FAN1 suddenly stop working
@Major said in FAN1 suddenly stop working:
M563 P0 D0 H1 F0 ; define tool 0Well your current config has fan0 as part cooling fan and assigned to the tool. So it should work with the slider in DWC or by sending M106 P0 S1.
Fan1 is set as thermostatic control for the hotend to turn on above 45c.
There is no config for fan2.
Are you saying that the hotend fan doesn't turn on above 45c?
If you send M106 P1 H-1 S1 does it turn on?
Until the beginning of this week everything was working well with the config.g that I posted. From one moment to the next it stopped working.
What I noticed in the meantime is that the cable extension I used for the fan stopped working. There may have been a short that I didn't notice. Visually I don't see anything burned (as in the examples I saw here on the forum). I'll attatch a photo of my duet board (if relevant, my board version is 1.04b)
Now the fan does not work even if the heater temperature rises above 45º.
I tried to send M106 P1 H-1 S1 as suggested and the fan still doesn't work. I used a multimeter to measure the voltage at the FAN1 output and when it should be switched off, the voltage is 24V and after sending the command the voltage dropped to 20.7V.
The strange thing, at least for me, is that if I have current why the fan doesn't work.
In the meantime I changed in config.g to use FAN2 for the hotend and everything is working fine, but I want to repair the FAN1 output.
Could it be a Mosfet problem?
Thanks -
Yes it sounds like that may be the case. If there was a short in your cabling it's possible even if you can't visually see an exploded mosfet. They don't always fail spectacularly.
If the exact same fan works on fan2 but not on fan1 with the same configuration, then it's pretty likely it's the mosfet.
They can be replaced if you have the skills and equipment, but not for beginners IMO.
@Phaedrux said in FAN1 suddenly stop working:
Fortunately I already have some experience soldering and doing some rework (some time ago I started to build guitar effects pedals) and I also had some experience with SOT23 components.
My fear is that there are so many components so close to the mosfet. But I think I'll order some replacements and try my luck.
Thanks for all the help. -
I've heard of kapton tape being used as a heat shield.
If you are using hot air equipment, then the main problem is that the plastic parts of the nearby fan outputs and jumper blocks will be scorched. You can avoid this in a couple of ways:
Pull the plastic parts off with pliers (for the Molex connectors, it's easier if you heat the pins using ~180C hot air first), and replace them when you have replaced the mosfets and tested the fix.
Shield the plastic parts. I generally use 2 layers of masking tape and a top layer of Kapton tape.
You don't need to worry about heating other nearby SMD parts as long are you are careful not to jog them while the solder is molten.
When replacing 0603 and SOT23 components, I often remove the old part using hot air but use a fine-tipped soldering iron to fit the new ones. A no-clean flux pen makes it easier.
HTH David
Alternatively if you don't have hot air and don't mind being a bit of a savage ... you might be able to put a blob of solder on a sufficiently tip and just cover the whole part you want to remove with the blob of molten solder and when you lift the iron the part will stick to the surface tension of the solder blob.
It helps to make sure you can touch the pads, so lifting the plastic shroud of the molex connector can help in desoldering and is almost a must for soldering in the new unless you have a very fine tip iron.
If the blob trick doesn't work, you can crank the savage factor up to 11 and try literally "decapitating" the poor little SOT23, exposing the die and leads makes it a lot easier to pull with a good sized tip and blob of solder, make sure to use flush side cutters to avoid any forces lifting up from the board and try something like
yes, i read a post from David talking about it.
@dc42 said in FAN1 suddenly stop working:
Unfortunately I don't have a hot air gun. I will have to do everything with the soldering iron, but I'm thinking about ordering some Chip Quik to make it easier.
And i will use your use Kapton tape technique.
Thanks. -
@bearer said in FAN1 suddenly stop working:
Thank you for the advice. As I do not have a hot air gun, I may as well use this technique.
I hope I don't have to get to that point. But let's see how it goes.
