    [DSF Extension] Exec On MCode (was: Shutdown SBC)
    DSF Development
    22
    117
    10.0k
    • gtj0undefined
      gtj0
      So many possibilities, so little time. I'd like to take a week off from my day job to do all the things that things like this can enable. 🙂
      • wilrikerundefined
        wilriker
        Release 5.1
        This release makes execonmcode compatible with Duet Software Framework 2.2.0 and later.
        It can be found at GitHub Releases page as usual.
        Manuel
        My Tool Collection
        • PCRundefined
          PCR
          got this error
           dial unix /var/run/dsf/dcs.sock: connect: no such file or directory
          any idea?
          • PCRundefined
            PCR
            Sorted it out! The PI has to be connected to the Duet!
            • PCRundefined
              PCR
              made a little videos how to install it. Mainly for my own reference later
              How to install and test
              How to make it as a systemservice
              PCRundefined 1 Reply Last reply Reply Quote 2
              • oozeBotundefined
                oozeBot @wilriker
                @wilriker are the parameters capped at 3? If not, what are there limits? Thanks
                • wilrikerundefined
                  wilriker @oozeBot
                  @oozeBot It should be at least 23 (every upper-case letter except G, M and T). Possibly also every lower-case letter, but I never tried that.
                  The application itself has no enforced limit.
                  Manuel
                  My Tool Collection
                  • oozeBotundefined
                    oozeBot
                    I posted a response a few minutes ago, but deleted it after I finally realized my mistake..
                    One note on this that's worth mentioning is the % in the service file has to be escaped like %%. Here is an example file:
                    [Unit]
                    Description=Duet API listener Test
                    After=duetcontrolserver.service
                    Requires=duetcontrolserver.service
                    [Service]
                    ExecStart=/usr/local/bin/execonmcode -mCode 4567 -command "./test.sh %%A %%B %%C"
                    Restart=always
                    RestartSec=10
                    [Install]
                    WantedBy=multi-user.target
                    wilrikerundefined 1 Reply Last reply Reply Quote 2
                    • wilrikerundefined
                      wilriker @oozeBot
                      @oozeBot I added a note to the README.md. I hope this helps to prevent this trap in the future.
                      Manuel
                      My Tool Collection
                      • docboboundefined
                        docbobo
                        Is this compatible with the latest beta?
                        • wilrikerundefined
                          wilriker @docbobo
                          @docbobo said in [DSF Extension] Exec On MCode (was: Shutdown SBC):
                          Yes, it is. Though it's not built according to the DSF Plugin Specs, yet.
                          Manuel
                          My Tool Collection
                            A Former User @wilriker
                            @wilriker Good afternoon, I'm a newbie in the RFF/Duet world and I'm starting to move in all directions but I realize I need more helpt than expected....I want to install this https://forum.duet3d.com/topic/19225/timelapse-video-through-execonmcode?_=1604845400929
                            on my Rapsby to have the capability to take timelapses of my prints. It is based on execonmcode...
                            I am not a Raspberry/Linux expert too so I'm in trouble to undesrtand what I have to do...I have read the README.md contained in the latest version of the execonmcode but I don't exactly what to do
                            1. this is maybe the most stupid question you have ever heard: execonmcode has to be installed in the Raspy not in the Duet's SD, right?
                            2. Have the Raspy being connected via USB to the Duet or is enough that both are connected to the same LAN via WiFi?
                            3. To make the script work I have understood I have to make it work as a service and configure it like this:
                              [Unit]
                              Description=Duet API listener for Timelapse Video by oozeBot
                              [Service]
                              ExecStart=/usr/local/bin/execonmcode -mCode 5575 -command "./scripts/timelapse.sh %%A %%F"
                              Restart=always
                              RestartSec=10
                              [Install]
                            but on github I can't find documentation about services and about where ti write down the previous lines of code I found just in the readme:
                            • Optional: use the shutdownsbc.service systemd unit (included in the repo) to run it at startup and let it shutdown the SBC (customize to your liking)
                              but here again I haven't understood why now you call it shutdown again...
                            I now maybe I'm asking too much but could you help me understanding?
                            Thanks!
                            Andrea
                              jay_s_uk @A Former User
                              @the_dragonlord This has to be installed on a raspberry pi connected to a duet board through SPI.
                              Therefore it only supports duet 3's or duet 2 that have been modified to use an SBC connection.
                              It will not work with a standard duet 2 ethernet or wifi.
                                A Former User @jay_s_uk
                                @jay_s_uk said in [DSF Extension] Exec On MCode (was: Shutdown SBC):
                                uh.....so it's not enough an USB connection between them....ok...
                                  jay_s_uk
                                  it relies on the duet software framework to work.
                                  This would work for what you want https://github.com/DanalEstes/DuetLapse
                                    thanks!
                                    • GoremanXundefined
                                      GoremanX
                                      Is this still the easiest way to issue commands on the pi in SBC mode? Or has a native way been implemented in RRF in recent releases? Just wanted to check before investing time and effort in something that's obsolete 😄
                                      • GoremanXundefined
                                        GoremanX
                                        Hah! Too late, I'm already neck-deep in implementing it
                                        @wilriker How do I make it execute the command and exit right away and return success without having to wait for the command to complete? I tried sending my command to background with & but that doesn't appear to work. I'm trying to get it to run a process which continues through the duration of the print, but executing the M code just causes it to hang until the process is complete. I thought it would be execAsync, but that gives me an error on the command line saying that's not a supported flag
                                        • garethkyundefined
                                          garethky
                                          I need this in my life! 😀 I was going to do something evil with file monitoring but this is much more direct.
                                          I'm planning to use it to run some Python to calculate a bed heightmap to enable probing magnetic beds with irregular optimal probing locations.
                                          • GoremanXundefined
                                            GoremanX
                                            @wilriker I don't think -execAsync is implemented in the 5.1 release. I just downloaded the source code for that release and there's no mention of execAsync anywhere. It's only implemented in the current (uncompiled) source code in the repository. Any chance you could push out a more recent release with the current code? It's the last bit I need to get my setup working.
