm7 said in Duet 2 Ethernet no connection:
        prey tell; what does it recognize it as? if it shows up as a bossa device then its not flashed properly; if it shows up as a duet then you're good, if it shows up as something else then check the usb device id or install the correct drivers.
        camposm7undefined 1 Reply Last reply Reply Quote 0
        • camposm7undefined
          camposm7 @A Former User
          @beare It does indeed show up as bossa device.
            Ok well at least it's showing up as something. Since it's showing as a bossa device it means it doesn't have firmware on it.
            Please carefully go through the bossa flashing procedure here: https://duet3d.dozuki.com/Wiki/Installing_and_Updating_Firmware#Section_Fallback_procedure_Num_3
            • camposm7undefined
              camposm7 @Phaedrux
              @Phaedrux The directions say Check boxes Erase all, Lock, and Boot from Flash. However there is no boot to flash check box. Am I supposed to check boot to flash?
                Can you show a screenshot of the bossa window? If you're on windows you should be able to press alt-print screen and then cntrl-v in the post window to paste a screenshot.
                • camposm7undefined
                  camposm7 @Phaedrux
                    yes I think boot to flash and boot from flash are meant to be the same.
                    What version of bossa is that?
                    • camposm7undefined
                      camposm7
                      v. 1.9.1
                        Ok, so does it write and verify correctly?
                        Did you follow the instructions on removing the jumper before flashing?
                        Remove the erase jumper as soon as the Diag LED lights up. This means you are successfully in programming mode.
                        Once flashed, power cycle the board and you should now have a port to connect with YAT.
                          A Former User
                          maybe try windows key + R, type cmd and click OK.
                          and then paste in the command below in the new window and press enter? (type out the whole path if its not under your own user profile.)
                          "%ProgramFiles(x86)%\BOSSA\bossac.exe" --port=COM14 -e -w -v -b -R "%USERPROFILE%\Documents\Syncro\Firmware\Duet2and3Firmware-3.1.1\Duet2CombinedFirmware.bin"
                          Clearly something goes wrong with resetting the cpu after flashing, or its become faulty.
                          camposm7undefined 1 Reply Last reply Reply Quote 1
                          • camposm7undefined
                            camposm7
                            Yes, it does Bossa does write and verify correctly.
                            I followed the instructions to the T, however my diag led is on even after removing the jumper and resetting.
                            As you can see in the picture it is still listed as a Bossa Program Port. It looks like it's connected to YAT but still unable to respond to Gcode commands.
                            • camposm7undefined
                              Jackpot! Thank you!
                                so it's working now?
                                  I think something got lost in translation to be honest, but that is why I suggested using the command line version with the -R flag as it removes the need for manually resetting the board.
                                  Maybe someone could file an issue on the bossa github to have the -R flag function added to the GUI version; would simplify things a little.
                                  • camposm7undefined
                                    camposm7 @Phaedrux
                                    @Phaedrux I was able to flash the firmware, and while I can now web into the board and shows connection established, my PanelDue contently displays Connecting. None of my macros are displayed on the panel although the web interface does display my macros. My extruder heaters are undefined. No thermistor readings. Some weird things happening. Even a simple M119 reports Endstops - X: no endstop, Y: no endstop, Z: no endstop, Z probe: at min stop
                                    I'm not even sure where to begin with this. It's like it isn't reading the config file properly. Using the same config I was previously using that was working fine before erasing the board and starting fresh
                                    • Vetiundefined
                                      Veti
                                      that sounds like you flashed rrf3.
                                      this requires some changes in the config. see
                                      https://duet3d.dozuki.com/Wiki/RepRapFirmware_3_overview#Section_Summary_of_what_you_need_to_do_to_convert_your_configuration_and_other_files
                                      post your config.g
                                        It may be helpful to create a fresh config set using the online configurator then you can compare it to your current config and see what's all changed.
                                        https://configtool.reprapfirmware.org/Start
                                        • camposm7undefined
                                          camposm7 @Veti
                                          @Veti
                                          What is the best method to post my config for ease of reading?
                                          • Vetiundefined
                                            Veti
                                            post the config.g file into the window here
                                            select it and press the code button
