    [DSF Extension] Exec On MCode (was: Shutdown SBC)
    DSF Development
    22
    117
    10.0k
    • wilrikerundefined
      wilriker @chas2706
      @chas2706 If you don't start it (automatically or manually) there is no need to do anything. It can sit in the filesystem that won't have any effect until you execute it.
      Manuel
      My Tool Collection
      • wilrikerundefined
        wilriker
        Release 4.0
        This version works with DuetSoftwareFramework 1.3.0 and later.
        Unfortunately due to breaking changes in the API of DSF this is NOT backwards-compatible with older versions of DuetSoftwareFramework.
        This release also has a new parameter -trace that will enable output of the underlying requests/responses to/from DuetControlServer.
        It can be downloaded as usual from GitHub Releases page.
        Manuel
        My Tool Collection
        • wilrikerundefined
          wilriker
          Release v5.0
          This release updates godsfapi to v2 and thus is only compatible with Duet Software Framework 2.1.0 and later.
          New Features
          • A new command-line paramter -version to output the version and exit
          Bug fixes
          • After a handled code is intercepted and before the assigned command is executed Flush will be called to make sure we are in sync with the machine
          Manuel
          My Tool Collection
          • gtj0undefined
            gtj0
            So many possibilities, so little time. I'd like to take a week off from my day job to do all the things that things like this can enable. 🙂
            • wilrikerundefined
              wilriker
              Release 5.1
              This release makes execonmcode compatible with Duet Software Framework 2.2.0 and later.
              It can be found at GitHub Releases page as usual.
              Manuel
              My Tool Collection
              • PCRundefined
                PCR
                got this error
                 dial unix /var/run/dsf/dcs.sock: connect: no such file or directory
                any idea?
                • PCRundefined
                  PCR
                  Sorted it out! The PI has to be connected to the Duet!
                  • PCRundefined
                    PCR
                    made a little videos how to install it. Mainly for my own reference later
                    How to install and test
                    How to make it as a systemservice
                    PCRundefined 1 Reply Last reply Reply Quote 2
                    • oozeBotundefined
                      oozeBot @wilriker
                      @wilriker are the parameters capped at 3? If not, what are there limits? Thanks
                      • wilrikerundefined
                        wilriker @oozeBot
                        @oozeBot It should be at least 23 (every upper-case letter except G, M and T). Possibly also every lower-case letter, but I never tried that.
                        The application itself has no enforced limit.
                        Manuel
                        My Tool Collection
                        • oozeBotundefined
                          oozeBot
                          I posted a response a few minutes ago, but deleted it after I finally realized my mistake..
                          One note on this that's worth mentioning is the % in the service file has to be escaped like %%. Here is an example file:
                          [Unit]
                          Description=Duet API listener Test
                          After=duetcontrolserver.service
                          Requires=duetcontrolserver.service
                          [Service]
                          ExecStart=/usr/local/bin/execonmcode -mCode 4567 -command "./test.sh %%A %%B %%C"
                          Restart=always
                          RestartSec=10
                          [Install]
                          WantedBy=multi-user.target
                          wilrikerundefined 1 Reply Last reply Reply Quote 2
                          • wilrikerundefined
                            wilriker @oozeBot
                            @oozeBot I added a note to the README.md. I hope this helps to prevent this trap in the future.
                            Manuel
                            My Tool Collection
                            • docboboundefined
                              docbobo
                              Is this compatible with the latest beta?
                              • wilrikerundefined
                                wilriker @docbobo
                                @docbobo said in [DSF Extension] Exec On MCode (was: Shutdown SBC):
                                Yes, it is. Though it's not built according to the DSF Plugin Specs, yet.
                                Manuel
                                My Tool Collection
                                  A Former User @wilriker
                                  @wilriker Good afternoon, I'm a newbie in the RFF/Duet world and I'm starting to move in all directions but I realize I need more helpt than expected....I want to install this https://forum.duet3d.com/topic/19225/timelapse-video-through-execonmcode?_=1604845400929
                                  on my Rapsby to have the capability to take timelapses of my prints. It is based on execonmcode...
                                  I am not a Raspberry/Linux expert too so I'm in trouble to undesrtand what I have to do...I have read the README.md contained in the latest version of the execonmcode but I don't exactly what to do
                                  1. this is maybe the most stupid question you have ever heard: execonmcode has to be installed in the Raspy not in the Duet's SD, right?
                                  2. Have the Raspy being connected via USB to the Duet or is enough that both are connected to the same LAN via WiFi?
                                  3. To make the script work I have understood I have to make it work as a service and configure it like this:
                                    [Unit]
                                    Description=Duet API listener for Timelapse Video by oozeBot
                                    [Service]
                                    ExecStart=/usr/local/bin/execonmcode -mCode 5575 -command "./scripts/timelapse.sh %%A %%F"
                                    Restart=always
                                    RestartSec=10
                                    [Install]
                                  but on github I can't find documentation about services and about where ti write down the previous lines of code I found just in the readme:
                                  • Optional: use the shutdownsbc.service systemd unit (included in the repo) to run it at startup and let it shutdown the SBC (customize to your liking)
                                    but here again I haven't understood why now you call it shutdown again...
                                  I now maybe I'm asking too much but could you help me understanding?
                                  Thanks!
                                  Andrea
                                    jay_s_uk @A Former User
                                    @the_dragonlord This has to be installed on a raspberry pi connected to a duet board through SPI.
                                    Therefore it only supports duet 3's or duet 2 that have been modified to use an SBC connection.
                                    It will not work with a standard duet 2 ethernet or wifi.
                                      A Former User @jay_s_uk
                                      @jay_s_uk said in [DSF Extension] Exec On MCode (was: Shutdown SBC):
                                      uh.....so it's not enough an USB connection between them....ok...
                                        jay_s_uk
                                        it relies on the duet software framework to work.
                                        This would work for what you want https://github.com/DanalEstes/DuetLapse
                                          thanks!
                                          • GoremanXundefined
                                            GoremanX
                                            Is this still the easiest way to issue commands on the pi in SBC mode? Or has a native way been implemented in RRF in recent releases? Just wanted to check before investing time and effort in something that's obsolete 😄
