    M701 causes reboot 3.2-beta2
    Beta Firmware
    406
    • TCundefined
      TC
      Hi I don't know what is going on but when I try to use the M701 or the Load filament option in DWC the Duet Ethernet with RRF 3.2-beta2 reboots. Is it possible there is a bug in the new version?
        Can you capture a M122 after the reboot?
        TCundefined 1 Reply Last reply Reply Quote 0
        • TCundefined
          TC @Phaedrux
          @Phaedrux
          M122
          RepRapFirmware for Duet 2 WiFi/Ethernet version 3.2-beta2 running on Duet Ethernet 1.02 or later + DueX5
          Board ID: 08DGM-917NK-F2MSW-6JKDG-3S86T-KZ5ND
          Used output buffers: 1 of 24 (13 max)
          Static ram: 24028
          Dynamic ram: 96364 of which 44 recycled
          Exception stack ram used: 200
          Never used ram: 10436
          Tasks: NETWORK(ready,137) HEAT(blocked,308) DUEX(blocked,36) MAIN(running,445) IDLE(ready,19)
          Owned mutexes:
          Last reset 00:01:36 ago, cause: software
          Last software reset at 2020-10-08 18:22, reason: AssertionFailed, GCodes spinning, available RAM 10436, slot 0
          Software reset code 0x4123 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0441f000 BFAR 0xe000ed38 SP 0x20004264 Task MAIN
          Stack: 0000059e 004716a8 00450849 0000000d ffffffff 20000db0 4d454144 200032a8 ffffffff 00000000 20002eb4 a5a5a5a5 004508cb 200042b0 0045e98c 20007940 0044e14f 200042cc 00446049 2000329c 200042cc 00000001 200042d4 00000000 004460b3 000000c8 200042d4
          Error status: 0x00
          MCU temperature: min 34.4, current 35.2, max 35.4
          Supply voltage: min 24.1, current 24.1, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes
          Driver 0: position 0, standstill, SG min/max not available
          Driver 1: position 0, standstill, SG min/max not available
          Driver 2: position 0, standstill, SG min/max not available
          Driver 3: position 0, standstill, SG min/max not available
          Driver 4: position 0, standstill, SG min/max not available
          Driver 5: position 0, standstill, SG min/max not available
          Driver 6: position 0, standstill, SG min/max not available
          Driver 7: position 0, standstill, SG min/max not available
          Driver 8: position 0, standstill, SG min/max not available
          Driver 9: position 0, standstill, SG min/max not available
          Driver 10: position 0
          Driver 11: position 0
          Date/time: 2020-10-08 18:24:23
          Cache data hit count 187762902
          Slowest loop: 11.53ms; fastest: 0.17ms
          === Storage ===
          Free file entries: 10
          SD card longest read time 3.4ms, write time 13.9ms, max retries 0
          Hiccups: 0(0), FreeDm: 169, MinFreeDm: 169, MaxWait: 0ms
          === MainDDARing ===
          === AuxDDARing ===
          Segments left: 0
          Movement lock held by null
          HTTP is idle in state(s) 0
          Telnet is idle in state(s) 0
          File is idle in state(s) 0
          USB is idle in state(s) 0
          Aux is idle in state(s) 0
          Trigger is idle in state(s) 0
          Queue is idle in state(s) 0
          LCD is idle in state(s) 0
          Daemon is idle in state(s) 0
          Code queue is empty.
          === Network ===
          Slowest loop: 50.53ms; fastest: 0.02ms
          HTTP sessions: 1 of 8
          Interface state active, link 100Mbps full duplex
          === DueX ===
          Read count 1, 0.62 reads/min
              0
          33
          Posts
          471
          Views
          • OwenDundefined
            OwenD
            I can confirm same issue
            Resets after any filament macro is run.
            Duet 2 wifi
            09/10/2020, 7:42:16 pm	M122
            RepRapFirmware for Duet 2 WiFi/Ethernet version 3.2-beta2 running on Duet WiFi 1.02 or later
            Board ID: 08DGM-917NK-F2MS4-7J1DA-3S86T-TZTWD
            Used output buffers: 3 of 24 (16 max)
            Static ram: 24028
            Dynamic ram: 100328 of which 44 recycled
            Exception stack ram used: 264
            Never used ram: 6408
            Tasks: NETWORK(ready,154) HEAT(blocked,294) MAIN(running,415) IDLE(ready,19)
            Owned mutexes:
            Last reset 00:00:38 ago, cause: software
            Last software reset at 2020-10-09 19:41, reason: AssertionFailed, GCodes spinning, available RAM 6112, slot 2
            Software reset code 0x4123 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f000 BFAR 0xe000ed38 SP 0x20004264 Task MAIN
            Stack: 0000059e 004716a8 00450849 0000003b ffffffff 20000c90 4d454144 200032a8 ffffffff 00000000 20002eb4 a5a5a5a5 004508cb 200042b0 0045e98c 20007940 0044e14f 200042cc 00446049 2000329c 200042cc 00000001 200042d4 00000000 004460b3 000000c8 200042d4
            Error status: 0x00
            MCU temperature: min 35.6, current 36.4, max 36.8
            Supply voltage: min 24.2, current 24.3, max 24.5, under voltage events: 0, over voltage events: 0, power good: yes
            Date/time: 2020-10-09 19:42:16
            Cache data hit count 62172132
            Slowest loop: 140.85ms; fastest: 0.17ms
            === Storage ===
            SD card longest read time 1.5ms, write time 0.0ms, max retries 0
            === MainDDARing ===
            === AuxDDARing ===
            Heater 1 is on, I-accum = 0.0
            Segments left: 0
            === Network ===
            Slowest loop: 40.15ms; fastest: 0.00ms
            Responder states: HTTP(2) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions
            - WiFi -
            Network state is active
            WiFi firmware version 1.23
            WiFi MAC address bc:dd:c2:89:a0:bb
            WiFi Vcc 3.38, reset reason Power up
            WiFi flash size 4194304, free heap 23128
            WiFi IP address 192.168.1.163
            WiFi signal strength -58dBm, reconnections 0, sleep mode modem
            Clock register ffffffff
              Thanks, I have located the problem. Will be fixed in next beta, and I may have an unofficial build before then.
              • TCundefined
                TC @dc42
                @dc42 Thanks David. Fast as allways 🙂
                  @TC , if you would like to test the fix, there is a new binary for Duet 2 at https://www.dropbox.com/s/5vhjjz4a28hu33g/Duet2CombinedFirmware.bin?dl=0.
                  • TCundefined
                    TC @dc42
                    @dc42 It works perfectly!
                      dc42 administrators @TC
                      Thanks for the feedback.
