    G30 and G29 show different results
    639
    • fcwiltundefined
      fcwilt @TC
      @TC
      Have you done this multiple times to see if it varies?
      And you are sure the G30 point is the same as the center G29 point?
      TCundefined 1 Reply Last reply Reply Quote 0
      • TCundefined
        TC @fcwilt
        @fcwilt I probed it several times manually with G30 and it allways showed an error of +-0.005. Nothing compared to 0.150...
        • fcwiltundefined
          fcwilt @TC
          @TC said in G30 and G29 show different results:
          Sorry, I meant have you done both the G30 and the G29 multiple times together.
          • TCundefined
            TC @fcwilt
            @fcwilt Yes its allways the same. G29 has a constant offset
            • fcwiltundefined
              fcwilt
              Well at this point we need to see these files:
              CONFIG.G HOMEALL.G HOMEX.G HOMEY.G HOMEZ.G BED.G and a screen shot of the displayed height map.
              • TCundefined
                TC @fcwilt
                @fcwilt config.g homex.g homey.g homez.g bed.g
                • TCundefined
                  TC @TC
                  @TC Ignore the commented stuff 😉
                  I played around a lot
                  • fcwiltundefined
                    fcwilt
                    Looking at them now.
                    Just FYI in the future you may want to try using the </> tag which allows pasting g-code into a scrolling region of it's own.
                    See below where I pasted your bed.g file:
                    ; Auto calibration routine for an example delta printers
                    ; Before running this, you should have set up your zprobe Z offset to suit your build, in the G31 command in config.g.
                    ;you should use https://configurator.reprapfirmware.org/ to setup a correct bed.g file for your printer, what is below is just an example (and its commented out)
                    G1 Z3.0
                    G31 P{sensors.probes[0].value[0] + 30} Z0.0
                    G29 S2
                    G29
                    • TCundefined
                      TC @fcwilt
                      @fcwilt Ah thanks for the hint
                      • fcwiltundefined
                        fcwilt
                        Well that was fun - those files are a bit cluttered with unused/unneeded commands.
                        Anyway what is the intent of the the command below?
                        Aside from that as near as I can determine you are running G30 at X150 Y130 but the center point for G29 is X152.5 Y130.
                        It's possible those points are not at the same Z height but a difference of 0.15 doesn't seem likely.
                        Please take screen shot of the height map.
                        • TCundefined
                          TC @fcwilt
                          @fcwilt I know I have to tidy them up a bit 😉
                          The purpose of this line is to have a reliable trigger value in case it chanches over time. I found this method here in the forum and it works perfect.
                          Regarding the probe point you are right but thats definitly not the reason. The height map is allmost plane just all red... I can post a pciture tomorrow
                            Sinec your config files are rather convoluted I would suggest getting a very basic stock config set from the web configurator with the minimal adjustments needed to match your hardware and then checking again if you get the same issue. Chances are there is something in the configuration that is causing a problem, but there's only one way to be sure.
                            Also, please post the results of M122, and M98 P"config.g"
                            • fcwiltundefined
                              fcwilt @TC
                              And what data is contained in sensors.probes[0].value[0]?
                              • TCundefined
                                TC @fcwilt
                                @fcwilt its the analog input value provided by the untouched piezo sensor
                                • lord binkyundefined
                                  lord binky
                                  My first guess is that if you're seeing an constant offset across the board, that'd be the discrepancy from programmed Z height, likely related to some missed steps traveling fast / accumulated after homing to the first probe point. I would reduce the travel speed in M558 to something fairly low to and see if it clears up. If it does, then you can play around with adjusting acceleration/ jerk settings to make it go away. If it doesn't, try lowering the feed rate too. Hopefully you'll find something with that.
