M701 causes reboot 3.2-beta2
Hi I don't know what is going on but when I try to use the M701 or the Load filament option in DWC the Duet Ethernet with RRF 3.2-beta2 reboots. Is it possible there is a bug in the new version?
Can you capture a M122 after the reboot?
M122 === Diagnostics === RepRapFirmware for Duet 2 WiFi/Ethernet version 3.2-beta2 running on Duet Ethernet 1.02 or later + DueX5 Board ID: 08DGM-917NK-F2MSW-6JKDG-3S86T-KZ5ND Used output buffers: 1 of 24 (13 max) === RTOS === Static ram: 24028 Dynamic ram: 96364 of which 44 recycled Exception stack ram used: 200 Never used ram: 10436 Tasks: NETWORK(ready,137) HEAT(blocked,308) DUEX(blocked,36) MAIN(running,445) IDLE(ready,19) Owned mutexes: === Platform === Last reset 00:01:36 ago, cause: software Last software reset at 2020-10-08 18:22, reason: AssertionFailed, GCodes spinning, available RAM 10436, slot 0 Software reset code 0x4123 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0441f000 BFAR 0xe000ed38 SP 0x20004264 Task MAIN Stack: 0000059e 004716a8 00450849 0000000d ffffffff 20000db0 4d454144 200032a8 ffffffff 00000000 20002eb4 a5a5a5a5 004508cb 200042b0 0045e98c 20007940 0044e14f 200042cc 00446049 2000329c 200042cc 00000001 200042d4 00000000 004460b3 000000c8 200042d4 Error status: 0x00 MCU temperature: min 34.4, current 35.2, max 35.4 Supply voltage: min 24.1, current 24.1, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes Driver 0: position 0, standstill, SG min/max not available Driver 1: position 0, standstill, SG min/max not available Driver 2: position 0, standstill, SG min/max not available Driver 3: position 0, standstill, SG min/max not available Driver 4: position 0, standstill, SG min/max not available Driver 5: position 0, standstill, SG min/max not available Driver 6: position 0, standstill, SG min/max not available Driver 7: position 0, standstill, SG min/max not available Driver 8: position 0, standstill, SG min/max not available Driver 9: position 0, standstill, SG min/max not available Driver 10: position 0 Driver 11: position 0 Date/time: 2020-10-08 18:24:23 Cache data hit count 187762902 Slowest loop: 11.53ms; fastest: 0.17ms I2C nak errors 0, send timeouts 0, receive timeouts 0, finishTimeouts 0, resets 0 === Storage === Free file entries: 10 SD card 0 detected, interface speed: 20.0MBytes/sec SD card longest read time 3.4ms, write time 13.9ms, max retries 0 === Move === Hiccups: 0(0), FreeDm: 169, MinFreeDm: 169, MaxWait: 0ms Bed compensation in use: mesh, comp offset 0.000 === MainDDARing === Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1 === AuxDDARing === Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1 === Heat === Bed heaters = 0 -1 -1 -1, chamberHeaters = -1 -1 -1 -1 === GCodes === Segments left: 0 Movement lock held by null HTTP is idle in state(s) 0 Telnet is idle in state(s) 0 File is idle in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 Daemon is idle in state(s) 0 Autopause is idle in state(s) 0 Code queue is empty. === Network === Slowest loop: 50.53ms; fastest: 0.02ms Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions HTTP sessions: 1 of 8 Interface state active, link 100Mbps full duplex === DueX === Read count 1, 0.62 reads/min 0 33 Posts 471 Views
I can confirm same issue
Resets after any filament macro is run.
Duet 2 wifi09/10/2020, 7:42:16 pm M122 === Diagnostics === RepRapFirmware for Duet 2 WiFi/Ethernet version 3.2-beta2 running on Duet WiFi 1.02 or later Board ID: 08DGM-917NK-F2MS4-7J1DA-3S86T-TZTWD Used output buffers: 3 of 24 (16 max) === RTOS === Static ram: 24028 Dynamic ram: 100328 of which 44 recycled Exception stack ram used: 264 Never used ram: 6408 Tasks: NETWORK(ready,154) HEAT(blocked,294) MAIN(running,415) IDLE(ready,19) Owned mutexes: === Platform === Last reset 00:00:38 ago, cause: software Last software reset at 2020-10-09 19:41, reason: AssertionFailed, GCodes spinning, available RAM 6112, slot 2 Software reset code 0x4123 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f000 BFAR 0xe000ed38 SP 0x20004264 Task MAIN Stack: 0000059e 004716a8 00450849 0000003b ffffffff 20000c90 4d454144 200032a8 ffffffff 00000000 20002eb4 a5a5a5a5 004508cb 200042b0 0045e98c 20007940 0044e14f 200042cc 00446049 2000329c 200042cc 00000001 200042d4 00000000 004460b3 000000c8 200042d4 Error status: 0x00 MCU temperature: min 35.6, current 36.4, max 36.8 Supply voltage: min 24.2, current 24.3, max 24.5, under voltage events: 0, over voltage events: 0, power good: yes Driver 0: position 0, standstill, SG min/max not available Driver 1: position 0, standstill, SG min/max not available Driver 2: position 0, standstill, SG min/max not available Driver 3: position 0, standstill, SG min/max not available Driver 4: position 0, standstill, SG min/max not available Driver 5: position 0 Driver 6: position 0 Driver 7: position 0 Driver 8: position 0 Driver 9: position 0 Driver 10: position 0 Driver 11: position 0 Date/time: 2020-10-09 19:42:16 Cache data hit count 62172132 Slowest loop: 140.85ms; fastest: 0.17ms I2C nak errors 0, send timeouts 0, receive timeouts 0, finishTimeouts 0, resets 0 === Storage === Free file entries: 10 SD card 0 detected, interface speed: 20.0MBytes/sec SD card longest read time 1.5ms, write time 0.0ms, max retries 0 === Move === Hiccups: 0(0), FreeDm: 169, MinFreeDm: 169, MaxWait: 0ms Bed compensation in use: none, comp offset 0.000 === MainDDARing === Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1 === AuxDDARing === Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1 === Heat === Bed heaters = 0 -1 -1 -1, chamberHeaters = -1 -1 -1 -1 Heater 1 is on, I-accum = 0.0 === GCodes === Segments left: 0 Movement lock held by null HTTP is idle in state(s) 0 Telnet is idle in state(s) 0 File is idle in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 Daemon is idle in state(s) 0 Autopause is idle in state(s) 0 Code queue is empty. === Network === Slowest loop: 40.15ms; fastest: 0.00ms Responder states: HTTP(2) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions HTTP sessions: 1 of 8 - WiFi - Network state is active WiFi module is connected to access point Failed messages: pending 0, notready 0, noresp 0 WiFi firmware version 1.23 WiFi MAC address bc:dd:c2:89:a0:bb WiFi Vcc 3.38, reset reason Power up WiFi flash size 4194304, free heap 23128 WiFi IP address 192.168.1.163 WiFi signal strength -58dBm, reconnections 0, sleep mode modem Clock register ffffffff
Thanks, I have located the problem. Will be fixed in next beta, and I may have an unofficial build before then.
@dc42 Thanks David. Fast as allways
@TC , if you would like to test the fix, there is a new binary for Duet 2 at https://www.dropbox.com/s/5vhjjz4a28hu33g/Duet2CombinedFirmware.bin?dl=0.
@dc42 It works perfectly!
Thanks for the feedback.
