    -273 on maestro e0temp pins
    837
    • Vetiundefined
      Veti @ejarmo
      @ejarmo said in -273 on maestro e0temp pins:
      I don't know. the documentation from dyze is that the reading is supposed to be 4066017.
      https://docs.google.com/spreadsheets/d/e/2PACX-1vQ5LGUbs4B3uAqrQeEvOqFw1ZFCB3qpAPk3ThCYK9mBS7uiTEF4hjOD6-znxU25MZo19cjhfqDsc06Y/pubhtml
      at -20. are you in the arctic? 🙂
      edit: sorry got dize and slice mixed up
      post how you configured the thermistor
        Phaedrux Moderator @ejarmo
        update: v.3.2beta1 firmware update returns message "error, duet maestro IAP.bin not found"
        What firmware were you on before? You would have needed to update to 3.0 and then 3.1.1 before updating to the beta. With that missing file you may have needed to update to 2.05.1 first as well.
        • ejarmoundefined
          ejarmo
          this is confusing, if I put the sensor on a meter and it reads 4.6 meg ohms at room temperature. I had taken it the the heated bed to try to match any of the values in the dyze documentation, but none did. Regardless after several stupid mistakes I have firmware 3.2beta1 installed and a reading for the sensor adjusted on the high gain parameter so that it matches the print bed reading. should be close enough. all filaments will get a temperature print test and the sensor will provide rock steady temperatures. I haven't tested it yet but I wanted to thank everyone for the help. if something goes wrong now I will just give up.
          Phaedruxundefined dc42undefined 2 Replies Last reply Reply Quote 0
          • ejarmoundefined
            ejarmo
            I should also mention thanks especially for the slice temp table.
              Do keep in mind that it is an early beta and may contain all sorts of surprises. You may want to upload the 3.1.1 zip file just to stay on a stable release during troubleshooting to avoid any confounding variables.
              • ejarmoundefined
                ejarmo
                yes. for example the touchscreen on the printer now does not respond to any control elements. I am only able to go through the separate tabs but none of the items on any of the tabs will respond.
                  If you mean the paneldue you will need to update the paneldue firmware to 1.24 and you will need to add a command to config.g to enable the paneldue.
                  M575 P1 B57600 S1
                  https://duet3d.dozuki.com/Wiki/PanelDue_Firmware_update
                  • ejarmoundefined
                    ejarmo
                    @Phaedrux said in -273 on maestro e0temp pins:
                    you guys are so awesome
                      dc42 administrators @ejarmo
                      Can you link to the data for the thermistor? I thought the Dyze thermistor was 500K at 25C, which means at a room temperature of around 20C its resistance should be will below 4.6Mohms.
                      • Vetiundefined
                        Veti
                        https://docs.dyzedesign.com/general-support/temperature-sensors.html
                        there are 2 one 300 and one 500
                        • ejarmoundefined
                          ejarmo
                          I am wondering about a possible source for my temperature display to register values that fluctuate constantly between random values between -10 to +5 degrees of set point. the issue happened 10 hrs in to my first long print, no issues with the print however. my first guess was an overheat in the board, but I have a big fan on the board and I calibrated the board temp sensor. strangely it says the board is running at 24c which is lower than the 30ish that is normal.
                          • Vetiundefined
                            Veti
                            please see
                            https://forum.duet3d.com/topic/19163/help-pid-tuning-dyzend-pro/47?_=1602843872701
                            that thermistor need some extra modifications to work
                            • ejarmoundefined
                              ejarmo
                              I see your point, however I was getting excellent stable temperature until I got well into the long print. then the changes started. I have done the Hotend tuning and the stability is better but no as good as it was. perhaps there is some sort of break in.
