    Buck converter , switch off pwm ?
    • peter247undefined
      peter247
      Hi , I want to control a 12volt fan using a 24v to 12v buck converter .
      Just want to switch it on or off not control the speed with pwm , on version 3.1.1 can I switch the pwm off are is that by setting the maximum setting 255 ?.
      Ender 5 plus linear rail and hemera powered by duet 2 wifi , CR10s pro v1 with bltouch mostly stock , BLV mgn Cube slowly being built powered by duet 3 mini 5+
        Switching it on and off is the same as controlling the speed.
        M106 S0/S1 would be off and on.
        The switching is done on the negative side. Your buck converter can either power the entire fan bank by connecting positive to the v_fan jumper, or you can power just that one fan by connecting the buck converter positive to the fan positive and the fan negative to the fan port negative. Then control the fan with M106.
        https://duet3d.dozuki.com/Wiki/Connecting_and_configuring_fans#Section_Using_12V_fans_when_VIN_is_24V
        peter247undefined 1 Reply Last reply Reply Quote 0
        • peter247undefined
          peter247 @Phaedrux
          @Phaedrux
          So if you don't set the Q do you get a binary on or off ?
          M950 F2 C"fan2" Q500
            The on and off is always going to be PWM based, the frequency is irrelevant for the off state and for the on state you're going to want to use one that works well for the fan. Q500 is the default.
